Prior to updating my GameEx for the Steam integration, I had GameEx run on login. Now, Steam connects first, then nothing happens. GameEx will have launched, but it will be minimized.
If I change the order, forcing GameEx to run first, then Steam, will Steam still connect? I tried this before (about a year ago) and Steam would never connect. Basically, anything that happened after GameEx launched never initialized. I had network drives that I would map to and if GameEx launched before the drives were mapped, the drives would be dead links.
After 4 years of GameEx I'm just now starting to really dig into the settings and I'm trying to figure out the best way possible to go about things. So sorry in advance, but you're going to be seeing a lot of questions from me in the near future :)
Adultery created a program called GameEx Launch that you may be able to use to automatically launch GameEx but set a delay to allow other applications to launch before. GameEx will launch Steam within so there should be no worries there.
Cool thanks! Originally I wrote a batch file to trigger certain events and have things load at different times, but if the "GameEx Launch" application is simplier, I'll definitely use that instead.
