I'm trying to get Pinmame to work with GameEx.
I keep getting to the point where I'll load a table, and GameEx goes through the motions, but a window pops up telling me that VPinball is paused, and to hit any key to continue. When any key is hit, the window closes and the emulation ends.
Any ideas what I'm doing wrong?
Anyone have some configs for PinMame/VPinball?
Yeah, I have not configured pinmame correctly yet either and would also like to see someone elses configs if available. Thanks.
Ive been using PinMAME since when the emulator support was first addedd to GameEx. I think its one of the default configs? Is it not with the install anymore? maybe you overwrite the config with something else?
I am sure you wont have a big problem, if you follow the default config included with the install?
Maybe I blitzed the config or something and its not there anymore?
Heres what I have on my MCE pc
[Emulator_7]
STARTPAGENAME=Pinball Games
TITLETEXT=Pinball
StartPageLogo=pinball
ROMFilter=*.vpt
RomsInFolders=False
RomPath=c:\Pinball\Tables
SnapPath=c:\pinball\snap
WorkingPath=c:\Pinball\Tables
MapKeys=True
WaitBeforeKeys=10000
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=[apppath]\vpauto.exe
Command=..\VPinball-XPFix4.exe -play -"[ROMFILE]"
OLDatZip=
Thanks,
Tom
  • 2 months later...
I know you must be tired of this question, but I've been fighting this for about 2 hours now. I have everything set up the same way you do, but everytime I click on a table, it takes me back to my desktop. I can see vpauto.exe in my taskbar and I can't re-run GameEX until I go back into configuration. The only difference I can see is the you guys are using XPFix5.exe. I am not sure what that is. I am using VPinball.exe. I am sorry I keep bringing up what should be a dead horse, I just don't seem to be getting it. Thanks for your patience and help.
I was having the same problems try this
Command=VPinball-XPFix4.exe -play -"C:\what ever your path to your roms is here\[ROMFILE]"
i am using the VPinball-XPFix5.exe. get it here www.vpforums.com in the downloads.
Thank you very much. I got it figured out, I just moved PinMAME to my C: directory and it worked fine. Maybe I had it in too many subfolders, I don't know. Thanks again, though, for taking the time to help me. :D
Ok, followed Tom's config and got Vis PinMame to work with Game Ex
When i launch any of the tables in game ex it loads up, but it also loads the editor as well and it is in the foreground, and the table in the background. I have to manually click on the table behind the editor to play the table.
how do you configure it so that it loads the table and not the editor? or do you need to load the editor as well?
This is a repost (sorry) from a different thread, but it may help for people only looking here:
I too was having an issue where I had to click on the table in order to force the game to start. I believe this problem developed when I updated to the newest version of Visual Pinball. With a bit of searching, I found an AutoIt file on the VPForums posted by a guy named eXentric. I just replaced the vpauto.exe that came with GameEX with this one (renamed it to vpauto.exe) and it works fine.
Tom, maybe you want to decompile his script to see what he did different?
Anyway, it's attached here.
vpa1.1.zip
I've tried the AutoIT file, because with the newest version of GameEx, it hangs the "Quit to Editor" option on Pinmame open, along with the table. After playing several tables, this poses a problem. When I replace the vpauto.exe file with what you recommended, it allowed me to press the button for "Quit to Editor", but then would go to my desktop with GameEx running on my taskbar. I've tried a lot of different setting and get the same thing. The AutoIT file also hangs on pause in my start taskbar, so if I run several different tables I will have the same number of vpauto.exe running in my startmenu. I am throroughly confused.
Use the MapKeys setting, and use the latest version of vpauto included with the latest GameEx.
Another thing is, how do i go about configuring the keys to use button 1 and button 2 on my mame cab?
do i have to manually edit this for every table?
Just upgraded to 4.61 and am still having the same prob of the editor n front of the table. here is my config
[Emulator_3]
StartPageName=Pinball Games
TitleText=Pinball
RomFilter=*.vpt
RomsInFolders=False
ROMPath=C:\Visual Pinball\Tables
SnapPath=C:\Visual Pinball\snap
WorkingPath=C:\Visual Pinball\Tables
MapKeys=True
WaitBeforeKeys=1000
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=C:\GameEx\vpauto.exe
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command=..\vpinball -play -"[ROMFILE]"
TitlePath=C:\Visual Pinball\snap
BoxPath=C:\Visual Pinball\artwork
LaunchBefore=
LaunchAfter=
CartPath=
I am using Visual Pinball vers 0.6.5922
[Emulator_3]
TitleText=Pinball
RomFilter=*.vpt
RomsInFolders=False
MapKeys=True
WaitBeforeKeys=1000
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
LaunchBefore=
LaunchAfter=
CartPath=
hmm, is it deffinitly running the script? Ie is your GameEx install in C:\GameEx and not C:\program files\gameeex? Could you check the file date on vpauto.exe?
You should be able to change the controls globally for Visual Pinball. Thats wht I always did. Just load it and find the settings and change. Its not on a table basis.
My GameEx is running under C:\Program files\gameex, could that be part of my problem with the "quit to editor"? That would certainly suck to have to reinstall everything, but If that will get it working correctly, I guess it's time to bite bullet... <_<
  Paco62 said:
My GameEx is running under C:\Program files\gameex, could that be part of my problem with the "quit to editor"?  That would certainly suck to have to reinstall everything, but If that will get it working correctly, I guess it's time to bite bullet...  <_>
No, that wont be it. My latest VPAUTO.exe does not quit you need to use MAPKEYS
Map Keys
where is that setting and how does it work?
I have managed to get the tables going with the file that Nightlife has attached (thanx mate)
but now if i load a couple of tables, it leaves that app running in the taskbar, then loads another, and another and another etc
Tom, I'm having the same problem closing... I have mapkeys on but hitting Esc is leaving everything (Quit to Editor, the table, the Visual Pinball) open and opening GameEx over top of that.
I'm using your new included vpauto and it works perfect for opening the tables! Any other ideas on how to close them?
yes i have the same problem it keeps on adding the app in the taskbar and i have to shut them down myself :P
Here is an updated vpauto.exe
Let me know.
Probably need to turn off MAPKeys
vpauto.zip
Let me know.
ill test it right away hang on :o
Edit : after a little test it works it shuts down but i tried another table "Star Wars Trilogy" there it shuts down the table by it self and returns to Game-Ex that worked fine with the old "vpauto.exe "
try:
vpauto.zip
Added new vpauto.exe and it switches from Pinmame back to GameEx just fine, but leaves "Quit to Editor" and the table still running on the desktop. MapKeys are set to false. Am I just missing something here? :(
Get the latest version of GameEx. It fixes a bug where map keys was always on!
