Chankast Launch
This is a wrapper for the Dreamcast emulator Chankast (http://www.chanka.org). It works with all versions of Chankast, even those that are not designed for full screen mode. It is also written in C++ and is only 72k in size.
CPWizard
CPWizard is a control panel editor, control panel (controls.dat), game info (listinfo.xml/Catver.ini/nplayers.ini/HallOfFame.xml), game history (history.dat), mame info (mameinfo.dat), special moves (command.dat) and hiscore (story.dat) viewer.
CPWizard is a CP editor and viewer with a graphics library designed to build a custom CP. It runs resident in the icon tray and can be invoked by pressing pause in Mame without the need for command line options. It can export CP as images or bezel artwork that can be toggled on or off inside Mame. It also supports emulators other than Mame.
FixColorKey
This program is for people who want transparency in GameEx but also want to keep black areas black. What it does is let you browse to a folder and it will scan each png file and if it contains transparency it will brighten the rest of the image by 5% then make the transparent area pure black. Now when you display the image in GameEx blacks should be black and the transparency should be transparent.
Detective DS
London, 1974. You are a famous Scotland Yard Detective who must solve the murder of the rich aristocrat Angus McFungus, who’s body has been discovered at his home at 427 Park Lane. Arriving at the residence you soon discover that this will not be a simple ‘open and shut’ case, and will take all your finely honed detective skills to solve. Can you put your finger on the killer?
GameEx Login
This program allows you to have multiple users in GameEx each with their own game lists and favourites. You can have up to 10 users including a "Default" login, select a custom username and avatar and password protect certain users. This should be good for people who have children and want to have a gamelist that does not have adult games, but also another password protected login with them included.
Jungool
'Jungool' a physics based platform adventure with a touch of puzzle solving.
LCD/LED Plugin
GameEx plugin that supports LEDWiz, PACDrive, BetaBrite, BPP-440, CrystalFontz, PJRC, ProLite hardware devices. It also supports Speech and Sample event driven effects.
MAME Analog Joystick Map Editor
This is a Mame joystick map editor. Loads/Saves Mame ini files that can specify a control map for specific games. Some example ini files included. Save the ini files to the Mame's ini folder (create an ini folder if it's not there). Name the file [ROM].ini.
MAME Compiler 64
FE to help compiling Mame and applying diff patches. Supports Mame 32/64 and MameUI 32/64.
Manic Miner: The Lost Levels
This game is a collaboration of Flash (ASM Coding), Headkaze (Coding Support), Lobo (Graphics), Spacefractal (Music), Sverx (libXM7 music system) and Rev.Stu (Concept, Research & Story) and has been the culmination of 3 months tireless work spread over the last 26 years since Willy's first outing.
Marquee2Bezel
This program that will convert your marquee collection into custom bezels for use in MAME.
PleasureExtractor
This program is made to extract Visual Pinball, Visual PinMAME and Future Pinball collections from PD.
PlugIn Launch
This plugin allows you to launch apps before and after games in GameEx. It also allows you to launch games with extra variables from GameEx's standard launch method.
PlugIn Rotate
Rotate using LPT port or LED method (or both so you can use the keyboard LED to indicate the rotation). Auto Rotate GameEx to the correct orientation when starting a game.
PlugIn UltraStik
GameEx plugin for UltraStik 360.
VJoy Virtual Joystick
VJoy Virtual Joystick is a driver and icon tray application for converting keystrokes into joystick input. It supports two virtual joysticks as well as command line control. It has signed drivers thanks to Ultimarc (no need to place your machine into driver testing mode) and supports 64-bit systems such as Vista and Windows 7.
Warhawk DS
Were proud to present the first Nintendo DS game by Flash and HeadKaze called Warhawk DS. It's based on a C64 SHMUP from 1986 and has been designed to maintain it's retro gameplay and charm.
WebCamSnap
This program will allow you to take photo's and video's from your Webcam and view them in GameEx. Basically you add the files in the attached zip to your GameEx directory, then setup the program in GameEx config under External Applications. This program will display your webcam stream live in full screen. You press a key to take a photo or record a video. Make sure the PhotoDir and VideoDir settings are the same as your GameEx Pictures and Video directory. Now you can view your photos and video's in GameEx under Multimedia->Pictures/Videos.
Windoze Solitaire
Solitaire for Windows users have been spoilt over the years with three of the greatest and most popular Solitaire games of all time; Klondike, Spider and Freecell. Now, we bring these games to iOS for free, keeping the original feel but bringing a fresh new modern look and simple intuitive control system.
WinUAE Loader
WinUAE Loader is a WinUAE launcher for arcade cabinets. It supports GameBase Amiga, SPS and WHDLoad game sets and allows you to remap input to suit arcade controls.
WinUAE Config Creator
This program will take a collection of ROMs and create uae configuration files for them based on a single uae config file.
  • Like 7
  • tthurman changed the title to Headkaze's Projectshttps://www.gameex.info/forums/topic/11353-headkazes-projects/
