I don't want to be annoying and not sure if I'm posting in the right place. But I'm running windows xp and I just bought gameex yesterday I was setting it up. And I got it all finished.
So I tried opening it and I get an error message-
GameEx has encountered a problem and needs to close. We are sorry for the inconvenience.
then askes if i want to send an error report.
Anyone know what's wrong?
Hey, Welcome to the forums.
When encountering a bug or error please post your log.txt and gameex.ini file, Information on this can be found here
This will enable us to assist you with your problem quicker.
You may want to download the latest version and install over your previous to see if it fixes your problem. If you get the error again after that, you may need to capture the details of the error report XP is generating in the event that a log.txt file is not even generating.
