Hi all
I brought my 3 screen pinball set up. I am now just going 100% FB on the pinball and it has PinballX frontend. So my problem is the backglass not going full screen and it has the DMD in it as well. I am not sure if this is the right table for my set up, or if i can just change the backglass? I have add a picture to show you what i mean.
I can now resize the backglass with Bam, but when i start the game in PinballX is back to the small pic. It has 60+ other FB tables running fine, but i just wanted to add 1 more.
Thanks for any helppost-26876-0-02473600-1401859746_thumb.j
When reporting a possible bug or error, please submit a copy of the following files so we may quickly assist you:
For PinballX - pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required)
The BAM settings are saved when BAM is closed regulary. PinballX kills the BAM process, so the settings wont be saved!
To make things a little easier for you:
- Open a Table with BAM (NOT with PinballX)
- Resize the Backglass, the the DMD on your Backglass Screen is out of the screen and the Backglass has the correct size
- Exit BAM
- There is a Subfolder in your BAM Directory, which contains all your Table configs (like the Backglass Dimensions). Copy the cfg file you just created from that directory into your BAM directory.
- Delete or rename the default.cfg in the BAM directory
- Rename the cfg you copied into the BAM directory to default.cfg
Voila! Now every Backglass has the size you set in the table you started in the first step. You will still need to adjust the size of the Backglasses of all your tables by hand - but its easier to adjust the size if it is more or less correct.
Most important: Do NOT start your FP tables with PinballX if you want to change any settings (at least if you want them to be saved)
