Hi.
I´m trying to create a theme for GameEx, but I´d a problem. I want to leave the horizontal menu, but crop it to a certain zone of the screen. I can resize it via notepad, or entering size manually in theme editor. For example, if the screen width is 1920, I want the menu width to be 1520. It appears in the correct zone, but when I move through it, the letters flows outside the defined zone, over the other elements. There´s any way to make it displace only in it defined zone, and hidden when outside his zone?
Thanks for the help.
If you are referring to the Menu Bar there is presently no way to crop this to where it doesn't extend past its dimensions. This is a known issue. Since a new theme engine and editor will be released sometime in the not too distant future, this may not be corrected in the current iteration.
Thanks for the answer. I´m going to wait to that new engine and editor :3
