[RESOLVED] MS Console Based Script Host has stopped working
Wonder if anyone can help with this error message I am getting when I exit a game under VP 9.16, also happens on VP 9.15.
"MS Console Based Script Host has stopped working"
Seems to happen on all tables that use ledwiz, tables that don't are fine.
Likely to be my fault as I have just added a new ledwiz device as I blew my old one & at this point I cannot get it to work but worth a post here in case anyone else has seen this error message?
Oh, using the latest version of PinballX that I downloaded yesterday.
Bumping this with an update.
I'm still getting the error message
""MS Console Based Script Host has stopped working""
It happens when I start a game & when I end a game.
Clicking OK on the message box gets rid of it & the game plays fine, any ideas anyone?
If you are encountering an error with PinballX, please provide copies of your pinballx.ini and log.txt files, and also provide any pertinent information, such as OS and any codecs installed. This helps the author facilitate a quicker fix for issues being reported. Thank you.
Sorry should have provided that at the start.
The problem started when I installed the Direct Output Framework for Ledwiz.
Had hell of a job getting that working, now it is all working fine I still get the
As said I can click around it?
PinballX.ini
[Display]
Monitor=0
rotate=270
Windowed=False
windowwidth=752
windowheight=645
windowx=2034
windowy=-38
PlayFieldBrightness=200
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
[backGlass]
monitor=1
x=0
y=0
width=1360
height=768
[DMD]
monitor=2
x=5
y=0
width=625
height=200
[interface]
DesktopModeEnabled=False
[Audio]
StreamVolume=30
SampleVolume=30
[startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=160
right=161
select=49
rotate=82
pageleft=162
pageright=163
exitemulator=27
ingame=32
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
WorkingPath=C:\Pinball Software\Future Pinball\BAM
TablePath=C:\Pinball Software\Future Pinball\Tables
Executable=FPLoader.exe
Parameters=Parameters=RunWait, /STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender,,hide UseErrorLevel
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Pinball Software\Visual Pinball
TablePath=C:\Pinball Software\Visual Pinball\Tables
Executable=VPinball.exe
LaunchBeforeEnabled=False
LaunchBeforeWorkingPath=C:\Pinball Software\PinballX\LEDWiz
LaunchAfterEnabled=True
LaunchAfterWorkingPath=C:\Pinball Software\PinballX
LaunchAfterExecutable=ledset.bat
NVRAMPath=C:\Pinball Software\Visual Pinball\VPinMame\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=False
[startupProgram]
Paramaters=
HideWindow=False
WaitForExit=false
[ExitProgram]
Enabled=False
Executable=ledoff.bat
Paramaters=
HideWindow=True
WaitForExit=True
[AttractMode]
Enabled=False
Timer=1
ShowFor=15
[system_1]
Name=PinballFX2
WorkingPath=C:\Pinball Software\Steam
TablePath=C:\Pinball Software\Steam\userdata
Executable=PinballFX.exe
Parameters=
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=0
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=832,780
WindowLocation=128,50
[internal]
lastselected=Earthshaker (Willaims 1989)Earthshaker (Willaims 1989)VisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[FileSystem]
EnableFileMatching=True
[system_2]
Name=Jukebox
WorkingPath=D:\DWJukebox
TablePath=D:\My Music
Executable=wincab.exe
Log.txt
15:19:56.4 10/11/2013: PinballX - Version 1.62
15:19:56.4 10/11/2013: Loading Settings
15:19:56.4 10/11/2013: Launching Startup Program: ledset.bat
15:19:56.4 10/11/2013: C:\Pinball Software\PinballX\ledset.bat
15:19:56.4 10/11/2013: Initialize Component
15:19:56.5 10/11/2013: Initialize Display
15:19:56.7 10/11/2013: Created DirectX BackGlass Window
15:19:56.8 10/11/2013: Created DirectX DMD Window
15:19:56.9 10/11/2013: Hiding Cursor
15:19:56.9 10/11/2013: Hiding Taskbar
15:19:56.9 10/11/2013: Loading PlugIns
15:19:56.9 10/11/2013: Load Game List
15:19:56.9 10/11/2013: Loading Database: Future Pinball
15:19:56.9 10/11/2013: Loading Database: Visual Pinball
15:19:56.9 10/11/2013: Loading Database: PinballFX2
15:19:56.9 10/11/2013: Loading Custom Database: DW Jukebox
15:19:56.9 10/11/2013: Finding and matching artwork and videos
15:19:57.3 10/11/2013: Loading Game Statistics and Scores
15:19:58.4 10/11/2013: Initialize Audio
15:19:58.4 10/11/2013: Set Keyboard Controls
15:19:58.4 10/11/2013: Initialize Joystick
15:19:58.5 10/11/2013: 1 Joystick Attached
15:19:58.5 10/11/2013: Started
First off, you need to upgrade to the latest PinballX version (1.69 is the most recent). Not sure if it will help with the error you are describing but 1.62 support is deprecated with the release of the later versions.
Upgraded to the latest version but no change, same error message.
I guess a total un-install of PinballX is called for followed by a rapid re-install.
What should I back up so I don't have to re-do all my set up again?
If you download the installer and run it you should be fine, it will only overwrite the actual program files, but should leave the other files intact. You should probably backup the contents of your pinballx folder as a precaution.
I meant a total un-install & re-install of PinballX, just need to back up my game manager settings.
Solved it, so if anyone else should come across the same problem.
I had previously set up a couple of batch files to clear the Leds upon start & exit. Stopping PinballX from running these got rid of my error message.
So simple in the end...
