Hi guys I need help you said you got demul to run naomi game? the only way I can get demul to run naomi games is buy choosing load decrypted rom. the files a have are .dat files do I have the wrong files? Atomiswave run well. any ideas or commandlines to bypass the game list?
thank you
I would run the files through a rom manager like clrmame pro against the latest dat to confirm your roms. I'm not aware of the roms having a dat extension. I could be wrong.
As far as command-line:
Demul (Sega * Emulator) v0.5.6
Build date: Sep 1 2010 build 714
usage: demul [options]
-? -h -help give this help
-version give about
-listxml list roms & bioses in ClrMame XML format
-listroms print games list
-run=<name> run specified system (dc, naomi, atomisware, hikaru)
-rom=<romname> run specified system rom
-customrom=<fullpath> run specified system customrom
Sorry Im a noob I have Demul v0.5.7 and what is a rom manager? demul outside of game ex will not run the rom till I tell it to load decrypted rom and pick the .dat file for the game and it playes the game. do you have a naomi emulator if so what do you use?
im trying to get it to launch into fullscreen,
snapback.pngfRequEnCy, on 12 September 2010 - 07:29 AM, said:
A script could be used but isn't required. Simply just put %{ENTER} in the Keys To Send setting in the Emulator Setup section of configuration. May have to tinker with the Wait Before Keys setting, depending on your system.
I tryed this and it works some what, but i get flickering video, i thought id add it here as im sure youll be asking about it to
A rom manager checks the file's crc to make sure you have the correct files. It checks against the dats. It's purpose is for rom management. It seems your roms are decrypted and mine or not but i would just try with the known commandline for naomi to test and see how things go. I don't run any emulators but demul is the one that is recommended by my known sources.
Try the following:
demul.exe -run=naomi -rom="[ROMPATH]\[ROMFILE]"
This is untested for your type of roms since I don't have them that way. But we'll still figure out. Please report back.
Hi Superyoyo90 . Have you been able to resolve this issue based upon the information provided by fRequEnCy as requested?
