2 Issues (Settings not updating, emus not loading)
Hi, I just jumped back into using GameEx recently and I'm having a bit of trouble setting things up.
Firstly, my settings made in the Setup Wizard don't seem to be reflected in GameEx. Instead, it seems to be creating (and loading from) a "VirtualStore" folder in my AppData. Deleting it forces it to go back to the Program Files version but only until I make more changes.
Second, whenever I launch a game, the screen goes black and doesn't even launch the emulator - moving my cursor around makes it sound like the GameEx UI is still there and selectable. My emulators work just fine outside of GameEx.
I've attached my log file, if that helps.
(Windows 8.1 Pro 64-bit, Intel Core i5, nVidia GTX660)
Am I correct in assuming you are not installing to c:\ but instead under Program Files? It has been my experience that things generally run better from the root. Also, would you mind providing a copy of your gameex.ini?
You might have permission issues if you install that way... Possible that you need to have the exe files run as administrator.
It's in root on purpose by default to avoid this.
