I saw posts and posts of all this regarding Mame 0.108 but i am having an issue with the newest version launching correctly. I Ran the update on my emulator games which now they are all viewing in MAME mode however, when i launch the game it loads to 0% then just says game over and takes me back to the main screen to hit play. I have disabled verticle game bezel and i created a Mame.ini file which i changed the Rom path to the correct path on my computer. I copied all the posts from way back but i keep getting the same results :(
Here is my Mame.ini file if that helps
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath C:\Roms\MAME32\Roms
hashpath C:\Emulators\MAME32\hash
samplepath C:\Assets\MAME\Samples
artpath C:\Assets\MAME\Artwork
ctrlrpath C:\Emulators\MAME32\ctrlr
inipath .;ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 0
uifont default
ramsize
confirm_quit 0
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 0
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 0
syncrefresh 0
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion 9
filter 1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 0
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
hide_cursor 1
dual_lightgun 0
Are you having the problem outside of GameEx or just when running MAME via GameEx? Also, you didn't indicate if you uploaded from one version of MAME to another. If you upgraded from 0.108 to 0.146, then you have all sorts of stuff to due to get your ROMs right and working with the new version.
As Alpha said, make sure you have it working right via MAME outside of GameEx. If not, while we may be able to assist in some way, our focus is making sure things are working right when you use the GameEx frontend.
verified just now. when i click mame.exe in its own folder it loads the roms and i am able to play all the ones that work. I got a bunch on there. it is only through gameex where it doesnt work and i changed the bezel to off and removed the command in the mame options to for the display thing. i been slamming my head on the table for like 2 hours already. Im not great at coding or setting up stuff but i was able to create the Mame.ini file and just copy and paste the paths that i knew.
i removed my old mame from a long time ago and downloaded the newest mame version on the mame site. I just created the INI file like 1 hour ago from scratch. Mame works outside of Gameex. If i goto Emulated games and choose mame it also works but when i just select the MAME loader where you can set it up by itself. Thats where i am having the issue with the loading.
Just to clarify... that you can't click on MAME.exe and load roms. MAME is an only command line application. What you mean, maybe, is that you have a MAMEUI32.exe or a MAMEUI64.exe in your MAME folder. Is my assumption correct?
Actually that is incorrect Alpha. The screenshot attached is what you get if you run mame.exe by clicking on it.
I don't know if it always did that or if that is a recent modification but you can use the command line mame.exe to load. It's a very rudimentary interface but it works.
post-7333-0-86431800-1342401088_thumb.jp
When i doubleclick mame.exe i get that attachment classic GMR posted. When i launch gameex and goto emulated roms the game will launch. When i goto MAME the organized section i can see the roms and when i launch one i believe veritcle and horizontle it will get to the loaded screen on Mame and then close before it gets to the bios screen and all the coin stuff
