I have a very weird problem getting my buttons to do what they are supposed to in pinballx.
According to the Windows game controllers control panel, my buttons are as follows:
4 Left flipper
5 Right flipper
3 Start button
7 Exit button
When I do the button config in pinballx settings this happens:
3 Left flipper
4 Right flipper
2 Start button
6 Exit
It gets even stranger because when I actually try to use those buttons this happens:
Right flipper - rotates screen
Exit button - does nothing
Left flipper - left (correct)
Start button - select (correct)
I'm not running xpadder. I do have joy2key on my machine for Pinball FX2 but I terminated it and it makes no difference. I don't have any problems like this with Hyperpin.
Hmm. It wouldn't bother me that the button numbers were different if they were performing the correct functions.
Would you mind submitting a copy of your pinballx.ini and log.txt files so that others and the author can take a look at your settings in the event this is a bug?
It may also be beneficial to know what kind of controller or panel setup you are using, including if using an IPAC or similar. Thanks!
