I tried copying the logos I made to the company logos folder, but I'm having some trouble.
Not all of the logos are displayed. For instance, I can now not see the Stern or Williams logos anymore. All tables and support files are correctly named. I just see the pinball icon when no logo is present. Is this a memory issue in that so many logos can't be loaded or something?
It does load them into memory so I put a hard limit on it. Although it should be a very high limit like 40 or something. How many do you have? It can be increased or I can go back to loading them dynamically again.
It will be in the next release but the attached supports up to 60 in total. Any more and I will have to go back to loading them dynamically. Not sure if that will max out some graphics cards. Let me know if you have any problems.
PinballX.7z
