So I am prompted to do an update and I select to do so. All it does when it does after I do the install wizard is load up the old version and prompt me to install update again. Now I noticed a new extracted folder. Is this the new version where I need to move that folder and overwrite the old one? Or do I need to start everything over again?
I actually had that problem on this update a few days ago. It kept going to the download screen then not download anything... it would time out and load into GameEx without installing anything then tell me there's an update again. :)
I downloaded the executable directly from the website and manually updated. Worked fine first time.
What did you just overwrite the gamex directory? If so did you lose your settings?
