ClassicGMR Posted August 17, 2012 Posted August 17, 2012 Obviously not a GameEx issue but everyone here is an emulator specialist so... I really want to use either my tankstick or my PS1 gamepad for NeoRaine. I read on their website that the emulator will just auto-recognize the USB gamepad connected and go.Problem is I have 5 USB controllers! I found out that NeoRaine actually wants to use my Vision-dapter with is my Intellivision contoller. I see no way to specify which controller it uses.Has anyone gotten around this? The Intellivision controller is awesome... for Intellivision. Not interested in it as a gamepad! Quote
Draco1962 Posted August 17, 2012 Posted August 17, 2012 Have you considered using something like Xpadder? That way you can better control which gamepad/cp profile is loaded for your emulator. 1 Quote
ClassicGMR Posted August 17, 2012 Author Posted August 17, 2012 I'll have to check that out. I'm using XPadder on my NES computer because that's 100% controlled by an XBox 360 controller. I haven't had to do anything like that with this one.Is it a command line switch to load the profile or another case of "Launch Before" and "Launch After"? Quote
ClassicGMR Posted August 17, 2012 Author Posted August 17, 2012 Wow I actually feel really stupid. After applying XPadder to the situation - thanks Draco and Adultery! - I got a (very snarky) reply from Tux on the Raine boards. Apparently you configure the controls AFTER you load a game. There's no way to do it unless you load up a game first.I guess should have read it in the documentation for Raine... oh wait! There isn't any!So while it was easy to configure it wasn't obvious. I still feel stupid though. Quote
Draco1962 Posted August 17, 2012 Posted August 17, 2012 That's OK. Stupid is used to frequent gropes by me. Glad it helped! Quote
