I'm new to GameEx as I've been using Hyperspin for many years now. I saw GameEx and accident and decided to give it a try. My question is with using Emumovies to download info and artwork. I have installed and downloaded all my NES info and used Emumovies and the scraper to get all my info. However, When using GameEx all my roms show and work just fine but only about 50%or less show the actual artwork and info. Does the rom.nes have to match the exact name of the file from Emumovies in order for it to pickup in GameEx?? Some names are slightly off or they might be more of an abbreviation due to a very long name but Hyperspin and using Mobygames use to pick up everything just fine. Am I doing something wrong? Thanks for any help.
Welcome to GameEx!
The download svc utility handles all your artwork naming for you which is the best option. You can also set GameEx to look for a close match in the tweaks setting.
Welcome to GameEx! The download svc utility handles all your artwork naming for you which is the best option. You can also set GameEx to look for a close match in the tweaks setting.
I did use the service utility included with the GameEx install and created an account with Emumovies so I could use the utility. I ran it while pointing to my NES roms folder as requested and then asked it to get all artwork. It did a fantastic job and seemed to grab everything. The issue isn't that, But it's when I'm actually in the GameEx frontend. I copied over all the info that the Emu utility downloaded and copied them to the "assets", "NES" folder then placed them in the correct folders from there ie. Boxes, Carts, Screens, etc. But again only about half actually are showing with my game files in GameEx. Glaring example, I have all the info for Super Mario Brothers 3 in all the correct Assets folders. But when I'm in GameEx and scroll to the Super Mario Brothers 3 rom it doesn't display anything. No description, No box art, No Cartridge etc. I'm not sure how to fix this.
I have went threw every NES rom I have and renamed word for word, space for space and dash for dash what Emumovies have there boxes, and carts titled. Still nothing, Won't pull them in even though they are there. :(
When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
20:53:40.4 3/24/2013: Opening Configuration File
20:53:40.4 3/24/2013: GameEx: Version 13.02: Starting Log
20:53:40.4 3/24/2013: Operating System Platform: Win32NT
20:53:40.4 3/24/2013: Operating System Name: Windows 7
20:53:40.4 3/24/2013: Operating System Version: 6.1.7601
20:53:40.4 3/24/2013: Aero running
20:53:40.4 3/24/2013: Initializing Vista/Windows 7 volume control
20:53:40.4 3/24/2013: Getting CPU and RAM info
20:53:40.4 3/24/2013: Intel® Core i7-2630QM CPU @ 2.00GHz, 8169MB
20:53:40.4 3/24/2013: 2Ghz - 8 Cores or CPU's
20:53:40.4 3/24/2013: Running Randomize()
20:53:40.4 3/24/2013: Loading PlugIns
20:53:40.4 3/24/2013: Checking for applications to Launch On Startup
20:53:40.4 3/24/2013: Running Misc startup tasks
20:53:40.4 3/24/2013: Setting Menu types
20:53:40.4 3/24/2013: Getting Configuration Values
20:53:40.4 3/24/2013: Using Theme: Default - Default - Animated
20:53:40.4 3/24/2013: Checking for alternate Image Directory for Theme: Default - Default - Animated
20:53:40.4 3/24/2013: Using Images from theme: Default - Default\MEDIA\
20:53:40.4 3/24/2013: Launching HideOS.exe
20:53:40.4 3/24/2013: Initialising Video/MNG DLL's
20:53:40.4 3/24/2013: GameEx will check for media insertion (may affect performance)
20:53:40.4 3/24/2013: Hiding Taskbar
20:53:40.4 3/24/2013: Is Media Center running?
20:53:40.4 3/24/2013: Checking/Creating LCD Registry values
20:53:40.4 3/24/2013: Check Media Center Exit/Start Mode
20:53:40.4 3/24/2013: Media Center Mode 2
20:53:40.5 3/24/2013: Video previews on. Warning: Only recommended on modern systems
20:53:40.5 3/24/2013: Snap Delay set to: 4
20:53:40.5 3/24/2013: Get other settings
20:53:40.5 3/24/2013: Desktop set to Hide ICONS and set Background to Black
20:53:40.5 3/24/2013: Set: Find emulator artwork on best match basis
20:53:40.5 3/24/2013: Start work for Form
20:53:40.5 3/24/2013: Getting Original Screen Size
20:53:40.5 3/24/2013: Opening Database Connection
20:53:40.5 3/24/2013: Initializing Component
20:53:40.6 3/24/2013: MAME Path is: C:\Emulators\Mame32
20:53:40.6 3/24/2013: Cannot Find MAME Path: MAME Disabled
20:53:40.6 3/24/2013: Loading Controls.ini map file
20:53:40.6 3/24/2013: Applying Language/Text
20:53:40.6 3/24/2013: Text/Language: English
20:53:40.6 3/24/2013: Loading Language/Text
20:53:40.6 3/24/2013: Loading Custom Emulators
20:53:40.6 3/24/2013: Loading Emulator 1: [Arcade] Arcade (MAME)
20:53:40.6 3/24/2013: Loading Emulator 2: [Console] Nintendo GameCube (Dolphin)
20:53:40.6 3/24/2013: Loading Emulator 3: [Console] Nintendo N64 (Project64)
20:53:40.6 3/24/2013: Loading Emulator 4: [Console] Nintendo NES (Jnes)
20:53:40.6 3/24/2013: Loading Emulator 5: [Console] Nintendo SNES (SNEeSe)
20:53:40.6 3/24/2013: Loading Emulator 6: [Console] Nintendo Wii (Dolphin)
20:53:40.6 3/24/2013: Loading Emulator 7: [Console] Sega 32x (Fusion)
20:53:40.6 3/24/2013: Loading Emulator 8: [Console] Sega 32x (GENS+)
20:53:40.6 3/24/2013: Loading Emulator 9: [Console] Sega CD (Fusion)
20:53:40.6 3/24/2013: Loading Emulator 10: [Console] Sega CD (GENS+)
20:53:40.6 3/24/2013: Loading Emulator 11: [Console] Sega Dreamcast (nullDC)
20:53:40.6 3/24/2013: Loading Emulator 12: [Console] Sega Genesis (Fusion)
20:53:40.6 3/24/2013: Loading Emulator 13: [Console] Sega Genesis (GENS+)
20:53:40.6 3/24/2013: Loading Emulator 14: [Console] Sega Master System (Fusion)
20:53:40.6 3/24/2013: Loading Emulator 15: [Console] Sega Master System (GENS+)
20:53:40.7 3/24/2013: Loading Emulator 16: [Console] Sega Saturn (Yabause)
20:53:40.7 3/24/2013: Loading Emulator 17: [Console] Sony Playstation (ePSXe)
20:53:40.7 3/24/2013: Loading Emulator 18: [Console] Sony Playstation 2 (PCSX2)
20:53:40.7 3/24/2013: Loading Emulator 19: [Handheld] Nintendo DS (DeSmuME)
20:53:40.7 3/24/2013: Loading Emulator 20: [Handheld] Nintendo Game Boy (VisualBoyAdvance)
20:53:40.7 3/24/2013: Loading Emulator 21: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
20:53:40.7 3/24/2013: Loading Emulator 22: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
20:53:40.7 3/24/2013: Loading Emulator 23: [Handheld] Sega Game Gear (Fusion)
20:53:40.7 3/24/2013: Loading Emulator 24: [Handheld] Sega Game Gear (GENS+)
20:53:40.7 3/24/2013: Loading Emulator 25: [HandHeld] Sony PSP (PCSP)
20:53:40.7 3/24/2013: Using Version 3 Themes Animations
20:53:40.7 3/24/2013: Retrieving resolution setting
20:53:40.7 3/24/2013: Using General Font: Trebuchet MS
20:53:40.7 3/24/2013: Using Title Font: Trebuchet MS
20:53:40.7 3/24/2013: GameEx will try to reduce CPU usage
20:53:40.7 3/24/2013: Initialising Direct3D
20:53:40.9 3/24/2013: Setting Resolution to 1600x900 32 bit color
20:53:40.9 3/24/2013: Creating Surfaces
20:53:41.0 3/24/2013: Creating Primary Surface - Full Screen Mode
20:53:41.0 3/24/2013: Creating Back Buffer
20:53:41.0 3/24/2013: Loading graphic Surfaces
20:53:41.0 3/24/2013: Display is running at: 1600x900 32bit color, 60hz
20:53:41.0 3/24/2013: Adapter: NVIDIA GeForce GTX 560M
20:53:41.0 3/24/2013: Max texture size: 8192x8192
20:53:41.0 3/24/2013: Available texture memory: -66MB
20:53:41.1 3/24/2013: Initialising Bass Audio Library
20:53:41.1 3/24/2013: Creating Surfaces Misc and Dialogs
20:53:41.2 3/24/2013: Creating Surfaces Volume
20:53:41.2 3/24/2013: Creating Surfaces Arrows
20:53:41.2 3/24/2013: Creating Surfaces GameEXlogo Text
20:53:41.2 3/24/2013: Creating Surfaces Toolbar
20:53:41.2 3/24/2013: Creating Surfaces Toolbar Controls
20:53:41.2 3/24/2013: Creating Surfaces Backgrounds
20:53:41.2 3/24/2013: Creating Surfaces GameEx Logo
20:53:41.2 3/24/2013: Creating Surface Unselected
20:53:41.2 3/24/2013: Creating Surfaces Snaps
20:53:41.2 3/24/2013: Creating Surfaces Menu and List Bars
20:53:41.5 3/24/2013: Creating Fonts
20:53:41.5 3/24/2013: Creating Game Font
20:53:41.6 3/24/2013: Creating Game Font Faded
20:53:41.6 3/24/2013: Creating Title Font
20:53:41.6 3/24/2013: Restoring Title Font From Cache
20:53:41.8 3/24/2013: Creating Font Black
20:53:41.9 3/24/2013: Creating Font Black Small
20:53:41.9 3/24/2013: Fonts Created Succesfully
20:54:04.3 3/24/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
20:54:04.6 3/24/2013: Initialising DirectInput for Gamepad support
20:54:04.6 3/24/2013: Unable to create a joystick device
20:54:04.6 3/24/2013: Loading Start Page
20:54:04.6 3/24/2013: Initializing MCE Remote
20:54:04.6 3/24/2013: Playing intro sound file
20:54:04.6 3/24/2013: Initialization OK! Starting GameEx!
20:54:04.6 3/24/2013: Testing Main Loop Once: Processing Frame
20:54:04.8 3/24/2013: Testing Main Loop Once: Main Loop ran successfully
20:54:08.4 3/24/2013: Validating: Emulator_1: Snap Path: C:\Assets\MAME\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_1: Control Panel Path: C:\Assets\MAME\Controls
20:54:08.4 3/24/2013: Validating: Emulator_1: Title Snap Path: C:\Assets\MAME\Titles
20:54:08.4 3/24/2013: Validating: Emulator_1: Box Art Path: C:\Assets\MAME\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_1: Cart Art Path: C:\Assets\MAME\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_1: Manual Path: C:\Assets\MAME\Manuals
20:54:08.4 3/24/2013: Warning: Emulator_1: MAPFile Does Not Exist
20:54:08.4 3/24/2013: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo GameCube\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo GameCube\Controls
20:54:08.4 3/24/2013: Validating: Emulator_2: Database: [Console] Nintendo GameCube
20:54:08.4 3/24/2013: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo GameCube\Titles
20:54:08.4 3/24/2013: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo GameCube\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo GameCube\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo GameCube\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo N64\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo N64\Controls
20:54:08.4 3/24/2013: Validating: Emulator_3: Database: [Console] Nintendo N64
20:54:08.4 3/24/2013: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo N64\Titles
20:54:08.4 3/24/2013: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo N64\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo N64\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo N64\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_4: Snap Path: C:\Assets\Nintendo NES\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_4: Control Panel Path: C:\Assets\Nintendo NES\Controls
20:54:08.4 3/24/2013: Validating: Emulator_4: Database: [Console] Nintendo NES
20:54:08.4 3/24/2013: Validating: Emulator_4: Title Snap Path: C:\Assets\Nintendo NES\Titles
20:54:08.4 3/24/2013: Validating: Emulator_4: Box Art Path: C:\Assets\Nintendo NES\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_4: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_4: Manual Path: C:\Assets\Nintendo NES\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_5: Snap Path: C:\Assets\Nintendo SNES\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_5: Control Panel Path: C:\Assets\Nintendo SNES\Controls
20:54:08.4 3/24/2013: Validating: Emulator_5: Database: [Console] Nintendo SNES
20:54:08.4 3/24/2013: Validating: Emulator_5: Title Snap Path: C:\Assets\Nintendo SNES\Titles
20:54:08.4 3/24/2013: Validating: Emulator_5: Box Art Path: C:\Assets\Nintendo SNES\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_5: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_5: Manual Path: C:\Assets\Nintendo SNES\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_6: Snap Path: C:\Assets\Nintendo Wii\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_6: Control Panel Path: C:\Assets\Nintendo Wii\Controls
20:54:08.4 3/24/2013: Validating: Emulator_6: Database: [Console] Nintendo Wii
20:54:08.4 3/24/2013: Warning: Emulator_6: Database Does not exist
20:54:08.4 3/24/2013: Validating: Emulator_6: Title Snap Path: C:\Assets\Nintendo Wii\Titles
20:54:08.4 3/24/2013: Validating: Emulator_6: Box Art Path: C:\Assets\Nintendo Wii\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_6: Cart Art Path: C:\Assets\Nintendo Wii\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_6: Manual Path: C:\Assets\Nintendo Wii\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_7: Snap Path: C:\Assets\Sega 32x\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_7: Control Panel Path: C:\Assets\Sega 32x\Controls
20:54:08.4 3/24/2013: Validating: Emulator_7: Database: [Console] Sega 32X
20:54:08.4 3/24/2013: Validating: Emulator_7: Title Snap Path: C:\Assets\Sega 32x\Titles
20:54:08.4 3/24/2013: Validating: Emulator_7: Box Art Path: C:\Assets\Sega 32x\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_7: Cart Art Path: C:\Assets\Sega 32x\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_7: Manual Path: C:\Assets\Sega 32x\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_8: Snap Path: C:\Assets\Sega 32x\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_8: Control Panel Path: C:\Assets\Sega 32x\Controls
20:54:08.4 3/24/2013: Validating: Emulator_8: Database: [Console] Sega 32X
20:54:08.4 3/24/2013: Validating: Emulator_8: Title Snap Path: C:\Assets\Sega 32x\Titles
20:54:08.4 3/24/2013: Validating: Emulator_8: Box Art Path: C:\Assets\Sega 32x\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_8: Cart Art Path: C:\Assets\Sega 32x\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_8: Manual Path: C:\Assets\Sega 32x\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_9: Snap Path: C:\Assets\Sega CD\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_9: Control Panel Path: C:\Assets\Sega CD\Controls
20:54:08.4 3/24/2013: Validating: Emulator_9: Database: [Console] Sega CD
20:54:08.4 3/24/2013: Validating: Emulator_9: Title Snap Path: C:\Assets\Sega CD\Titles
20:54:08.4 3/24/2013: Validating: Emulator_9: Box Art Path: C:\Assets\Sega CD\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_9: Cart Art Path: C:\Assets\Sega CD\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_9: Manual Path: C:\Assets\Sega CD\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_10: Snap Path: C:\Assets\Sega CD\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_10: Control Panel Path: C:\Assets\Sega CD\Controls
20:54:08.4 3/24/2013: Validating: Emulator_10: Database: [Console] Sega CD
20:54:08.4 3/24/2013: Validating: Emulator_10: Title Snap Path: C:\Assets\Sega CD\Titles
20:54:08.4 3/24/2013: Validating: Emulator_10: Box Art Path: C:\Assets\Sega CD\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_10: Cart Art Path: C:\Assets\Sega CD\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_10: Manual Path: C:\Assets\Sega CD\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_11: Snap Path: C:\Assets\Sega Dreamcast\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_11: Control Panel Path: C:\Assets\Sega Dreamcast\Controls
20:54:08.4 3/24/2013: Validating: Emulator_11: Database: [Console] Sega Dreamcast
20:54:08.4 3/24/2013: Validating: Emulator_11: Title Snap Path: C:\Assets\Sega Dreamcast\Titles
20:54:08.4 3/24/2013: Validating: Emulator_11: Box Art Path: C:\Assets\Sega Dreamcast\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_11: Cart Art Path: C:\Assets\Sega Dreamcast\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_11: Manual Path: C:\Assets\Sega Dreamcast\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_12: Snap Path: C:\Assets\Sega Genesis\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_12: Control Panel Path: C:\Assets\Sega Genesis\Controls
20:54:08.4 3/24/2013: Validating: Emulator_12: Database: [Console] Sega Genesis
20:54:08.4 3/24/2013: Validating: Emulator_12: Title Snap Path: C:\Assets\Sega Genesis\Titles
20:54:08.4 3/24/2013: Validating: Emulator_12: Box Art Path: C:\Assets\Sega Genesis\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_12: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_12: Manual Path: C:\Assets\Sega Genesis\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_13: Snap Path: C:\Assets\Sega Genesis\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_13: Control Panel Path: C:\Assets\Sega Genesis\Controls
20:54:08.4 3/24/2013: Validating: Emulator_13: Database: [Console] Sega Genesis
20:54:08.4 3/24/2013: Validating: Emulator_13: Title Snap Path: C:\Assets\Sega Genesis\Titles
20:54:08.4 3/24/2013: Validating: Emulator_13: Box Art Path: C:\Assets\Sega Genesis\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_13: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_13: Manual Path: C:\Assets\Sega Genesis\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_14: Snap Path: C:\Assets\Sega Master System\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_14: Control Panel Path: C:\Assets\Sega Master System\Controls
20:54:08.4 3/24/2013: Validating: Emulator_14: Database: [Console] Sega Master System
20:54:08.4 3/24/2013: Validating: Emulator_14: Title Snap Path: C:\Assets\Sega Master System\Titles
20:54:08.4 3/24/2013: Validating: Emulator_14: Box Art Path: C:\Assets\Sega Master System\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_14: Cart Art Path: C:\Assets\Sega Master System\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_14: Manual Path: C:\Assets\Sega Master System\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_15: Snap Path: C:\Assets\Sega Master System\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_15: Control Panel Path: C:\Assets\Sega Master System\Controls
20:54:08.4 3/24/2013: Validating: Emulator_15: Database: [Console] Sega Master System
20:54:08.4 3/24/2013: Validating: Emulator_15: Title Snap Path: C:\Assets\Sega Master System\Titles
20:54:08.4 3/24/2013: Validating: Emulator_15: Box Art Path: C:\Assets\Sega Master System\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_15: Cart Art Path: C:\Assets\Sega Master System\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_15: Manual Path: C:\Assets\Sega Master System\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_16: Snap Path: C:\Assets\Sega Saturn\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_16: Control Panel Path: C:\Assets\Sega Saturn\Controls
20:54:08.4 3/24/2013: Validating: Emulator_16: Database: [Console] Sega Saturn
20:54:08.4 3/24/2013: Validating: Emulator_16: Title Snap Path: C:\Assets\Sega Saturn\Titles
20:54:08.4 3/24/2013: Validating: Emulator_16: Box Art Path: C:\Assets\Sega Saturn\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_16: Cart Art Path: C:\Assets\Sega Saturn\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_16: Manual Path: C:\Assets\Sega Saturn\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_17: Snap Path: C:\Assets\Sony Playstation\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_17: Control Panel Path: C:\Assets\Sony Playstation\Controls
20:54:08.4 3/24/2013: Validating: Emulator_17: Database: [Console] Sony Playstation
20:54:08.4 3/24/2013: Validating: Emulator_17: Title Snap Path: C:\Assets\Sony Playstation\Titles
20:54:08.4 3/24/2013: Validating: Emulator_17: Box Art Path: C:\Assets\Sony Playstation\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_17: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_17: Manual Path: C:\Assets\Sony Playstation\Manuals
20:54:08.4 3/24/2013: Warning: Emulator_17: MAPFile Does Not Exist
20:54:08.4 3/24/2013: Validating: Emulator_18: Snap Path: C:\Assets\Sony Playstation 2\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_18: Control Panel Path: C:\Assets\Sony Playstation 2\Controls
20:54:08.4 3/24/2013: Validating: Emulator_18: Database: [Console] Sony Playstation 2
20:54:08.4 3/24/2013: Validating: Emulator_18: Title Snap Path: C:\Assets\Sony Playstation 2\Titles
20:54:08.4 3/24/2013: Validating: Emulator_18: Box Art Path: C:\Assets\Sony Playstation 2\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_18: Cart Art Path: C:\Assets\Sony Playstation 2\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_18: Manual Path: C:\Assets\Sony Playstation 2\Manuals
20:54:08.4 3/24/2013: Warning: Emulator_18: MAPFile Does Not Exist
20:54:08.4 3/24/2013: Validating: Emulator_19: Snap Path: C:\Assets\Nintendo DS\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_19: Control Panel Path: C:\Assets\Nintendo DS\Controls
20:54:08.4 3/24/2013: Validating: Emulator_19: Database: [Handheld] Nintendo DS
20:54:08.4 3/24/2013: Validating: Emulator_19: Title Snap Path: C:\Assets\Nintendo DS\Titles
20:54:08.4 3/24/2013: Validating: Emulator_19: Box Art Path: C:\Assets\Nintendo DS\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_19: Cart Art Path: C:\Assets\Nintendo DS\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_19: Manual Path: C:\Assets\Nintendo DS\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_20: Snap Path: C:\Assets\Nintendo Game Boy\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_20: Control Panel Path: C:\Assets\Nintendo Game Boy\Controls
20:54:08.4 3/24/2013: Validating: Emulator_20: Database: [Handheld] Nintendo Game Boy
20:54:08.4 3/24/2013: Validating: Emulator_20: Title Snap Path: C:\Assets\Nintendo Game Boy\Titles
20:54:08.4 3/24/2013: Validating: Emulator_20: Box Art Path: C:\Assets\Nintendo Game Boy\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_20: Cart Art Path: C:\Assets\Nintendo Game Boy\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_20: Manual Path: C:\Assets\Nintendo Game Boy\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_21: Snap Path: C:\Assets\Nintendo Game Boy Advance\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_21: Control Panel Path: C:\Assets\Nintendo Game Boy Advance\Controls
20:54:08.4 3/24/2013: Validating: Emulator_21: Database: [Handheld] Nintendo Game Boy Advance
20:54:08.4 3/24/2013: Validating: Emulator_21: Title Snap Path: C:\Assets\Nintendo Game Boy Advance\Titles
20:54:08.4 3/24/2013: Validating: Emulator_21: Box Art Path: C:\Assets\Nintendo Game Boy Advance\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_21: Cart Art Path: C:\Assets\Nintendo Game Boy Advance\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_21: Manual Path: C:\Assets\Nintendo Game Boy Advance\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_22: Snap Path: C:\Assets\Nintendo Game Boy Color\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_22: Control Panel Path: C:\Assets\Nintendo Game Boy Color\Controls
20:54:08.4 3/24/2013: Validating: Emulator_22: Database: [Handheld] Nintendo Game Boy Color
20:54:08.4 3/24/2013: Validating: Emulator_22: Title Snap Path: C:\Assets\Nintendo Game Boy Color\Titles
20:54:08.4 3/24/2013: Validating: Emulator_22: Box Art Path: C:\Assets\Nintendo Game Boy Color\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_22: Cart Art Path: C:\Assets\Nintendo Game Boy Color\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_22: Manual Path: C:\Assets\Nintendo Game Boy Color\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_23: Snap Path: C:\Assets\Sega Game Gear\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_23: Control Panel Path: C:\Assets\Sega Game Gear\Controls
20:54:08.4 3/24/2013: Validating: Emulator_23: Database: [Handheld] Sega Game Gear
20:54:08.4 3/24/2013: Validating: Emulator_23: Title Snap Path: C:\Assets\Sega Game Gear\Titles
20:54:08.4 3/24/2013: Validating: Emulator_23: Box Art Path: C:\Assets\Sega Game Gear\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_23: Cart Art Path: C:\Assets\Sega Game Gear\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_23: Manual Path: C:\Assets\Sega Game Gear\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_24: Snap Path: C:\Assets\Sega Game Gear\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_24: Control Panel Path: C:\Assets\Sega Game Gear\Controls
20:54:08.4 3/24/2013: Validating: Emulator_24: Database: [Handheld] Sega Game Gear
20:54:08.4 3/24/2013: Validating: Emulator_24: Title Snap Path: C:\Assets\Sega Game Gear\Titles
20:54:08.4 3/24/2013: Validating: Emulator_24: Box Art Path: C:\Assets\Sega Game Gear\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_24: Cart Art Path: C:\Assets\Sega Game Gear\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_24: Manual Path: C:\Assets\Sega Game Gear\Manuals
20:54:08.4 3/24/2013: Validating: Emulator_25: Snap Path: C:\Assets\Sony PSP\Snaps
20:54:08.4 3/24/2013: Validating: Emulator_25: Control Panel Path: C:\Assets\Sony PSP\Controls
20:54:08.4 3/24/2013: Validating: Emulator_25: Database: [HandHeld] Sony PSP
20:54:08.4 3/24/2013: Validating: Emulator_25: Title Snap Path: C:\Assets\Sony PSP\Titles
20:54:08.4 3/24/2013: Validating: Emulator_25: Box Art Path: C:\Assets\Sony PSP\Boxes
20:54:08.4 3/24/2013: Validating: Emulator_25: Cart Art Path: C:\Assets\Sony PSP\Cartridges
20:54:08.4 3/24/2013: Validating: Emulator_25: Manual Path: C:\Assets\Sony PSP\Manuals
20:54:08.5 3/24/2013: Restoring Emulator from Cache: 4
20:54:08.6 3/24/2013: Restoring Emulator Database From Cache: 4
20:54:08.7 3/24/2013: Restoring Emulator from Cache: 5
20:54:08.7 3/24/2013: Restoring Emulator Database From Cache: 5
20:54:09.0 3/24/2013: Restoring Emulator from Cache: 11
20:54:09.0 3/24/2013: Restoring Emulator Database From Cache: 11
20:54:09.1 3/24/2013: Restoring Emulator from Cache: 14
20:54:09.1 3/24/2013: Restoring Emulator Database From Cache: 14
20:54:09.2 3/24/2013: Restoring Emulator from Cache: 15
20:54:09.2 3/24/2013: Restoring Emulator Database From Cache: 15
20:54:09.3 3/24/2013: Restoring Emulator from Cache: 17
20:54:09.3 3/24/2013: Restoring Emulator Database From Cache: 17
20:54:09.3 3/24/2013: Restoring Emulator from Cache: 18
20:54:09.3 3/24/2013: No Database Data: 18
20:59:46.8 3/24/2013: Exiting GameEx!
20:59:46.8 3/24/2013: Disposing all videos
20:59:46.8 3/24/2013: Deleting temporary Karaoke videos
20:59:46.8 3/24/2013: Disposing Image List
20:59:46.8 3/24/2013: Disposing Fonts
20:59:46.8 3/24/2013: Disposing Surfaces
20:59:46.9 3/24/2013: Saving Settings
20:59:46.9 3/24/2013: Shutting down Bass
20:59:47.0 3/24/2013: Closing HideOS.exe
20:59:47.2 3/24/2013: Disposing Plugins
20:59:47.2 3/24/2013: Closing database connection
20:59:47.2 3/24/2013: Checking for applications to Launch On Exit
20:59:47.2 3/24/2013: Media Center was not open when starting GameEx, so not launching
20:59:47.2 3/24/2013: Bye
@bloodlust - 2 things please. First, please use Attach Files option under More Reply Options on the bottom right when making a reply. Attached files are more friendly to those that may be on mobile devices reviewing your thread and log file are a devil to scroll through.
Second, you are presently using version 13.02. Please install the latest GameEx version (13.08) and provide a new log file and gameex..ini file if the issue is not resolved. If so, please let us know as well. Thanks!
How do you completely uninstall the game. If I uninstall the program all the GameEx folders and files are still in my c: even after it says it's been uninstalled. Does this matter?
I think you need to give us some more info to work with as what you are saying doesn't quite make sense. First, you were instructed to upgrade to the latest version. You can download the latest version and install it over your existing installation - no need to uninstall anything. If there was a need, you would have been instructed accordingly.
When you say "When I install the newest release it's not installing correctly." what exactly does this mean? Are you getting an error message during the install? Is it installing but not starting (again, is there an error message)?
I actually uninstalled the previous version as I've had troubles in the past with programs and drivers not "updating" correctly so I've always made it a habit to uninstall and re-install the latest version. So I removed the old version. I reinstalled the new version of GameEx and ran the basic config wizard as I had done before. When I select the emulators to install it doesn't set them up. When I go back to my C: where there was once a "Rom", "Emulator" and "Assests" folder they are now gone. The "GameEx" folder is there. Now before the emulators would be placed into the emulator and so on and so forth. Now, Back to the GameEx program itself. I'm not sure if this is due to the updated version or not but when in GameEx the only menu options that show are the following. At the top of the default theme I have, "Change View", "Back", "Home", and "Exit". However in the actual menu I now only show "Search", "Multimedia", "More Games & Programs", "News" and "Exit/Shutdown". Before I had Mame, Last Played, Favorites, Emulated Programs and it seemd many others. Is this correct with this new version? Why are my emulators now not showing in GameEx? This is what I mean when I don't think it's installing correctly as I'm now missing functions, folders, etc.
Not sure what to tell you as that is not a normal behavior and appears to be isolated to you at present. Going forward, I recommend installing over.
Please attach copies of your gameex.ini and log.txt files in reply to this thread (under More Reply Options).
@bloodlust - ...please use Attach Files option under More Reply Options on the bottom right when making a reply. Attached files are more friendly to those that may be on mobile devices reviewing your thread and log file are a devil to scroll through.
Using [ SPOILER ] Log Text Here [ /SPOILER ] (without the spaces) tags are even better, as my version of Tapatalk won't allow me to download from this forum for some reason. ;)
That's me though, I just live here practically. LOL!
Sorry for not getting back sooner, Been out of town due to my job. I got home tonight and started up GameEx to begin playing with it again and discovered most of the stuff seems to be working now. Not sure why or how, I do have auto update on my Emumovies setup within GameEx maybe something happened there. There are still a few that I have the images for and have the .rom named exactly what Emu has there image files named and they still won't pickup. At least now that's only like 5% of them instead of the 95% earlier. I can live with this at least. I'm going to start testing GameEx now and see if I like it compared to Hyperspin. Thanks for the help and suggestions!!
