hi
i just downloaded game ex but when i try to run it, i get an error saying directX error. its telling me to lower the resolution and ensure the required drivers are installed. i lowered the resolution but i know nothing about drivers or anything.
im useing an old notebook/laptop with an intel pentium 3 1.13GHz processor and 384Mb RAM if that helps.
any help will be greatly appreciated.
Sorry to hear you are having difficulties getting started. When reporting a possible GameEx bug orerror, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
Also, you may want to make sure that your laptop meets the following Minimum System Requirements:
Pentium 3 800Mhz CPU (or equivalent)
DirectX(DirectDraw) Compatible Video card, capable of 16 bit colour at 640X480.
[Your video card does not normally need to be too special unless using
videos or DVD, although older motherboard onboard video is not
recommended]
DirectSound Compatible Sound Card.
256MB Ram
Windows 2000 (SP4), XP (SP2), MCE, Vista, Windows 7
250MB Free hard drive space
Microsoft .net framework 2 service pack 1
Microsoft Direct X 9.0
Windows Media Player 9 or above
Some of these minimums have probably increased, especially regarding the .net framework. Not knowing what kind of laptop, its specs, and OS installed makes it difficult to advise you regarding how or where to look to find the most up to date drivers, so you will have to educate yourself a bit on how to do that.
thanks for the response.
so the log.txt is:
18:35:48.8 2/8/2013: Opening Configuration File
18:35:49.5 2/8/2013: GameEx: Version 13.09: Starting Log
18:35:49.5 2/8/2013: Operating System Platform: Win32NT
18:35:49.5 2/8/2013: Operating System Name: Windows XP
18:35:49.5 2/8/2013: Operating System Version: 5.1.2600
18:35:49.6 2/8/2013: Getting CPU and RAM info
18:35:49.6 2/8/2013: Intel® Pentium® III Mobile CPU 1133MHz, 383MB
18:35:49.6 2/8/2013: 1.13Ghz
18:35:49.6 2/8/2013: Running Randomize()
18:35:50.4 2/8/2013: Loading PlugIns
18:35:50.9 2/8/2013: Loaded Plugin:"Cursor Hider" Version 1.01 By Stu
18:35:51.3 2/8/2013: PlugIn: "Cursor Hider" Initialized OK
18:35:51.3 2/8/2013: Using Plugin System Version: 1.3
18:35:51.8 2/8/2013: Loaded Plugin:"Game Info Plugin" Version 1.1.6 By Adultery
18:35:53.0 2/8/2013: PlugIn: "Game Info Plugin" Initialized OK
18:35:53.0 2/8/2013: Using Plugin System Version: 1.4
18:35:53.2 2/8/2013: Loaded Plugin:"MAME Commander 2" Version 2.1.4 By Adultery
18:35:53.2 2/8/2013: PlugIn: "MAME Commander 2" Initialized OK
18:35:53.2 2/8/2013: Using Plugin System Version: 1.4
18:35:53.4 2/8/2013: Loaded Plugin:"Exit GameEx" Version 1.0 By Ben Baker
18:35:54.6 2/8/2013: PlugIn: "Exit GameEx" Initialized OK
18:35:54.6 2/8/2013: Using Plugin System Version: 1
18:35:54.9 2/8/2013: Loaded Plugin:"Speak Game Name" Version 1.41 By Tom Speirs
18:35:54.9 2/8/2013: PlugIn: "Speak Game Name" Initialized OK
18:35:54.9 2/8/2013: Using Plugin System Version: 1.4
18:35:54.9 2/8/2013: Loaded Plugin:"Random Arcade Sound" Version 1.11 By Tom Speirs
18:35:55.0 2/8/2013: PlugIn: "Random Arcade Sound" Initialized OK
18:35:55.0 2/8/2013: Using Plugin System Version: 1.4
18:35:55.0 2/8/2013: Checking for applications to Launch On Startup
18:35:55.0 2/8/2013: Setting default net connection limit to 15
18:35:55.0 2/8/2013: Running Misc startup tasks
18:35:55.0 2/8/2013: Setting Menu types
18:35:55.0 2/8/2013: Getting Configuration Values
18:35:55.0 2/8/2013: Using Theme: Default - Media Center - Background
18:35:55.0 2/8/2013: Checking for alternate Image Directory for Theme: Default - Media Center - Background
18:35:55.0 2/8/2013: Using Images from theme: Default - Media Center V1\MEDIA\
18:35:55.0 2/8/2013: Launching HideOS.exe
18:35:55.0 2/8/2013: Initialising Video/MNG DLL's
18:35:55.0 2/8/2013: GameEx will check for media insertion (may affect performance)
18:35:55.0 2/8/2013: Hiding Taskbar
18:35:55.4 2/8/2013: Is Media Center running?
18:35:55.4 2/8/2013: Checking/Creating LCD Registry values
18:35:55.6 2/8/2013: Check Media Center Exit/Start Mode
18:35:55.6 2/8/2013: Media Center Mode 2
18:35:55.6 2/8/2013: Video previews on. Warning: Only recommended on modern systems
18:35:55.7 2/8/2013: Snap Delay set to: 4
18:35:55.7 2/8/2013: Get other settings
18:35:55.8 2/8/2013: Desktop set to Hide ICONS and set Background to Black
18:35:55.8 2/8/2013: Set: Find emulator artwork on best match basis
18:35:55.8 2/8/2013: Start work for Form
18:35:55.9 2/8/2013: Getting Original Screen Size
18:35:56.0 2/8/2013: Opening Database Connection
18:35:58.6 2/8/2013: Initializing Component
18:35:59.2 2/8/2013: MAME Path is: C:\Emulators\Mame32
18:35:59.3 2/8/2013: Cannot Find MAME Path: MAME Disabled
18:35:59.3 2/8/2013: Loading Controls.ini map file
18:35:59.4 2/8/2013: Applying Language/Text
18:35:59.4 2/8/2013: Text/Language: English
18:35:59.4 2/8/2013: Loading Language/Text
18:35:59.6 2/8/2013: Loading Custom Emulators
18:35:59.6 2/8/2013: Loading Emulator 1: [Arcade] Arcade (MAME)
18:35:59.7 2/8/2013: Using Version 3 Themes Animations
18:35:59.7 2/8/2013: Retrieving resolution setting
18:35:59.8 2/8/2013: Using General Font: HandelGothic BT
18:35:59.8 2/8/2013: Using Title Font: HandelGothic BT
18:35:59.8 2/8/2013: GameEx will try to reduce CPU usage
18:35:59.8 2/8/2013: Initialising Direct3D
18:36:00.6 2/8/2013: Setting Resolution to 800x600 32 bit color
18:36:00.7 2/8/2013: Creating Surfaces
18:36:01.1 2/8/2013: Creating Primary Surface - Full Screen Mode
18:36:01.1 2/8/2013: Creating Back Buffer
18:36:01.1 2/8/2013: Loading graphic Surfaces
18:36:01.1 2/8/2013: Display is running at: 800x600 16bit color, 60hz
18:36:01.2 2/8/2013: Adapter: S3 Graphics SuperSavage/IXC 1014
18:36:01.2 2/8/2013: Max texture size: 2048x2048
18:36:01.2 2/8/2013: Available texture memory: 43MB
18:36:01.5 2/8/2013: --**--
18:36:01.5 2/8/2013: Error: Error in the application.
18:36:01.7 2/8/2013: at Microsoft.DirectX.Direct3D.Texture..ctor(Device device, Int32 width, Int32 height, Int32 numLevels, Usage usage, Format format, Pool pool)
18:36:01.7 2/8/2013: at Direct2D.Direct2d.Surface.CreateSpriteAndTextureIfNothing()
18:36:01.7 2/8/2013: at Direct2D.Direct2d.Surface.a(Bitmap& A_0, Device& A_1)
18:36:01.7 2/8/2013: at Direct2D.Direct2d.Surface..ctor(Bitmap Image, SurfaceDescription Description, Device Device)
18:36:01.7 2/8/2013: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
18:36:01.7 2/8/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1, Boolean A_2)
18:36:01.7 2/8/2013: at GameEx.GameEx.mainform.a(Boolean A_0, String A_1, Boolean A_2)
18:36:01.7 2/8/2013: at GameEx.GameEx.mainform..ctor()
18:36:01.7 2/8/2013: It was detected you experienced a DirectX error.
18:36:01.7 2/8/2013: Please note the following for possible solutions to your problem:
18:36:01.7 2/8/2013: 1. Ensure you have the latest version of DirectX installed.
18:36:01.7 2/8/2013: 2. Ensure you have the latest Manufacturer provided video card drivers.
18:36:01.7 2/8/2013: NOTE: Windows/Microsoft Update does not contain the latest.
18:36:01.7 2/8/2013: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
18:36:01.7 2/8/2013: www.ati.com www.nvidia.com
18:36:01.7 2/8/2013: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
18:36:01.7 2/8/2013: 4. Ensure any required video codecs are installed.
18:36:01.7 2/8/2013: 5. Try a different theme, or try running the theme at the resolution it was designed for
18:36:01.7 2/8/2013: 6. Try the latest version of GameEx. GameEx is updated all the time.
18:36:01.7 2/8/2013: 7. If you performed an auto update to this version. Try performing a manual download and install.
18:36:01.7 2/8/2013: Closing database connection
18:36:01.7 2/8/2013: Disposing Plugins
18:36:01.7 2/8/2013: GameEx is exiting with errors
18:36:02.3 2/8/2013: ERRORS DETECTED: EXITING
18:36:03.1 2/8/2013: Bye
and the GameEx.ini is: (i think this)
[General]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
MAMEPath=C:\Emulators\Mame32
MAMEEXE=Mame32.exe
ROMPath=C:\Emulators\Mame32\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=True
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
SnapPath=C:\Emulators\Mame32\snap
AVISnapPath=C:\Emulators\Mame32\avisnap
AVIFrameSkip=0
flyerpath=C:\Emulators\Mame32\flyers
cabinetpath=C:\Emulators\Mame32\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=C:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - Media Center - Background
Language=English
FlatStartPage=False
DontSwitchRes=True
SnapDelay=4
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=yes
ShellOnExit=yes
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
MarqueePath=C:\Emulators\Mame32\marquees
PanelPath=C:\Emulators\Mame32\cpanel
TitlePath=C:\Emulators\Mame32\titles
ICONPath=C:\Emulators\Mame32\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
AttractVideosRatio=1
AttractVideosPath=C:\Video
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=0
EnableAmbiance=True
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
AutoUpdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
ManualPath=C:\Emulators\Mame32\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=C:\Emulators\Mame32\pcb
ArtworkPath=C:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=True
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=\\Nasusa\music
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=C:\Emulators\Mame32\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=C:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=2
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=True
GameExtenderCustomImageMAMEPath=C:\Emulators\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=C:\Documents and Settings\All Users\Application Data
EnableEscapeKeyExit=True
DisableChangeView=False
EnabledConfigurationApp=True
ResumeLastAtStartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=C:\Emulators\Mame32\backgroundsnap
TVVideoPath=
OtherVideoPath=C:\Video;[myvideos]
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=True
EnableDownloadService=True
ShowCHD=True
RunFullScreenInWindow=true
SeekPreviewVideo=0
[Daphne]
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "R:\ARCADE\Daphne\vldp\astron\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "R:\ARCADE\Daphne\vldp\badlands\badlands.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "R:\ARCADE\Daphne\vldp\bega\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "R:\ARCADE\Daphne\vldp\cliff\cliff.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "R:\ARCADE\Daphne\vldp\cobra\cobra.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "R:\ARCADE\Daphne\lair_HD\lair_hd.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "R:\ARCADE\Daphne\vldp\lair2\lair2.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "R:\ARCADE\Daphne\vldp\esh\esh.txt"
Enabled_9=False
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "R:\ARCADE\Daphne\vldp\FireFox\firefox.txt"
Enabled_10=False
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "R:\ARCADE\Daphne\vldp\galaxyr\galaxyr.txt"
Enabled_12=False
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar
GameOptions_13=-framefile "R:\ARCADE\Daphne\vldp\interstellar\interstellar.txt"
Enabled_14=True
ROMName_14=gpworld
GameName_14=GP World
GameOptions_14=-framefile "R:\ARCADE\Daphne\vldp\gpworld\gpworld.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "R:\ARCADE\Daphne\vldp\mach3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "R:\ARCADE\Daphne\vldp\rb\rb.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "R:\ARCADE\Daphne\Space Ace HD\ace_hd.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "R:\ARCADE\Daphne\vldp\sdq\sdq.txt"
Enabled_19=False
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "R:\ARCADE\Daphne\vldp\tq\tq.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "R:\ARCADE\Daphne\vldp\uvt\uvt.txt"
UseGamepad=False
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marquees
DaphneBakSNAP=C:\Emulators\Daphne\backgroundimages
[DVD]
EnableDVD=True
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=True
DVDPath=C:\DVD
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD="C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uMCEPlayer6.exe" "[dvd]"
[Pictures]
PicturesEnabled=True
Paths=C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=12
[News]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[Radio]
RadioEnabled=True
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
http://relay4.slayradio.org:8000
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlApplications]
Enabled_1=True
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[ExternalApplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[TEXT]
TV=TV
SearchNetFlix=Search NetFlix
ByActor=By Actor
NetFlix=NetFlix
mameCHDlist=CHD
mameCHDstart=MAME CHD Games
steamlist=Steam
steamstart=Steam Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
ByArtist=By Artist
[Favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[DVRMS]
DVRFFDSHOW=0
CODEC=
[AtractModeNewGameTimer]
When in attract mode start a new random game or video each time this value is reached.=2
[AttractVideosPath]
The folder your videos are located.=L:\GameAds
[GameExTender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=MATRIXBK
Username=User33549
ComputerName=MATRIXBK-PC
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[GameExtenderViewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[Karaoke]
Path=C:\Karaoke
mode=False
[CachedImages]
bak=100652
res=0
videobak=100652
jukeboxbak=100652
radiobak=100652
picturesbak=100652
emubak=100652
startbak=100652
daphnebak=100652
mamebak=100652
themedir=
titlefont=Trebuchet MS
titlefontsize=0
outlinefonts=False
antialiasfonts=True
windowed=True
use16bitcolour=False
gradienttitlefont=True
lowercasetitlefont=True
Font=Trebuchet MS
FontSize=0
titlefontres=275808
bakres=0
theme=
startbak_Foreground=386810
videobak_Foreground=386810
jukeboxbak_Foreground=386810
radiobak_Foreground=386810
picturesbak_Foreground=386810
daphnebak_Foreground=386810
titlefontstyle=0
bakresbak=921600
mameselectbak=465213
lastplayedbak=290516
mostplayedbak=199198
favoritesbak=283065
allgamesbak=375154
emulatorselectbak=100444
themepickerbak=621253
[Plugin_1]
Name=CursorHider.dll
[Plugin_2]
Enabled=False
Name=DT Loader.dll
[Plugin_3]
Name=Game Info Plugin.dll
[Plugin_4]
Name=MAME Commander 2.dll
[Plugin_5]
Enabled=False
Name=PlugInCallerID.dll
[ArcadeSoundPlugin]
Volume=8
[Plugin_6]
Enabled=False
Name=PlugInDigDug.dll
[CachedImagesMenuFont]
themedir=\themes\Default - Media Center V1\MEDIA\
res=0
font=Trebuchet MS
fontsize=0
outlinefonts=False
antialiasfonts=True
windowed=True
menufontsamesize=True
fontstyle=1
[CachedImagesBak]
bak=214295
videobak=214295
jukeboxbak=214295
radiobak=214295
picturesbak=214295
emubak=214295
startbak=214295
daphnebak=214295
[Emulator_]
SelectionMusicFolder=C:\Music
[eBook]
Paths=C:\eBooks
Quality=0
fittopage=False
[Plugin_7]
Name=PlugInExit.dll
[MediaPlayer]
AudioMode=0
[CachedImagesGameFont]
res=275808
[CachedImagesGameFontFaded]
res=275808
[CachedImagesFontBlack]
Res=277056
[CPWizard]
CPWizardEnable=False
CPWizardPath=C:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
UseWMPWMV=
CMD=
[ADVKEYBOARD]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[Plugin_8]
Enabled=False
Name=PlugInLaunch.dll
[CursorHider]
DoNotHide=
DoNotHideInGameEX=False
[Plugin_9]
Enabled=False
Name=PlugInLCD.dll
[DefaultPaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[GameBase]
Path=
MapBack=False
ShowDesktop=True
[CachedImages3d]
titlefontres=275808
titlefontstyle=0
titlefontsize=0
outlinefonts=False
antialiasfonts=True
windowed=True
res=0
bakres=0
startbak_foreground=386810
theme=BlueBox
bak_foreground=39023
jukeboxbak_foreground=23206
[CachedImagesGameFontFadedFalse]
res=921600
[CachedImagesMenuFont3d]
res=0
[DVDRIP]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[GameExArcade]
[Touchscreen]
Touchscreen_Enabled=2
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[LastStatus]
specialfilter=EMU
oldspecialfilter=EMU
curemulator=12
listtype=20
curbak=EmulatorSelect
maxgames=28
gamename=
[Plugin_10]
Enabled=False
Name=PlugInRotate.dll
[Plugin_11]
Name=PlugInSpeech.dll
[list_SETTINGS_20_EMU_1002]
displaybackgroundimage=True
displaybackgroundimageemu=False
displaystartpagemenuimage=False
displaystartpagemenuimage2=False
displaystartpagelistnotforcebaksnap=True
displayimagelist=False
[list_SETTINGS_20_EMU_503]
displaybackgroundimage=Snap
displaystartpagelistnotforcebaksnap=False
displayimagelist=True
[steam]
LaunchBefore=
LaunchAfter=
[NetFlix]
[MappedDrives_1]
UNCPATH=\\Nasusa\roms_mint
Drive=R
[iNTERNAL]
CurrentStation=
VGenre=---
OPTIMIZED=0
[Emulator_1]
System=Arcade
Category=Arcade
Emulator=MAME
Version=0.145
Rating=8.4
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/mame.7z
RequiredFiles=
Website=http://mamedev.org/
Info=MAME stands for Multiple Arcade Machine Emulator. When used in conjunction with images of the original arcade game's ROM and disk data, MAME attempts to reproduce that game as faithfully as possible on a more modern general-purpose computer. MAME can currently emulate several thousand different classic arcade video games from the late 1970s through the modern era.
TitleText=Mame
StartPageName=[Arcade] Arcade (MAME)
StartPageLogo=MAME
Command=mame.exe [ROM] -rompath "[ROMPATH]"
RomFilter=
Database=
ConfigFile=[Mapping Off] Exit (Process Close)
MapFile=[APP]\Map Files\[Arcade] MAME.map
RomPath=C:\Roms\MAME\Roms
SnapPath=C:\Assets\MAME\Snaps
TitlePath=C:\Assets\MAME\Titles
BoxPath=C:\Assets\MAME\Boxes
CartPath=C:\Assets\MAME\Cartridges
ManualPath=C:\Assets\MAME\Manuals
ControlPanelPath=C:\Assets\MAME\Controls
WorkingPath=C:\Emulators\MAME
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
UseDbName=
GamesIn7Zips=
MergeSets=
PlayInScreenSaver=
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
[setupWizard]
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=0
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=3
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
ShowPanel=False
FontSize=1
WindowState=0
WindowSize=650,478
WindowLocation=75,46
[Plugin_12]
Enabled=False
Name=PlugInUltraStik.dll
[Plugin_13]
Name=RandomArcadeSound.dll
[Plugin_14]
Enabled=False
Name=Xpadder Plugin.dll
it does meet the minimum requirements but it is a laptop so the graphics card is probably built in? i dont know. so i really know nothing about the graphics or sound cardsin it.
if you need any more info just ask.
thanks for the help so far.
One thing to try right off. Open the gameex.ini and search for the word AdvancedGFX . You will likely see that the line is reading AdvancedGFX=True . Change True to False then save the changes. Load GameEx and see if there is any difference. Submit a new copy of the log.txt file if any errors. Thanks!
thanks but still no luck (although it did try to load for a bit longer this time)
the new log is:
19:41:51.6 2/8/2013: Opening Configuration File
19:41:52.2 2/8/2013: GameEx: Version 13.09: Starting Log
19:41:52.2 2/8/2013: Operating System Platform: Win32NT
19:41:52.2 2/8/2013: Operating System Name: Windows XP
19:41:52.2 2/8/2013: Operating System Version: 5.1.2600
19:41:52.2 2/8/2013: Getting CPU and RAM info
19:41:52.2 2/8/2013: Intel® Pentium® III Mobile CPU 1133MHz, 383MB
19:41:52.3 2/8/2013: 1.13Ghz
19:41:52.3 2/8/2013: Running Randomize()
19:41:53.0 2/8/2013: Loading PlugIns
19:41:53.6 2/8/2013: Loaded Plugin:"Cursor Hider" Version 1.01 By Stu
19:41:54.1 2/8/2013: PlugIn: "Cursor Hider" Initialized OK
19:41:54.1 2/8/2013: Using Plugin System Version: 1.3
19:41:54.7 2/8/2013: Loaded Plugin:"Game Info Plugin" Version 1.1.6 By Adultery
19:41:55.9 2/8/2013: PlugIn: "Game Info Plugin" Initialized OK
19:41:55.9 2/8/2013: Using Plugin System Version: 1.4
19:41:56.1 2/8/2013: Loaded Plugin:"MAME Commander 2" Version 2.1.4 By Adultery
19:41:56.1 2/8/2013: PlugIn: "MAME Commander 2" Initialized OK
19:41:56.1 2/8/2013: Using Plugin System Version: 1.4
19:41:56.2 2/8/2013: Loaded Plugin:"Exit GameEx" Version 1.0 By Ben Baker
19:41:57.3 2/8/2013: PlugIn: "Exit GameEx" Initialized OK
19:41:57.4 2/8/2013: Using Plugin System Version: 1
19:41:57.6 2/8/2013: Loaded Plugin:"Speak Game Name" Version 1.41 By Tom Speirs
19:41:57.6 2/8/2013: PlugIn: "Speak Game Name" Initialized OK
19:41:57.6 2/8/2013: Using Plugin System Version: 1.4
19:41:57.7 2/8/2013: Loaded Plugin:"Random Arcade Sound" Version 1.11 By Tom Speirs
19:41:57.7 2/8/2013: PlugIn: "Random Arcade Sound" Initialized OK
19:41:57.7 2/8/2013: Using Plugin System Version: 1.4
19:41:57.7 2/8/2013: Checking for applications to Launch On Startup
19:41:57.7 2/8/2013: Setting default net connection limit to 15
19:41:57.7 2/8/2013: Running Misc startup tasks
19:41:57.7 2/8/2013: Setting Menu types
19:41:57.7 2/8/2013: Getting Configuration Values
19:41:57.7 2/8/2013: Using Theme: Default - Media Center - Background
19:41:57.7 2/8/2013: Checking for alternate Image Directory for Theme: Default - Media Center - Background
19:41:57.7 2/8/2013: Using Images from theme: Default - Media Center V1\MEDIA\
19:41:57.7 2/8/2013: Launching HideOS.exe
19:41:57.7 2/8/2013: Initialising Video/MNG DLL's
19:41:57.7 2/8/2013: GameEx will check for media insertion (may affect performance)
19:41:57.7 2/8/2013: Hiding Taskbar
19:41:57.9 2/8/2013: Is Media Center running?
19:41:57.9 2/8/2013: Checking/Creating LCD Registry values
19:41:58.0 2/8/2013: Check Media Center Exit/Start Mode
19:41:58.0 2/8/2013: Media Center Mode 2
19:41:58.0 2/8/2013: Video previews on. Warning: Only recommended on modern systems
19:41:58.1 2/8/2013: Snap Delay set to: 4
19:41:58.1 2/8/2013: Get other settings
19:41:58.1 2/8/2013: Desktop set to Hide ICONS and set Background to Black
19:41:58.1 2/8/2013: Set: Find emulator artwork on best match basis
19:41:58.1 2/8/2013: Start work for Form
19:41:58.1 2/8/2013: Getting Original Screen Size
19:41:58.3 2/8/2013: Opening Database Connection
19:42:00.9 2/8/2013: Initializing Component
19:42:01.6 2/8/2013: MAME Path is: C:\Emulators\Mame32
19:42:01.6 2/8/2013: Cannot Find MAME Path: MAME Disabled
19:42:01.7 2/8/2013: Loading Controls.ini map file
19:42:01.8 2/8/2013: Applying Language/Text
19:42:01.8 2/8/2013: Text/Language: English
19:42:01.8 2/8/2013: Loading Language/Text
19:42:02.0 2/8/2013: Loading Custom Emulators
19:42:02.1 2/8/2013: Loading Emulator 1: [Arcade] Arcade (MAME)
19:42:02.1 2/8/2013: Using Version 3 Themes Animations
19:42:02.1 2/8/2013: Retrieving resolution setting
19:42:02.2 2/8/2013: Using General Font: HandelGothic BT
19:42:02.2 2/8/2013: Using Title Font: HandelGothic BT
19:42:02.2 2/8/2013: GameEx will try to reduce CPU usage
19:42:02.3 2/8/2013: Initialising Direct3D
19:42:03.2 2/8/2013: Setting Resolution to 800x600 32 bit color
19:42:03.2 2/8/2013: Creating Surfaces
19:42:03.7 2/8/2013: Creating Primary Surface - Full Screen Mode
19:42:03.7 2/8/2013: Creating Back Buffer
19:42:03.7 2/8/2013: Loading graphic Surfaces
19:42:03.7 2/8/2013: Display is running at: 800x600 16bit color, 60hz
19:42:03.8 2/8/2013: Adapter: S3 Graphics SuperSavage/IXC 1014
19:42:03.8 2/8/2013: Max texture size: 2048x2048
19:42:03.8 2/8/2013: Available texture memory: 43MB
19:42:04.1 2/8/2013: --**--
19:42:04.1 2/8/2013: Error: Error in the application.
19:42:04.2 2/8/2013: at Microsoft.DirectX.Direct3D.Texture..ctor(Device device, Int32 width, Int32 height, Int32 numLevels, Usage usage, Format format, Pool pool)
19:42:04.2 2/8/2013: at Direct2D.Direct2d.Surface.CreateSpriteAndTextureIfNothing()
19:42:04.2 2/8/2013: at Direct2D.Direct2d.Surface.a(Bitmap& A_0, Device& A_1)
19:42:04.2 2/8/2013: at Direct2D.Direct2d.Surface..ctor(Bitmap Image, SurfaceDescription Description, Device Device)
19:42:04.2 2/8/2013: at GameEx.GameEx.mainform.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
19:42:04.2 2/8/2013: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1, Boolean A_2)
19:42:04.2 2/8/2013: at GameEx.GameEx.mainform.a(Boolean A_0, String A_1, Boolean A_2)
19:42:04.2 2/8/2013: at GameEx.GameEx.mainform..ctor()
19:42:04.2 2/8/2013: It was detected you experienced a DirectX error.
19:42:04.2 2/8/2013: Please note the following for possible solutions to your problem:
19:42:04.2 2/8/2013: 1. Ensure you have the latest version of DirectX installed.
19:42:04.2 2/8/2013: 2. Ensure you have the latest Manufacturer provided video card drivers.
19:42:04.2 2/8/2013: NOTE: Windows/Microsoft Update does not contain the latest.
19:42:04.2 2/8/2013: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
19:42:04.2 2/8/2013: www.ati.com www.nvidia.com
19:42:04.2 2/8/2013: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
19:42:04.2 2/8/2013: 4. Ensure any required video codecs are installed.
19:42:04.2 2/8/2013: 5. Try a different theme, or try running the theme at the resolution it was designed for
19:42:04.2 2/8/2013: 6. Try the latest version of GameEx. GameEx is updated all the time.
19:42:04.2 2/8/2013: 7. If you performed an auto update to this version. Try performing a manual download and install.
19:42:04.2 2/8/2013: Closing database connection
19:42:04.2 2/8/2013: Disposing Plugins
19:42:04.2 2/8/2013: GameEx is exiting with errors
19:42:04.8 2/8/2013: ERRORS DETECTED: EXITING
19:42:05.6 2/8/2013: Bye
thanks.
Your log file shows quite a few plugins running. Can you disable all of them? You will need to load the Plugin Manager and uncheck and close. Also, please go into Setup Wizard and select the Default-Default theme. Try launching GameEx again and post a new log file.
Sounds like an IBM T23 Thinkpad:
The ThinkPad T23 features:
  • Intel Mobile Pentium III Processor-M at 866MHz (1), 1.13GHz, 1.0GHz or 1.2GHz with 512KB onboard cache, depending on model
  • Sleek profile and light weight
  • Microsoft
    Windows 98 Second Edition, Microsoft Windows XP Professional, or
    Microsoft Windows 2000 Professional, depending on model
  • 133MHz front-side system bus with 133MHz memory modules
  • 128MB or 256MB of memory is standard, depending on model, expandable to 1.0GB
  • S-Video out port (TV out) on all models
  • 15, 20, 30, 48 or 60GB (2) hard disk drive and 30GB for selected Korean systems
  • Integrated 802.11b wireless, v.90 modem (3), Ethernet, and/or Secure Chip, depending on model
  • Enhanced graphics enabling multiple monitor (4) support
  • 8x-3.3x DVD (5) drive, 24x-10x CD-ROM drive, 8x4x24x maximum CD-RW drive, or 4x4x24x/6x DVD-ROM/CD-RW drive,depending on model
LCD TFT display
The ThinkPad T23 notebook comes with one of the following displays:
  • 337.8-mm (13.3-in) TFT display with 1024 x 768 resolution
  • 358.1-mm (14.1-in) TFT display with 1024 X 768 resolution
  • 358.1-mm (14.1-in) TFT display with 1400 x 1050 resolution
All displays are measured diagonally.
Video Modes -- T23 (16M SDRAM)
For systems having 1400 x 1050 resolution LCD displays.
LCD External Monitor (CRT only mode) Resolution TFT 85 Hz 75 Hz 72 Hz 70 Hz 60 Hz 640 X 480 16M 16M 16M 16M NA 16M 800 x 600 16M 16M 16M 16M NA 16M 1024 x 768 16M 16M 16M NA 16M 16M 1280 x 1024 16M 16M 16M NA NA 16M 1400 x 1050 16M NA NA NA NA NA 1600 x 1200 16M(*) 64K 64K NA NA 64K
(*): Panning on LCD
NOTE: All modes are common for each operating system.
LCD with 1024 x 768 resolution
LCD External Monitor CRT only mode) Resolution TFT 85 Hz 75 Hz 72 Hz 70 Hz 60 Hz 640 X 480 16M 16M 16M 16M NA 16M 800 x 600 16M 16M 16M 16M NA 16M 1024 x 768 16M 16M 16M NA 16M 16M 1280 x 1024 16M(*) 16M 16M NA NA 16M 1400 x 1050 NA NA NA NA NA NA 1600 x 1200 16M(*) 64K 64K NA NA 64K
If it only has 16MB SDRAM then it is relying heavily on the shared 383MB RAM being reported in the log file (likely it is actually 512MB). This would put it below minimum specs for GameEx to run well if at all. As noted in the minimum requirements, onboard video on the older systems is not recommended. If the RAM was upgraded to 1GB you might have enough juice to run it with some of the lighter weight emulators (MAME for example), but I wouldn't put a lot of money into it to do so.
lol, thats exactly what it is.
so what your saying is that it cant be done on this?
does anyone think that their is another front end out their that would work on this (eg.mala or maximus arcade, hyperspin, mamewah) or is their an outstanding reason why it couldnt possibly be done?
all i plan on running is MAME as i dont like console emulators anyway.
i dont expect you to encourage me to use other sites but if it cant be done here then i have no choice but to move on. the reson i chose here in the begining was because it seemed simple to set us for a noob like myself.
so if you think a different one will work, please direct me.
thanks for all the help so far.
You could try to increase the amount of installed RAM to give you more leeway. Also, try using Lite mode which will open a smaller version of GameEx without all of the extras. Also, ensure that you have the most up to date Direct X and .net versions installed that your OS will support.
HyperSpin will be too much for your system as will Maximus Arcade most likely. There may be some others that are no longer actively supported that were designed to run on older, legacy systems but no names come to mind at the moment. Perhaps one of the other members can recommend some.
There is always the option of using just MameUI32 or in conjunction with IVPlay which gives more of a basic FE feel to MameUi. Whatever you decide, please let us know what you choose and how it works for you and your system.
