8trek Posted October 19, 2012 Share Posted October 19, 2012 Okay, here's the situation...Have 3 individual displays hooked up to the computer. I'm only using 1 display to run gameex and games themselves. The other 2 displays have there own purposes. When i startup gameex all other displays either freeze up or go blank. What settings do i need to choose in order to play gameex in full screen mode but not cause the other displays to freeze or go blank? I've tried different options and haven't figured it out yet or know if it's even possible. Thanks. Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted October 19, 2012 Share Posted October 19, 2012 I have a dual display and the same thing happens - this is usually because I am loading GameEx in fullscreen as opposed to windowed mode. Likely you are using Windows 7 with Aero enabled and this occurs as the display is being changed to Windows Basic view. Try switching to Windows Basic mode and most of this should subside, however, not entirely unless you load GameEx in windowed mode. Quote Link to comment Share on other sites More sharing options...
