Lo peeps. I've seen some posts similar to this one, but not quite the same (I think).
I have Space Ace running perfectly through Daphne, but Dragons Lair keeps giving me errors.
--DAPHNE version 0.99.6
--Command line is: F:\Documents and Settings\JohnnyG\Desktop\Daphne 99.6\daphne.exe seektest vldp -preset 0 -framefile F:\Daphne 99.6\Framefile.txt -fullscreen -bank 0 11111101 -bank 1 10110111 -nohwaccel -nocrc
--CPU : AuthenticAMD 1950 MHz || Mem : 1024 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce4 Ti 4800 SE
ERROR: The ability to set bank values is not supported in this game.
Disabling ROM CRC check...
Really annoying me now.
The Daphne loader I have for Space Ace is Build 130, from 2005, but it only lists Space Ace as games. How can I add Dragons Lair to it to get them both running?
In GameEx, I set the paths correctly (I think) in the config screen, but it bombs out to a black screen when I try to run Space Ace (but a Windows error box appears for a sec as that happens).
I have great plans for a Mame cabinet, and even SHe Who Must Be Obeyed has given permission for me to build it. Please, can somone help me out so I can build the Mame cab of my dreams?
By the way, many congrats to Tom on a brilliant front end. GameEx finally convinced me to build a cab, and GameEx will be the GUI for me. Simple to use, but very configurable; as soon as my cheque clears next month I'll be donating.
PPS: I found GameEx to be quite slow using the default theme, since I switched to the Tron theme, it's flying! Hope that might help somebody.
Cheers
Cheers
I am having the same issue..hang on..someone will come to our aid!
Cheers
Post your GameEx.ini and ill try and correct it for you, or remove this from your options:
Hi Tom,
I'm not being wilfully stupid: where is my GameEx.ini file, I can't find it?
I've had a rummage around in Daphne and managed to add Dragons Lair as a game name to the newer Daphne loader in Space Ace, but the error keeps coming back up. I don't know how to remove that from options: I can make it display the command line before it runs, but even when I delete it, it comes back every launch. BTW, I forgot just how hard the old arcade games were, and Space Ace is rock!
Thanks for the help,
Johnny
Hi Tom,
Johnny
c:\program files\gameex\config\gameex.ini
Cheers Tom,
[General]
# The Resolution to display GameEx in. Most resolutions are supported.
# If a Y resolution of 479 or below GameEx automaticaly goes into
# ArcadeMode and displays smaller text,and is less graphical.
# For ArcadeVGA set this to 640 X 288
XResolution=640
YResolution=480
# If you have a dual display setup, the next option allows you to run
# GameEx on the Secondary Display. Default is false.
DisplayOnSecondary=False
# The following settings are for launching programs on startup on exit of GameEx.
# The NoWait settings wait for the application to close before resuming execution.
# The other two settings run asynchronously with GameEx, and GameEx wont wait for
# them to Exit. LaunchOnStart fires up pretty much immeidatly when GameEx Starts
# and before it initialises audio, graphics or the gameEx interface.
# The Launch on Exit are the 'Last' things Gameex does.
# Make sure these settings are blank if you do not wish to use them
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
# The path where Mame is located
MAMEPath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32
# The Mame.exe executable file
# Both Windows and DOS versions are supported (DOS only on Windows 98/ME)
MAMEEXE=Mame32.exe
# The path to your MAME roms
# Multiple ROM paths can be entered, seperate with semicolons.
ROMPATH=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\roms
# Put 'START /WAIT ' before the MAME executable in the command line.
# This is required if running MAME32 On Windows 98/ME only.
# Otherwise set to False.
StartWait=False
# Whether to use AdvanceMame for launching ROMS. You will still need
# a valid version of Windows MAME or MAME32 and specify it above.
# This is required for generating the game list. However if you set
# UseAdvanceMAME to true The EXE and path below will be used for launching
# games. Be sure to setup Your advmame.rc file, or use the
# AdvanceMAMEOptions
# Both Windows and DOS version are supported. DOS only on Win 98/ME
# NOTE: Dont use the -sound_volume option in AdvanceMAMEOptions
# as attract mode uses it.
# Note: AdvanceMAMEPath should not include the EXE,
# just the full path to where AdvanceMAME is located. Specify the EXE
# in AdvanceMAMEExe
UseAdvanceMAME=False
AdvanceMAMEExe=advmame.exe
AdvanceMAMEPAth=G:\MAME32
AdvanceMameOptions=-device_video_output fullscreen -dir_rom "G:\-DATA-\-MAME ROMS-"
# The following settings are used if you wish to use the Zinc Emulator
# (http://www.emuhype.com/)
# for launching games based on the 3D SONY Playstation
# hardware instead of MAME.
# The Zinc Emulator runs these games much better than MAME, and most
# will run full speed with full sound on modern hardware.
# Zinc use should appear seemless in GameEx
# and the games will appear as normal in the lists. The game has to be at
# least partially supported by MAME, to appear in the list, and the ROMS
# must be in the MAME ROM Directory specified above.
# Therefore don't specify the --roms-directory option in ZincOptions.
# Note: ZincPath should not include the EXE, just the full path to where
# Zinc is located. Specify the EXE in ZincEXE.
UseZinc=False
ZincEXE=zinc.exe
ZincPath=G:\ZINC
ZincOptions=--renderer=.\renderer.znc
# The font to use
# Verdana is recommended for Arcade Cab setups. Trebuchet MS is recommended
# for Media Center setup - and set DisplayBackgroundImage to true,
# Outline Fonts False
FONT=Trebuchet MS
# The text that displays at the top of the screen when not in arcademode
TitleText=MAME Games
# Only list MAME games where the driver is known to be fully working.
# In addition AllowImperfect allows a driver status of "IMPERFECT" to
# pass as working. In newer versions of MAME, games such as Galaga have
# a Driver Status as IMPERFECT although run very well. Set AllowImperfect
# to True to allow these games not to be filtered when OnlyWorking is set
# to True. Default for AllowImperfect is True
OnlyWorking=False
AllowImperfect=False
# Verify your MAME roms, and don't include if bad. This makes updating the
# game list slow.
VerifyRoms=False
# Only list MAME games that you have on your hard disk rom directory.
OnlyRoms=True
# Dont Display game Version (Bracketed) info in the game list.
# For example if set to true '720 Degrees (rev 1)' Will appear in the
# list as '720 Degrees'. This is useful if running at a low resolution,
# as text won't get truncated. Use in conjuction with NoClones=True, to
# create a very clean looking list.
NoGameInfo=True
# Apply a filter to the MAME game list. Seperate words to filter on with
# a semi colan. Any game name descriptions that contain these words will
# not be shown in the game list if the GameFilterOn setting is enabled.
GameFilter=Japan;Korea;Asia;Hispanic;bootleg;french;german;hack;prototype; hardware
GameFilterOn=True
# The following option when set to True will NOT add Adult Games to the
# list, and these games will not be available from the front end after
# doing an update list. Default is false
NoAdult=True
# Don't add clones to the list if True. Default is false.
# Use in conjuction with NoGameInfo=True to
NoClones=1
# Command Line options for when launching MAME.
# Tip if running on Media Center and on a widescreen TV,
# set '-resolution widthXheight' to your preffered widescreen resolution.
# It's also a good idea to set '-effect sharp' especially if
# using ArcadeVGA
MameOptions=-triplebuffer -nowindow -joy
# Turn ArcadeMode on even if displaying at a suitable resolution
ArcadeMode=True
# Font Size
# -1 = Smaller
# 0 = Normal
# 1 = Bigger
FontSize=0
# Location to your snapshots for MAME. JPG and PNG are supported
# You can also specify a ZIP file containing the images
snappath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\snap
# AVISnapPath. The folowing settings allow you to play videos in place of
# snapshots. Specify the path of the AVI files. If an avi file is found
# for a ROM it will be played instead of showing the snap.
# Go to http://tomspeirs.com/gameex for information on
# where to get game videos for MAME
AVISnapPath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\Mame Intro Vids
# AVI's are a little slow if played every frame. Set the following to
# only update the video every n screen updates. Default is 5.
AVIFrameSkip=0
# Location of Flyer Images. JPG and PNG are supported
flyerpath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\flyers
# Location of Cabinet Images. JPG and PNG are supported.
cabinetpath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\cabinets
# Location of Catver.ini (www.catver.com & www.mameworld.com/catlist)
# Which provides game category information for your MAME games
CatverLocation=\DATA\catver.ini
# Location of nplayers.ini (http://nplayers.arcadebelgium.be)
# Which provides GameEx with a list of MAME multiplayer Simultaneous games.
# A list that only contains MAME multiplayer Simultaneous games is only
# available if EnableStartPage is set to True. Default is data\nplayers.ini
nplayerslocation=\DATA\nplayers.ini
# Location of History.dat (www.arcade-history.com)
# Which provides game description information (where available)
# for your MAME games. Default is DATA\history.dat
HistoryLocation=\DATA\history.dat
# Location of MameInfo.dat (www.mameworld.net/mameinfo)
# Which provides game recommended games information (where available)
# for your MAME games. Default is DATA\mameinfo.dat
InfoLocation=\DATA\mameinfo.dat
# Show Game Information Page after selecting a game. True or False.
# If not set to true, game will launch straight away, otherwise game
# information and recommended games will display. Recommended Games
# are selectable, and playable. The Game info page will also allow you to
# view a games flyer and cabinet image.
# If set to true, GameEx will use MAMEInfo.dat and History.dat when updating
# The game list. The default is True
ShowGameInfoPage=True
# Enable Start Page. Setting the following setting to True will enable the
# Start page. If configured you can select other
# Emulators and game lists from this start page. There are also options
# To restart and shutdown the PC (If DisableExit is not on).
# If set to false, GameEx will resort back to being MAME only, and display
# the last used list. Default is True
EnableStartPage=True
# If EnableStartPage is set to True, the following setting determines if the
# Start Page is shown first after launching GameEx, or whether the last used
# list is shown. Set ShowStartPageFirst to True to always show the Start
# Page first if the Start Page is enabled. Set the setting to False, to
# show the last used list after launching GameEx. The default is True
ShowStartPageFirst=False
# Skip the Intro animation. True or false
skipintro=False
# AntiAlias Fonts. Looks nice at higher resolutions
# This is automatically set to false if ArcadeMode is on, or resolution is
# less than 640 x 480
AntiAliasFonts=True
# Outline fonts. Puts a black edge around the fonts used. Deffinitly
# recommended for an Arcade Monitor.
OutlineFonts=False
# Display Background image. If set to True displays a Blue gradiented image
# in the background. Looks nice, on a PC or TV,
# This also makes GameEx look similar to Windows Media Center.
# set this to DisplayBackgroundImage=snap, to make Snap images the
# background and make the backgrounds of the menus transparent.
# Set to false to display a Black background.
DisplayBackgroundImage=True
# Snap/Image Brightness. If DisplayBackground is set to snap, then
# this next value controls the screen brightness of the images displayed.
# Enter a value 0 - 255
SnapBrightness=140
# Music Playlist file. MP3 and OGG files are supported.
# The file should be a simple list of file locations to audio files.
# Do not surround the paths in the file with quotes.
# You can also specify a directory here, and on startup GameEx will scan
# this directory and all sub directories for compatible audio files.
# If you choose a directory, GameEx will generate a playlist file for you
# and you can then use this to save future startup time once it is created.
# It is created in the GameEx\Data directory and called playlist.txt.
# MusicPlayList=L:\-DATA-\-MP3-\
MusicPlayList=C:\Documents and Settings\TSpeirs\My Documents\My Music
# Volume Level of music playback 0 - 100
MusicVolume=20
# Media Center Exit & Start Mode. If running on Windows XP Media Center
# Handles how Media Center is exited from and restarted. Media Center will
# not launch on exit if not open when GameEx is launched.
# Values supported are:
# 0:
# No Media Center use or interaction. In other words
# Your not using Windows XP Media Center
# 1:
# Send Pause Command to Media Center when Launching GameEx, and send
# Play Command when exiting GameEx. this will Pause Live TV, or pause any
# Radio or Music Playing. This also Takes Media Center back to the start
# page. If using 1 then set the -noswitchbpp in the MAME options, as
# Media Center does not like running below 32 bit colour. There are a few
# Issues with this mode. If you have problems, use mode 2.
# 2:
# Close Windows Media Center completely before running GameEx. Then launch
# Again when exiting GameEx
MediaCenterMode=0
# Plays Intro Sound on Startup
PlayIntroSound=True
# Attract Mode ScreenSaver. Timer to wait for Attract Mode screensaver in
# minutes if no interface input. If the timer is reached, attract mode
# starts and runs a random game every couple of minutes.
# set to 0 to disable. Default is 4 minutes
AttractModeTimer=3
# Attract Mode Audio. Controls what audio is heard when Attract Mode
# is running. Default is 2.
# 0:
# Play GameEx playlist audio and run MAME with sound
# 1:
# Pause playlist audio and run MAME with sound
# 2:
# Play GameEx Playlist audio and run MAME with no sound
# 3:
# Pause GameEx Playlist audio and run MAME with no sound
AttractModeAudio =1
# ArcadeVGA Resolution Settings. If using an ArcadeVGA card from Ultimarc,
# The following settings can be used to automatically run games at the
# best resolutions. Set UsingArcadeVGA to true if using an ArcadeVGA card.
# Set StrechResToX and StretchResToY to the resolution to
# stretch games to if a game runs at a height above 288, or would display
# interlaced. Set TryToStretchTo256 to try and find a
# resolution with a height of 256 first before
# using the StretchResToX/Y resolution, and stretch to
# ResToX/Y only if a resolution above 256 is found.
# If your Arcade Monitor rolls, or significantly stretches with a resoluton
# height of 288, set TryToStretchto256 True. If your Monitor
# supports a resolution of 288 then set StretchResTox/Y
# to 640 x 288 and TryToStretchto256 off, ortherwise use 632 x 264 or a 256
# Y Resolution and turn TryToStretchto256 on.
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
# Normally GameEx waits for a vertical Sync of the display before drawing
# to the screen. This should offer smooth animation on fast PC's, and is
# normally recommended. Although Waiting for a VSync takes up CPU cycles.
# It may also be a little pointless to wait for a Vsync on older PC's where
# GameEx runs slowly anyway. Setting NoWaitVSync to true will make GameEx
# Update the screen whenever it can, and may make GameEx run a little
# faster. Also if used in conjuction with Sleep, you can claim back more
# CPU cycles from GameEx.
NoWaitVSync=True
# If you have critical processes running at the same time as GameEx, such
# as TV/Video Capture/Encoding, you can specify a value for Sleep in
# Milliseconds, and GameEx will give this time back to the CPU just before
# updating the screen. A value of 0 disables this setting and is the default.
# If you feel you must use this setting, a value no higher than 20 is
# recommended, otherwise you will really start to see a slow down of GameEx.
# Default is 0.
Sleep=0
# The following three options are mainly for Arcade Cabinets running in
# Public
# or Commercial places, or where children have access. When set to true
# HideUpdateList hides and disables the Update List button in GameEx, and
# DisableExit disables exiting from GameEx, and hides the shutdown button
# on the Start Page. If this last option is set
# to True the only way to exit GameEx will be to use CTRL-ALT-DELETE, or
# Shut down/Restart the PC. If you wish to be able to exit from GameEx,
# But not allow shutting down of the PC from the Start Page, then set
# HideShutDown to True
# Default for all three is False.
# DisableEscape disables exiting of GameEx with the Escape Key.
# DisableRemoveGame turns off the
# ability to remove games from lists
# with the delete key
HideUpdateList=True
DisableExit=False
HideShutDown=True
DisableEscape=True
DisableRemoveGame=False
# Specify a Video to play at Startup. AVI, MPG:
StartupVideo=g:\Mame32\mame_videos_shrunk\
Theme=Default - Tron
Language=English
FlatStartPage=True
DontSwitchRes=False
SnapDelay=3
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=True
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=False
JukeBoxPlaylist=
EnableMediaControls=False
ShufflePlayLists=False
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=False
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=2
DoNotFilterROMS=*(U)*.zip;*(E)*.zip
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=False
Marqueepath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\marquees
Panelpath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\cpanel
Titlepath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\titles
ICONpath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\icons
CPEnabled=True
CPPath=\data\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=False
ShowAdult=False
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=False
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=True
HideCreateSnaps=True
HideLogoff=True
HideStandBy=False
DisableMouse=True
ShowVideos=False
VideoPath=F:\-VIDEO-OLD-\OLD-STAR TREK TOS-;V:\;D:\-VIDEO-;E:\;F:\;L:\;c:\;d:\;G:\KARAOKE TEST;T:\
EnableAlphaPage=True
EnableJoystick=False
EnableSlikStik=False
KeyboardDirectInput=True
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
AttractVideosRatio=1
AttractVideosPath=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32\Mame Intro Vids
AtractModeNewGameTimer=2
AdvancedGFX=False
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=2
AmbienceFile=L:\-DATA-\-MP3-\4 Non Blondes\4 Non Blondes - What's Up.mp3
AmbianceFile=F:\Documents and Settings\JohnnyG\Desktop\New mame\Arcade ambience\arcade86.mp3
EnableAmbiance=True
HIDEDESKTOP=False
UseSnapBestMatch=False
IngameVK=76
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=False
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=True
ShowAtari=False
ShowGolden=True
[Daphne]
# (http://www.daphne-emu.com/)
# Daphne is a an arcade Laserdisc emulator, that allows playing of
# games such as Dragon's Lair and Space Ace.
# The following options enable GameEx to act as a Daphne front end
# and presents a list of Daphne games that can be selected from the Start
# Page. DaphnePath, and DapnheSnaps should contain the full path to where
# the Daphne ExE is located (path only), and the path to snaps to use.
# Daphne EXE is the daphne executable file (without the path).
# DaphneSnap is the location of Snap Images
# DapnheOptions are the global command line options applicable to all games.
# Set UseDapnhe to true to enable Daphne support in GameEx
UseDaphne=True
DaphnePath=F:\Space Ace
DaphneExe=Daphne.exe
DaphneSnap=F:\Documents and Settings\JohnnyG\Desktop\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
# Set up the following options for each Daphne Game. Suffix the end of the
# option with an underscore and a number between one and 30. With Each
# game having a seperate number.
# ROMName is the ROM filename
# GameName is the friendly name shown in the GameEx list
# GameOptions are the specific command line options for each game
# Enabled is true or false and whether the game will appear in the list.
Enabled_1 =True
ROMName_1 =lair
GameName_1 =Dragons Lair
GameOptions_1 =-framefile F:\Documents and Settings\JohnnyG\Desktop\Daphne 99.6\FramefileDRAGONSLAIR.txt
Enabled_2=True
ROMName_2 =sae
GameName_2 =Space Ace
GameOptions_2 =-framefile F:\Space Ace\framefile.txt
Enabled_3=False
ROMName_3 =astron
GameName_3 =Astron Belt
GameOptions_3 =-framefile j:\daphne\mpeg\abelt_framefile.txt
Enabled_4=False
ROMName_4 =cliff
GameName_4 =Cliff Hanger
GameOptions_4 =-framefile j:\daphne\mpeg\cliff_framefile.txt
Enabled_5=False
ROMName_5 =cobraab
GameName_5 =Cobra Command
GameOptions_5 =-framefile j:\daphne\mpeg\cc_framefile.txt
Enabled_6=False
ROMName_6=cobraab
GameName_6=Cobra Command
GameOptions_6=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_7=False
ROMName_7=cobraab
GameName_7=Cobra Command
GameOptions_7=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_8=False
ROMName_8=cobraab
GameName_8=Cobra Command
GameOptions_8=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_9=False
ROMName_9=cobraab
GameName_9=Cobra Command
GameOptions_9=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_10=False
ROMName_10=cobraab
GameName_10=Cobra Command
GameOptions_10=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_11=False
ROMName_11=cobraab
GameName_11=Cobra Command
GameOptions_11=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_12=False
ROMName_12=cobraab
GameName_12=Cobra Command
GameOptions_12=-framefile h:\daphne\mpeg\cc_framefile.txt
GameName_23=
Enabled_13=False
ROMName_13=
GameName_13=
GameOptions_13=
Enabled_14=False
ROMName_14=
GameName_14=
GameOptions_14=
Enabled_15=False
ROMName_15=
GameName_15=
GameOptions_15=
Enabled_16=False
ROMName_16=
GameName_16=
GameOptions_16=
Enabled_17=False
ROMName_17=
GameName_17=
GameOptions_17=
Enabled_18=False
ROMName_18=
GameName_18=
GameOptions_18=
Enabled_19=False
ROMName_19=
GameName_19=
GameOptions_19=
Enabled_20=False
ROMName_20=
GameName_20=
GameOptions_20=
Enabled_21=False
ROMName_21=
GameName_21=
GameOptions_21=
Enabled_22=False
ROMName_22=
GameName_22=
GameOptions_22=
Enabled_23=False
ROMName_23=
GameOptions_23=
DaphneFlyer=F:\Space Ace\images
DaphneCabinet=F:\Space Ace\images
DaphneTitle=F:\Space Ace\images
DaphneMarquee=F:\Space Ace\images
DaphnePanel=F:\Space Ace\images
UseGamepad=False
[internal]
# These settings are used internally by GameEx
# They are used to do things such as remember where you were upto in lists
# and the Current Playlist position.
# It is recommended you do not change anything here.
PlayListPosition= 0
SelectedGame= 148
GameListTop= 129
GameListType= 0
YearListTop= 1
CatListTop= 1
ManuListTop= 1
YearSelectedGame= 1
CatSelectedGame= 1
ManuSelectedGame= 1
NameListTop= 129
NameSelectedGame= 148
Emulator= 1000
VideoAspect=0
csv=F:\Program Files\GameEx\config\config.csv
ini=F:\Program Files\GameEx\config\gameex.ini
ControlHeight=34
ControlSpacing=8
FontSize=17
CSVType=comma
nextaction=onepage
Windowed=False
windowx=75
windowy=44
windowwidth=640
windowheight=480
CurrentStation=
CurrentStationURL=
MAMEEXE=
MAMEPATH=F:\Documents and Settings\JohnnyG\Desktop\New mame\Mame32
ExtenderCapable=0.1
CatFilter=
ManuFilter=
YearFilter=
ROMName=blktiger
ROMName2=blktiger
SpecialFilter=FAV
[DVD]
EnableDVD=False
Codec=0
DVDFFDSHOW=1
EnableDVDDisk=False
DVDPath=G:\DVD's
[Pictures]
PicturesEnabled=True
Paths=c:\;g:\;a:\;d:\;e:\;F:\Documents and Settings\JohnnyG\My Documents\My Pictures
UseAlphaBlend=True
SlideDuration=12
[News]
Enabled=False
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=http://www.mameworld.net/mt/index.xml
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=http://www.penny-arcade.com/RSS.xml
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://blog.seanalexander.com/SyndicationService.asmx/GetRssCategory?categoryName=XP%20Media%20Center
URL_8=http://www.mediacenterpcworld.com/news_rss.xml
URL_9=http://msdn.microsoft.com/rss.xml
URL_10=http://www.mameworld.net/maws/mawshof.xml
URL_11=
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
[Radio]
RadioEnabled=False
Enabled_5=False
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=False
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=False
Name_22=Slay Radio
URL_22=http://relay.slayradio.org:8000/listen.pls
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=False
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=False
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=False
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=False
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=False
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=False
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=False
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=False
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=False
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=False
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=False
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Enabled_24=
[htmlApplications]
UseHTMLApps=False
Enabled_1=True
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
[ExternalApplications]
Enabled_99=False
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=
path_1=
cmd_1=
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
[Emulator_1]
Enabled=False
StartPageName=Nintendo 64 Games
TitleText=N64
StartPageLogo=n64
RomFilter=*.zip
RomsInFolders=False
ROMPath=G:\-DATA-\-ROMS-\N64GOOD
SnapPath=D:\BitTorrent-Downloads\EmuMovies N64 AVI Game Previews for Mamewah
WorkingPath=G:\project64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=False
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=C:\Program Files\OfflineList0.7\datas\n64_OL.zip
Command=Project64.exe [ROMPath]\[RomFile]
TitlePath=
BoxPath=G:\zsnes\Boxscans_SNES_(USA)_28May04
LaunchBefore=
LaunchAfter=
CartPath=G:\zsnes\CartScans SNES USA
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=N64
Import=
Export=
[Emulator_2]
Enabled=False
StartPageName=Nintendo SNES games
TitleText=SNES
StartPageLogo=snes
RomFilter=*.zip
RomsInFolders=False
ROMPath=G:\-DATA-\-ROMS-\SNESRoms\GOOD
SnapPath=C:\Program Files\OfflineList0.7\imgs\SNES - Official OfflineList
WorkingPath=G:\ZSNES
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=C:\Program Files\OfflineList0.7\datas\snes_OL.zip
Command=Zsnesw.exe "[ROMPath]\[RomFile]"
TitlePath=G:\zsnes\titles
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=False
DATABASE=SNES
DumbyValue=
[Emulator_3]
Enabled=False
StartPageName=Pinball Games
TitleText=Pinball
StartPageLogo=pinball
RomFilter=*.vpt
RomsInFolders=False
ROMPath=G:\Pinball\Tables
SnapPath=
WorkingPath=G:\Pinball\Tables
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=[apppath]\vpauto.exe
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command=..\VPinball-XPFix4.exe -play -"[ROMFILE]"
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=Visual Pinball
ExcludedFiles=
CustomBackground=bak.avi
Import=
Export=
DumbyValue=
PlayMusic=
PCGame=
DATABASE=
[Emulator_4]
Enabled=False
StartPageName=Nintendo NES Games
TitleText=NES
StartPageLogo=nes
RomFilter=*.nes
RomsInFolders=False
ROMPath=G:\-DATA-\-ROMS-\NES ROMS
SnapPath=
WorkingPath=G:\ROCKNESX\
MapKeys=True
WaitBeforeKeys=3000
SendKeys=%{ENTER}
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=
OLDatZip=
Command=nesemu2.exe [ROMPath]\[RomFile]
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
Import=
Export=
DumbyValue=
[Emulator_5]
Enabled=False
StartPageName=PC Apps
TitleText=PC Apps
StartPageLogo=
RomFilter=*.lnk
RomsInFolders=False
ROMPath=C:\lnks
SnapPath=
WorkingPath=C:\lnks
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command="[ROMPath]\[RomFile]"
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
DumbyValue=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_6]
Enabled=False
STARTPAGENAME=PC Apps
TITLETEXT=PC Apps
StartPageLogo=
ROMFilter=*.lnk
RomsInFolders=False
RomPath=C:\lnks
SnapPath=
WorkingPath=C:\lnks
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=""[ROMPath]\[RomFile]""
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
[Emulator_9]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_10]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
[Emulator_11]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_12]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_13]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_14]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_15]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
[Emulator_16]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_17]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_18]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_19]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
[Emulator_20]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[TEXT]
Visualize=Visualize
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
playstation=Playstation
shutdown=Turn Off System
standby=Stand By System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
DVDonDiskStart=DVD's
DVDonDiskList=DVD's
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
QueueAll=Queue All
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
News=News
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select to Confim.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Theme Picker
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
[Emulator_21]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_22]
Enabled=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_23]
Enabled=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
CartPath=
LaunchBefore=
LaunchAfter=
configFile=Visual Pinball V2
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_24]
Enabled=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
CartPath=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_25]
Enabled=False
STARTPAGENAME=Nintendo 64 Games
TITLETEXT=N64
StartPageLogo=n64
ROMFilter=*.zip
RomsInFolders=False
RomPath=G:\-DATA-\-ROMS-\N64GOOD
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=False
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
TitlePath=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=N64
Import=
Export=
DumbyValue=
[Favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[DVRMS]
DVRFFDSHOW=0
CODEC=
[AtractModeNewGameTimer]
When in attract mode start a new random game or video each time this value is reached.=2
[AttractVideosPath]
The folder your videos are located.=L:\GameAds
[GameExTender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
ENABLED=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
PORT=8383
RefreshRate=20
[GameExtenderViewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
[Karaoke]
Enabled=False
Path=G:\KARAOKE TEST
Mode=True
[Emulator_7]
Enabled=False
DumbyValue=
STARTPAGENAME=Atari Games
TITLETEXT=Atari
StartPageLogo=Atari
ROMFilter=*.exe
RomsInFolders=False
RomPath=w:\Program Files\GameEx\GAMES\Atari\Games
SnapPath=w:\Program Files\GameEx\GAMES\Atari\Snaps
TitlePath=
BoxPath=
CartPath=
WorkingPath=w:\Program Files\GameEx\GAMES\Atari\Games
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=[RomFile]
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
[Emulator_8]
Enabled=False
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=False
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
