Hi Guys,
I'm building a minicabinet with a 1080p 23" monitor and a 17lcd as backglass.
I've installed the latest Pinballx 1.72 and with Future Pinball it works correctly (excepr for temporal desktop view during loading process..but this is OT for now) Visual Pinball doesn't load at all, and every time you choose a vp table Pinballx start to loading and exit with a not specified error.
This is part of the settings in Pinballx:
[FuturePinball]
WorkingPath=C:\Games\Future Pinball\BAM
TablePath=C:\Games\Future Pinball\Tables
Executable=FPLoader.exe
Parameters=/STAYINRAM/open "[TABLEPATH]\[TABLEFILE]" /play /exit
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeExecutable=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterExecutable=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=False
MouseClickFocus=True
FPRAMPath=C:\Games\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=C:\Games\vp2
TablePath=C:\Games\vp2\Tables
Executable=VPinball920.exe
NVRAMPath=C:\Games\VP\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
Where's the mistake?
Does starting Vpinball920.exe outside of PBX, and loading/starting a table work? Is your pinballx.exe and vpinball920.exe set to "Run as Administrator"?
I always had the nvram under my VP dir like this: NVRAMPath=D:\VPinball\VPinMAME\nvram
so I'm not sure if that is the issue.
Here is the sample from the PBX documentation:
[VisualPinball]
WorkingPath=D:\VPinball
TablePath=D:\VPinball\Tables
Executable=VPinball.exe
LaunchBeforeEnabled=False
LaunchAfterEnabled=True
LaunchAfterWorkingPath=D:\PinballX\Scripts
LaunchAfterExecutable=ledset.bat
LaunchAfterHideWindow=True
LaunchAfterParameters=
Z
Also, does the table name under c:\Games\vp2\Tables match the name in your visual pinball .xml file?
Z
Vpinball920.exe works perfectly and run as administrator but when loaded in pinballx crashes.. but what do you mean with match the name in my visual pinball XML?
I think that XML is created by the game manager integrated in pinballx.. am I wrong?
The name of the Tables in the Game Manager have match the Filename of the Table (without the vpt extension).
This as nothing to do with the crash, but: Is it correct, that your nvram folder is in another VP folder?
And what about the Filenames?
Just like zeenon and I said: The Game Name in the Game Manager must be exactly the same as the Filename without extension!
The filename in the XML is ok, same name w/o the .vpt
I've tried to reinstall PinballX and configured only VP...it runs perfectly
But when I've added Future Pinball is born another problem, Now FP load tables (loading screen is not visible and there's only a white screen) and when I exit the table by pressing ESC PinballX minimize itself in the Taskbar....only with mouse I can re-enter on pinballx interface.
It's possible that Pinballx doesn't support FP+VP?
