Hi Tom / Guys,
First and foremost - my apologies in advance if I have done this incorrectly.
Background information - I have absolutely BASIC computer (& GameEx) knowledge.
I purchased GameEx originally a few years back - managed to get it all set up to my liking and then as "live" tended to occupy my time, haven't played it for some time (I last had Version 8.09). My one memory / issue I had back at this time was that for whatever reason I didn't recieve automatic updates and / or these wouldn't install properly.
Anyway fast forwarding to the future I decided it would be nice to see what new features have been added so I recently decided to purchase version 12.54 and see what was new (I know I dont think I technically needed to do this but was happy to pay the $ to "start a fresh").
Unfortunately I have been unable to get 12.54 up and running (Error message below) and have had to resort to just reloading up 8.09 which still works fine.
I was hoping someone might be able to look at the below and possibly point me in the right direction.
Cheers and thanks in advance guys,
Stuart.
14:51:37.3 2/11/2011: Retrieving resolution setting
14:51:37.3 2/11/2011: Using General Font: Trebuchet MS
14:51:37.3 2/11/2011: Using Title Font: Trebuchet MS
14:51:37.5 2/11/2011: Initialising Direct3D
14:51:37.7 2/11/2011: Applying GameEx is Loading Image
14:51:37.7 2/11/2011: Setting Resolution to 800x600 32 bit color
14:51:37.7 2/11/2011: Creating Surfaces
14:51:37.8 2/11/2011: Applying GameEx is Loading Image
14:51:37.8 2/11/2011: Setting Resolution to 800x600 32 bit color
14:51:37.8 2/11/2011: Creating Surfaces
14:51:37.9 2/11/2011: --**--
14:51:37.9 2/11/2011: Error: Error in the application.
14:51:37.9 2/11/2011: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
14:51:37.9 2/11/2011: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
14:51:37.9 2/11/2011: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
14:51:37.9 2/11/2011: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
14:51:37.9 2/11/2011: at ag.b(Boolean A_0, Boolean A_1, Boolean A_2)
14:51:37.9 2/11/2011: at ag.a(Boolean A_0, String A_1, Boolean A_2)
14:51:37.9 2/11/2011: at ag..ctor()
14:51:37.9 2/11/2011: Closing database connection
14:51:37.9 2/11/2011: Disposing Plugins
14:51:37.9 2/11/2011: GameEx is exiting with errors
14:51:37.9 2/11/2011: Deleting search cache
14:51:38.9 2/11/2011: ERRORS DETECTED: EXITING
14:51:39.0 2/11/2011: Bye
So... You want the good news or the bad news? :)
Since you were here last, we've upgraded GameEx's rendering system to Direct3D. It appears your video card is either too old, or the drivers are unable to handle the load. The first place I would start is looking on your video card manufacurer's web site for an updated driver.
I would be happy to help you check for one, but I'll need to see your whole log file as opposed to just the snippet you provided here. :)
Hey Adultery,
Firstly many thanks for your response and any future assistance your able to provide.
Below as requested the full error log.
6:31:32.7 2/12/2011: Opening Configuration File
16:31:32.7 2/12/2011: GameEx: Version 12.54: Starting Log
16:31:32.7 2/12/2011: Operating System Platform: Win32NT
16:31:32.7 2/12/2011: Operating System Name: Windows XP
16:31:32.7 2/12/2011: Operating System Version: 5.1.2600
16:31:32.7 2/12/2011: Intel® Pentium® 4 CPU 2.53GHz, 511MB
16:31:32.7 2/12/2011: 2.54Ghz
16:31:32.7 2/12/2011: Running Randomize()
16:31:32.7 2/12/2011: Loading PlugIns
16:31:32.7 2/12/2011: Checking for applications to Launch On Startup
16:31:32.7 2/12/2011: Running Misc startup tasks
16:31:32.7 2/12/2011: Setting Menu types
16:31:32.7 2/12/2011: Getting Configuration Values
16:31:32.7 2/12/2011: Using Theme: Default - MCE Glossy
16:31:32.7 2/12/2011: Checking for alternate Image Directory for Theme: Default - MCE Glossy
16:31:32.7 2/12/2011: Launching HideOS.exe
16:31:32.7 2/12/2011: Initialising Video/MNG DLL's
16:31:32.7 2/12/2011: GameEx will check for media insertion (may affect performance)
16:31:32.7 2/12/2011: Hiding Taskbar
16:31:32.8 2/12/2011: Is Media Center running?
16:31:32.8 2/12/2011: Checking/Creating LCD Registry values
16:31:32.8 2/12/2011: Check Media Center Exit/Start Mode
16:31:32.8 2/12/2011: Media Center Mode 2
16:31:32.8 2/12/2011: Video previews on. Warning: Only recommended on modern systems
16:31:32.8 2/12/2011: Snap Delay set to: 2
16:31:32.8 2/12/2011: Get other settings
16:31:32.8 2/12/2011: Desktop set to Hide ICONS and set Background to Black
16:31:32.8 2/12/2011: Set: Find emulator artwork on best match basis
16:31:32.8 2/12/2011: Start work for Form
16:31:32.8 2/12/2011: Getting Original Screen Size
16:31:32.8 2/12/2011: Opening Database Connection
16:31:32.9 2/12/2011: Initializing Component
16:31:33.0 2/12/2011: MAME Path is: D:\Mame32
16:31:33.0 2/12/2011: daphne Path is: D:\Daphne
16:31:33.0 2/12/2011: daphne EXE file is: daphne.exe
16:31:33.0 2/12/2011: Use daphne on. daphne.exe will launch games
16:31:33.0 2/12/2011: MAME EXE file is: Mame32.exe
16:31:33.0 2/12/2011: ROM Path is: D:\Mame32\roms
16:31:33.0 2/12/2011: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
16:31:33.0 2/12/2011: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
16:31:33.0 2/12/2011: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
16:31:33.0 2/12/2011: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
16:31:33.0 2/12/2011: command.dat is located at: C:\Program Files\GameEx\DATA\command.dat
16:31:33.0 2/12/2011: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
16:31:33.0 2/12/2011: Loading Controls.ini map file
16:31:33.0 2/12/2011: Snap Path is: D:\Mame32\snap
16:31:33.0 2/12/2011: Background Snap Path: Not Found
16:31:33.0 2/12/2011: AVI Snap Path is: D:\Mame32\video
16:31:33.0 2/12/2011: Flyer Path is: D:\Mame32\flyers
16:31:33.0 2/12/2011: Cabinet Path is: D:\Mame32\cabinets
16:31:33.0 2/12/2011: Cabinet 3D Path: Not Found
16:31:33.0 2/12/2011: Title Path is: D:\Mame32\titles
16:31:33.0 2/12/2011: PCB Path: Not Found
16:31:33.0 2/12/2011: Artwork Preview Path: Not Found
16:31:33.0 2/12/2011: Panel Path is: D:\Mame32\cpanel
16:31:33.0 2/12/2011: Manual Path: Not Found
16:31:33.0 2/12/2011: Icon Path is: D:\Mame32\icons
16:31:33.0 2/12/2011: Marquee Path is: D:\Mame32\marquees
16:31:33.0 2/12/2011: Applying Language/Text
16:31:33.0 2/12/2011: Text/Language: English
16:31:33.1 2/12/2011: Loading Custom Emulators
16:31:33.1 2/12/2011: Loading Emulator Group 1: Games
16:31:33.1 2/12/2011: Could not load emulator group. Check emulators specified are valid.
16:31:33.1 2/12/2011: Loading Emulator Group 2: Laserdisc
16:31:33.1 2/12/2011: Using 2D Animations
16:31:33.1 2/12/2011: Retrieving resolution setting
16:31:33.1 2/12/2011: Using General Font: Trebuchet MS
16:31:33.1 2/12/2011: Using Title Font: Trebuchet MS
16:31:33.3 2/12/2011: Initialising Direct3D
16:31:33.4 2/12/2011: Applying GameEx is Loading Image
16:31:33.5 2/12/2011: Setting Resolution to 800x600 32 bit color
16:31:33.5 2/12/2011: Creating Surfaces
16:31:33.5 2/12/2011: Applying GameEx is Loading Image
16:31:33.6 2/12/2011: Setting Resolution to 800x600 32 bit color
16:31:33.6 2/12/2011: Creating Surfaces
16:31:33.6 2/12/2011: --**--
16:31:33.6 2/12/2011: Error: Error in the application.
16:31:33.6 2/12/2011: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
16:31:33.6 2/12/2011: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
16:31:33.6 2/12/2011: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
16:31:33.6 2/12/2011: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
16:31:33.6 2/12/2011: at ag.b(Boolean A_0, Boolean A_1, Boolean A_2)
16:31:33.6 2/12/2011: at ag.a(Boolean A_0, String A_1, Boolean A_2)
16:31:33.6 2/12/2011: at ag..ctor()
16:31:33.6 2/12/2011: Closing database connection
16:31:33.7 2/12/2011: Disposing Plugins
16:31:33.7 2/12/2011: GameEx is exiting with errors
16:31:33.7 2/12/2011: Deleting search cache
16:31:35.4 2/12/2011: ERRORS DETECTED: EXITING
16:31:35.5 2/12/2011: Bye
I seemingly are using a NVidia GeForce4 MX 440-SE video card. I googled and found / installed (what I think) was the latest driver but no joy (The error log is post that).
Appreciate any further input you might have.
Cheers
Stuart - you noted in your original post the following:
A few questions in addition to Adultery's:
1 - Did you resolve the quoted memory error? If not definitely get it fixed.
2 - What version of the nVidia driver did you install? (Latest stable release for your OS/GPU is 93.71)
3 - Are you running an "nlite" or other stripped-down version of XP on your system?
4 - What is your resolution set to & have you tried changing it?
One significant change with GameEx that you may wish to accustom yourself is that the old Configuration app (blue & white screens) support has been replaced by using the Setup WIzard, so please familiarize yourself as we may refer you to elements within it.
Hi Adultery,
DirectX version - 9.0c (4.09.0000.0904.
Adultery below is the DxDiag report if relevant:
System Information
Time of this report: 2/14/2011, 22:08:31
Machine name: MAME
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.100216-1441)
Language: English (Regional Setting: English)
System Manufacturer: GBT___
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: Intel® Pentium® 4 CPU 2.53GHz
Memory: 512MB RAM
Page File: 202MB used, 1046MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX 440-SE
Manufacturer: NVIDIA
Chip type: GeForce4 MX 440-SE
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0173&SUBSYS_00000000&REV_A3
Display Memory: 64.0 MB
Current Mode: 800 x 600 (16 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2006 12:22:00, 4527488 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/22/2006 12:22:00, 3994624 bytes
Device Identifier: {D7B71E3E-4233-11CF-2B47-0A2002C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0173
SubSys ID: 0x00000000
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24C5&SUBSYS_A0021458&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.6120 (English)
WHQL Logo'd: Yes
Date and Size: 6/27/2006 18:42:14, 3972672 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 26, 20
Static/Strm HW 3D Bufs: 26, 20
HW Memory: 0
Voice Management: No
EAX™ 2.0 Listen/Src: Yes, Yes
I3DL2™ Listen/Src: Yes, Yes
Sensaura™ ZoomFX™: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 00:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 23:00:00, 4736 bytes
Gameport Devices
+ Intel® 82801DB LPC Interface Controller - 24C0
| Matching Device ID: pci\ven_8086&dev_24c0
| Service: isapnp
| Driver: isapnp.sys, 8/17/2001 14:58:02, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 00:08:22, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 00:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 23:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 02:01:08, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/3/2004 23:58:34, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Failed gracefully
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech™ 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 47.0 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800JB-00CRA1
Drive: D:
Free Space: 110.6 GB
Total Space: 305.2 GB
File System: NTFS
Model: ST3320620A
Drive: F:
Model: HL-DT-ST CD-ROM GCR-8521B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 23:59:54, 49536 bytes
System Devices
Name: Intel® 82845G/GL/GE/PE/GV/E Processor to AGP Controller - 2561
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_03\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/4/2004 00:07:42, 42368 bytes
Name: Intel® 82845G/GL/GE/PE/GV/E Processor to I/O Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_03\3&13C0B0C5&0&00
Driver: n/a
Name: Intel® 82801DB/DBM USB2 Enhanced Host Controller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_50041458&REV_02\3&13C0B0C5&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 01:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:56:44, 7168 bytes
Name: Intel® 82801DB Ultra ATA Storage Controller - 24CB
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_24C21458&REV_02\3&13C0B0C5&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 14:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 23:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 23:59:44, 95360 bytes
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_24C21458&REV_02\3&13C0B0C5&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:38, 20480 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_A0021458&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 01:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 01:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 00:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 00:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 00:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6120 (English), 6/27/2006 18:42:14, 3972672 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0054 (English), 6/21/2006 06:42:44, 577536 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0062 (English), 6/21/2006 06:40:36, 18796544 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 14:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0062 (English), 6/21/2006 06:35:40, 10527744 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0009 (English), 6/8/2006 09:00:40, 143360 bytes
Driver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0003 (English), 11/18/2005 12:20:26, 217088 bytes
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_24C21458&REV_02\3&13C0B0C5&0&E9
Name: Intel® 82801DB/DBM SMBus Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_24C21458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_24C21458&REV_02\3&13C0B0C5&0&E8
Name: Intel® 82801DB LPC Interface Controller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 14:58:02, 35840 bytes
Name: Intel® 82801DB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_82\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 00:07:48, 68224 bytes
Name: Intel® PRO/1000 MT Network Connection
Device ID: PCI\VEN_8086&DEV_100E&SUBSYS_30138086&REV_02\4&1A671D0C&0&48F0
Driver: n/a
Name: ITE IT8211 ATA/ATAPI Controller
Device ID: PCI\VEN_1283&DEV_8212&SUBSYS_00011283&REV_10\4&1A671D0C&0&60F0
Driver: C:\WINDOWS\system32\DRIVERS\iteatapi.sys, 5.02.3790.1830 (English), 10/28/2005 17:11:00, 27648 bytes
Name: Multimedia Video Controller
Device ID: PCI\VEN_121A&DEV_0001&SUBSYS_00000000&REV_02\4&1A671D0C&0&10F0
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_10001458&REV_46\4&1A671D0C&0&38F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:58:30, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:58:30, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/18/2001 00:46:40, 6400 bytes
Name: NVIDIA GeForce4 MX 440-SE
Device ID: PCI\VEN_10DE&DEV_0173&SUBSYS_00000000&REV_A3\4&384EA2E1&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3994624 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 4527488 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 159810 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 212992 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5644288 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 7700480 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11060 (English), 10/22/2006 12:22:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5619712 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5255168 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3047424 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3203072 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 888832 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 2859008 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 2924544 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 2973696 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 1236992 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 1732608 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/22/2006 12:22:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 10/22/2006 12:22:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
Name: Silicon Image SiI 3112 SATARaid Controller
Device ID: PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_02\4&1A671D0C&0&50F0
Driver: C:\WINDOWS\system32\DRIVERS\SI3112r.sys, 1.00.0056.0000 (English), 1/12/2006 13:56:56, 102528 bytes
Driver: C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys, 1.00.0000.0011 (English), 11/1/2004 13:21:32, 10368 bytes
Driver: C:\WINDOWS\system32\SilSupp.cpl, 3.00.0021.0000 (English), 10/19/2005 13:17:00, 77824 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 23:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 23:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 23:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 23:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:46 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 00:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 82432 bytes
system.dll: 1.01.4322.2463 English Final Retail 11/18/2010 17:52:20 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/12/2011 16:23:36 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/11/2011 17:04:41 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/11/2011 17:04:42 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/11/2011 17:04:43 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/11/2011 17:04:43 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/11/2011 17:04:44 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/11/2011 17:04:44 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/11/2011 17:04:45 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/11/2011 17:04:46 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/11/2011 17:04:46 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/12/2011 16:23:36 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:37 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:37 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:37 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:38 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:35 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:36 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/12/2011 16:23:34 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 23:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 01:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 9/22/2004 19:46:02 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:26 733696 bytes
quartz.dll: 6.05.2600.3665 English Final Retail 2/6/2010 05:40:58 1291264 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 19:16:37 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.3610 English Final Retail 8/5/2009 20:11:47 204800 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:42 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:40 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:14 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:58 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:46 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:58 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:14 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:14 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 30720 bytes
msyuv.dll: 5.03.2600.3649 English Final Retail 11/28/2009 04:33:35 17920 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:48 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:00 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.01.4096.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3665
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.01.4096.0000
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.01.4096.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
CD+G BootStrap,0x00600000,0,0,karaoke.ax,
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3665
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3665
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3665
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3665
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3665
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0051
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Text Karaoke To Video Transform Filter,0x00600000,1,1,karaoke.ax,
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3665
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3665
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Text Karaoke Bootstrap Filter,0x00600000,0,0,karaoke.ax,
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3665
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3665
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3665
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3665
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.01.0001.0002
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
CD+G Parser,0x00600000,1,2,karaoke.ax,
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,DVobSub.ax,1.00.0000.0009
DirectVobSub (auto-loading version),0x00800002,2,1,DVobSub.ax,1.00.0000.0009
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AC3Filter,0x40000000,1,1,ac3filter.ax,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3665
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
CD+G 2 Video Transform Filter,0x00600000,1,1,karaoke.ax,
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.01.4096.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3665
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3665
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3665
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.3665
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3665
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.01.4096.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3665
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3665
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3665
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3665
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3665
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.01.4096.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3665
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3665
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3665
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3665
DSP Group TrueSpeech™,0x00200000,1,1,quartz.dll,6.05.2600.3665
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3665
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3665
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3665
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3665
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3665
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3665
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3665
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3665
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3665
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3665
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3665
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3665
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3665
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,18,2,,5.03.2600.2180
Draco,
1. No....no joy as yet with the (original) issue of the system not automatically updating. As mentioned Im currently running version 8.09 whilst I try and sort out 12.54, Was hoping once I got 12.54 operational that might resolved the update issue.
2.Yep thats the version I updated too.
3. Mate to the best of my knowledge the PC is running just a standard version of XP.
4.I assume your referring to the PC resolution which is 800x600 and not the (gameex resolution setting right? - which is the same in config).........I'm actually currently away but will check it on my return.
Thanks again for your help.
Hey Guys,
I just wanted to let you know I have been called overseas for work and wont return till the weekend. Once back - will follow up on the resolution matter and any other suggestions.
I am having the same issue. I received a Tankstick for Christmas and have been trying to build my arcade since. I was so excited I went out and bought an arcade cabinet. I've been pulling my hair out (what little I have) since.
I am running a dual core 2.8 with 2GB ram running XP SP3 32 bit. (I tried running Win7 64 bit but was receiving the video mode not supported errors so I formatted and started over with XP).
My video card is a Geforce 7600. I have tried newer drivers I have tried older drivers. When trying just to click on the mame executable it bluescreens. I tried downloading the 66.93 driver but the license screen pops up, I click agree and nothing happens. I tried on multiple machine so I'm guessing there is an issue with that link.
I am using a 27 inch TV with an rca cable to an svideo connector and then an svideo cable into the svideo port on the video card.
DirectX version is 9.0c. I tried figuring out where to tell video mode to use direct draw but I'm not having much luck.
Can someone point me in the right direction? I want to buy the full version but want to get the arcade functional before doing so.
Below is my log
09:40:50.5 2/19/2012: Opening Configuration File
09:40:50.6 2/19/2012: GameEx: Version 12.54: Starting Log
09:40:50.6 2/19/2012: Operating System Platform: Win32NT
09:40:50.6 2/19/2012: Operating System Name: Windows XP
09:40:50.6 2/19/2012: Operating System Version: 5.1.2600
09:40:50.6 2/19/2012: Running under Remote Desktop
09:40:50.6 2/19/2012: Intel® Pentium® 4 CPU 2.80GHz, 2046MB
09:40:50.6 2/19/2012: 2.81Ghz - 2 Cores or CPU's
09:40:50.6 2/19/2012: Running Randomize()
09:40:50.6 2/19/2012: Loading PlugIns
09:40:50.6 2/19/2012: Checking for applications to Launch On Startup
09:40:50.6 2/19/2012: Running Misc startup tasks
09:40:50.6 2/19/2012: Setting Menu types
09:40:50.6 2/19/2012: Getting Configuration Values
09:40:50.7 2/19/2012: Using Theme: Default - Galaxian V1
09:40:50.7 2/19/2012: Checking for alternate Image Directory for Theme: Default - Galaxian V1
09:40:50.7 2/19/2012: Using Images from theme: Default - Galaxian\MEDIA\
09:40:50.7 2/19/2012: Initialising Video/MNG DLL's
09:40:50.7 2/19/2012: GameEx will check for media insertion (may affect performance)
09:40:50.7 2/19/2012: Is Media Center running?
09:40:50.7 2/19/2012: Checking/Creating LCD Registry values
09:40:50.7 2/19/2012: Check Media Center Exit/Start Mode
09:40:50.7 2/19/2012: Media Center Mode 2
09:40:50.7 2/19/2012: Video previews on. Warning: Only recommended on modern systems
09:40:50.7 2/19/2012: Custom Game Device Input enabled: Getting custom codes
09:40:50.7 2/19/2012: Snap Delay set to: 2
09:40:50.7 2/19/2012: Get other settings
09:40:50.7 2/19/2012: Desktop set to Hide ICONS and set Background to Black
09:40:50.7 2/19/2012: Set: Find emulator artwork on best match basis
09:40:50.7 2/19/2012: Using DirectInput for keyboard input
09:40:50.7 2/19/2012: Start work for Form
09:40:50.7 2/19/2012: Getting Original Screen Size
09:40:50.7 2/19/2012: Opening Database Connection
09:40:50.9 2/19/2012: Initializing Component
09:40:51.0 2/19/2012: MAME Path is: C:\Emulators\MAME
09:40:51.0 2/19/2012: MAME EXE file is: mame.exe
09:40:51.0 2/19/2012: ROM Path is: C:\Roms\Arcade
09:40:51.0 2/19/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
09:40:51.0 2/19/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
09:40:51.0 2/19/2012: History.dat is located at: C:\GameEx\DATA\history.dat
09:40:51.0 2/19/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
09:40:51.0 2/19/2012: command.dat is located at: C:\GameEx\DATA\command.dat
09:40:51.0 2/19/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
09:40:51.1 2/19/2012: Loading Controls.ini map file
09:40:51.1 2/19/2012: Snap Path: Not Found
09:40:51.1 2/19/2012: Background Snap Path: Not Found
09:40:51.1 2/19/2012: AVI Snap Path: Not Found
09:40:51.1 2/19/2012: Flyer Path: Not Found
09:40:51.1 2/19/2012: Cabinet Path: Not Found
09:40:51.1 2/19/2012: Cabinet 3D Path: Not Found
09:40:51.1 2/19/2012: Title Path: Not Found
09:40:51.1 2/19/2012: PCB Path: Not Found
09:40:51.1 2/19/2012: Artwork Preview Path: Not Found
09:40:51.1 2/19/2012: Panel Path: Not Found
09:40:51.1 2/19/2012: Manual Path: Not Found
09:40:51.1 2/19/2012: Icon Path: Not Found
09:40:51.1 2/19/2012: Marquee Path: Not Found
09:40:51.1 2/19/2012: Applying Language/Text
09:40:51.1 2/19/2012: Text/Language: English
09:40:51.2 2/19/2012: Loading Custom Emulators
09:40:51.2 2/19/2012: Loading Emulator 1: [Arcade] Arcade (CPS-3)
09:40:51.2 2/19/2012: Loading Emulator 2: [Arcade] Arcade (FB Alpha)
09:40:51.2 2/19/2012: Loading Emulator 3: [Arcade] Arcade (MAME)
09:40:51.2 2/19/2012: Loading Emulator 4: [Arcade] Arcade (Mjolnir)
09:40:51.2 2/19/2012: Loading Emulator 5: [Arcade] Model 2 (Model2)
09:40:51.2 2/19/2012: Loading Emulator 6: [Arcade] Arcade (Nebula)
09:40:51.2 2/19/2012: Loading Emulator 7: [Arcade] Arcade (Raine)
09:40:51.2 2/19/2012: Loading Emulator 8: [Arcade] Arcade (WinKawaks)
09:40:51.2 2/19/2012: Loading Emulator 9: [Arcade] Arcade (ZiNc)
09:40:51.3 2/19/2012: Loading Emulator 10: [Arcade] Sammy Atomiswave (DEmul)
09:40:51.3 2/19/2012: Loading Emulator 11: [Arcade] Sega Naomi (DEmul)
09:40:51.3 2/19/2012: Loading Emulator 12: [Console] Atari 2600 (MESS)
09:40:51.3 2/19/2012: Loading Emulator 13: [Console] Atari 2600 (Stella)
09:40:51.3 2/19/2012: Loading Emulator 14: [Console] Atari 2600 (Z26)
09:40:51.3 2/19/2012: Loading Emulator 15: [Console] Atari 5200 (Atari++)
09:40:51.3 2/19/2012: Loading Emulator 16: [Console] Atari 5200 (Jum's A5200)
09:40:51.3 2/19/2012: Loading Emulator 17: [Console] Atari 5200 (MESS)
09:40:51.3 2/19/2012: Loading Emulator 18: [Console] Atari 7800 (MESS)
09:40:51.3 2/19/2012: Loading Emulator 19: [Console] Atari 7800 (ProSystem)
09:40:51.4 2/19/2012: Loading Emulator 20: [Console] Atari Jaguar (Virtual Jaguar)
09:40:51.4 2/19/2012: Loading Emulator 21: [Console] Bally Astrocade (MESS)
09:40:51.4 2/19/2012: Loading Emulator 22: [Console] Coleco Vision (ColEm)
09:40:51.4 2/19/2012: Loading Emulator 23: [Console] Coleco Vision (Meka)
09:40:51.4 2/19/2012: Loading Emulator 24: [Console] Coleco Vision (MESS)
09:40:51.4 2/19/2012: Loading Emulator 25: [Console] Coleco Vision (Virtual Colecovision)
09:40:51.4 2/19/2012: Loading Emulator 26: [Console] Commodore Amiga CD32 (WinUAE)
09:40:51.4 2/19/2012: Loading Emulator 27: [Console] Emerson Arcadia 2001 (WinArcadia)
09:40:51.4 2/19/2012: Loading Emulator 28: [Console] Fairchild Channel F (MESS)
09:40:51.4 2/19/2012: Loading Emulator 29: [Console] Fujitsu FM-Towns Marty (UNZ)
09:40:51.4 2/19/2012: Loading Emulator 30: [Console] GCE Vectrex (MESS)
09:40:51.4 2/19/2012: Loading Emulator 31: [Console] Magnavox Odyssey (ODYEmu)
09:40:51.4 2/19/2012: Loading Emulator 32: [Console] Magnavox Odyssey 2 (O2EM)
09:40:51.5 2/19/2012: Loading Emulator 33: [Console] Mattel Intellivision (Bliss)
09:40:51.5 2/19/2012: Loading Emulator 34: [Console] Mattel Intellivision (Nostalgia)
09:40:51.5 2/19/2012: Loading Emulator 35: [Console] Microsoft Xbox (Cxbx)
09:40:51.5 2/19/2012: Loading Emulator 36: [Console] NEC PC-FX (MagicFX)
09:40:51.5 2/19/2012: Loading Emulator 37: [Console] NEC PC-FX (mednafen)
09:40:51.5 2/19/2012: Loading Emulator 38: [Console] NEC SuperGrafx (mednafen)
09:40:51.5 2/19/2012: Loading Emulator 39: [Console] NEC TurboGrafx CD (MagicEngine)
09:40:51.5 2/19/2012: Loading Emulator 40: [Console] NEC TurboGrafx CD (mednafen)
09:40:51.5 2/19/2012: Loading Emulator 41: [Console] NEC TurboGrafx CD (Ootake)
09:40:51.5 2/19/2012: Loading Emulator 42: [Console] NEC TurboGrafx-16 (MagicEngine)
09:40:51.5 2/19/2012: Loading Emulator 43: [Console] NEC TurboGrafx-16 (mednafen)
09:40:51.5 2/19/2012: Loading Emulator 44: [Console] NEC TurboGrafx-16 (Ootake)
09:40:51.5 2/19/2012: Loading Emulator 45: [Console] Nintendo GameCube (Dolphin)
09:40:51.5 2/19/2012: Loading Emulator 46: [Console] Nintendo N64 (1964)
09:40:51.5 2/19/2012: Loading Emulator 47: [Console] Nintendo N64 (Project64)
09:40:51.5 2/19/2012: Loading Emulator 48: [Console] Nintendo NES (FCE Ultra)
09:40:51.5 2/19/2012: Loading Emulator 49: [Console] Nintendo NES (Jnes)
09:40:51.6 2/19/2012: Loading Emulator 50: [Console] Nintendo NES (mednafen)
09:40:51.6 2/19/2012: Loading Emulator 51: [Console] Nintendo NES (MESS)
09:40:51.6 2/19/2012: Loading Emulator 52: [Console] Nintendo NES (Nessie)
09:40:51.6 2/19/2012: Loading Emulator 53: [Console] Nintendo NES (Nestopia)
09:40:51.6 2/19/2012: Loading Emulator 54: [Console] Nintendo NES (RockNES)
09:40:51.6 2/19/2012: Loading Emulator 55: [Console] Nintendo NES (VirtuaNES)
09:40:51.6 2/19/2012: Loading Emulator 56: [Console] Nintendo SNES (BSNES)
09:40:51.6 2/19/2012: Loading Emulator 57: [Console] Nintendo SNES (MESS)
09:40:51.6 2/19/2012: Loading Emulator 58: [Console] Nintendo SNES (SNEeSe)
09:40:51.6 2/19/2012: Loading Emulator 59: [Console] Nintendo SNES (Snes9x)
09:40:51.6 2/19/2012: Loading Emulator 60: [Console] Nintendo SNES (SNESGT)
09:40:51.6 2/19/2012: Loading Emulator 61: [Console] Nintendo SNES (ZSNES)
09:40:51.6 2/19/2012: Loading Emulator 62: [Console] Nintendo Wii (Dolphin)
09:40:51.7 2/19/2012: Loading Emulator 63: [Console] Sega 32x (Fusion)
09:40:51.7 2/19/2012: Loading Emulator 64: [Console] Sega 32x (GENS+)
09:40:51.7 2/19/2012: Loading Emulator 65: [Console] Sega CD (Fusion)
09:40:51.7 2/19/2012: Loading Emulator 66: [Console] Sega CD (GENS+)
09:40:51.7 2/19/2012: Loading Emulator 67: [Console] Sega Dreamcast (nullDC)
09:40:51.7 2/19/2012: Loading Emulator 68: [Console] Sega Genesis (Fusion)
09:40:51.7 2/19/2012: Loading Emulator 69: [Console] Sega Genesis (GENS+)
09:40:51.7 2/19/2012: Loading Emulator 70: [Console] Sega Genesis (Gens32 Surreal)
09:40:51.7 2/19/2012: Loading Emulator 71: [Console] Sega Master System (Dega)
09:40:51.7 2/19/2012: Loading Emulator 72: [Console] Sega Master System (Fusion)
09:40:51.7 2/19/2012: Loading Emulator 73: [Console] Sega Master System (GENS+)
09:40:51.7 2/19/2012: Loading Emulator 74: [Console] Sega Master System (Meka)
09:40:51.7 2/19/2012: Loading Emulator 75: [Console] Sega Saturn (SSF)
09:40:51.7 2/19/2012: Loading Emulator 76: [Console] Sega Saturn (Yabause)
09:40:51.7 2/19/2012: Loading Emulator 77: [Console] SNK Neo-Geo (Nebula)
09:40:51.7 2/19/2012: Loading Emulator 78: [Console] SNK Neo-Geo (WinKawaks)
09:40:51.7 2/19/2012: Loading Emulator 79: [Console] SNK Neo-Geo CD (Nebula)
09:40:51.7 2/19/2012: Loading Emulator 80: [Console] SNK Neo-Geo CD (neocd)
09:40:51.7 2/19/2012: Loading Emulator 81: [Console] SNK Neo-Geo CD (NeoGeo CDZ)
09:40:51.8 2/19/2012: Loading Emulator 82: [Console] SNK Neo-Geo CD (NeoRaine)
09:40:51.8 2/19/2012: Loading Emulator 83: [Console] Sony Playstation (ePSXe)
09:40:51.8 2/19/2012: Loading Emulator 84: [Console] Sony Playstation (pSX)
09:40:51.8 2/19/2012: Loading Emulator 85: [Console] Sony Playstation (Xebra)
09:40:51.8 2/19/2012: Loading Emulator 86: [Console] Sony Playstation 2 (PCSX2)
09:40:51.8 2/19/2012: Loading Emulator 87: [Fruit] Fruit (BFM)
09:40:51.8 2/19/2012: Loading Emulator 88: [Fruit] Fruit (MFME)
09:40:51.8 2/19/2012: Loading Emulator 89: [Handheld] Atari Lynx (Handy)
09:40:51.8 2/19/2012: Loading Emulator 90: [Handheld] Atari Lynx (mednafen)
09:40:51.8 2/19/2012: Loading Emulator 91: [Handheld] Bandai WonderSwan (mednafen)
09:40:51.8 2/19/2012: Loading Emulator 92: [Handheld] Bandai WonderSwan Color (mednafen)
09:40:51.8 2/19/2012: Loading Emulator 93: [Handheld] Bandai WonderSwan Color (Oswan)
09:40:51.8 2/19/2012: Loading Emulator 94: [Handheld] Entex Adventure Vision (MESS)
09:40:51.8 2/19/2012: Loading Emulator 95: [Handheld] Nintendo DS (DeSmuME)
09:40:51.8 2/19/2012: Loading Emulator 96: [Handheld] Nintendo Game Boy (BGB)
09:40:51.9 2/19/2012: Loading Emulator 97: [Handheld] Nintendo Game Boy (mednafen)
09:40:51.9 2/19/2012: Loading Emulator 98: [Handheld] Nintendo Game Boy (VisualBoyAdvance)
09:40:51.9 2/19/2012: Loading Emulator 99: [Handheld] Nintendo Game Boy Advance (mednafen)
09:40:51.9 2/19/2012: Loading Emulator 100: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
09:40:51.9 2/19/2012: Loading Emulator 101: [Handheld] Nintendo Game Boy Color (BGB)
09:40:51.9 2/19/2012: Loading Emulator 102: [Handheld] Nintendo Game Boy Color (mednafen)
09:40:51.9 2/19/2012: Loading Emulator 103: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
09:40:51.9 2/19/2012: Loading Emulator 104: [Handheld] Nintendo Super Game Boy (BGB)
09:40:51.9 2/19/2012: Loading Emulator 105: [Handheld] Nintendo Virtual Boy (Reality Boy)
09:40:51.9 2/19/2012: Loading Emulator 106: [Handheld] Nintendo Virtual Boy (Red Dragon)
09:40:51.9 2/19/2012: Loading Emulator 107: [Handheld] Sega Game Gear (Dega)
09:40:51.9 2/19/2012: Loading Emulator 108: [Handheld] Sega Game Gear (Fusion)
09:40:51.9 2/19/2012: Loading Emulator 109: [Handheld] Sega Game Gear (GENS+)
09:40:51.9 2/19/2012: Loading Emulator 110: [Handheld] Sega Game Gear (Meka)
09:40:52.0 2/19/2012: Loading Emulator 111: [Handheld] Sega Game Gear (MESS)
09:40:52.0 2/19/2012: Loading Emulator 112: [Handheld] SNK Neo-Geo Pocket (mednafen)
09:40:52.0 2/19/2012: Loading Emulator 113: [Handheld] SNK Neo-Geo Pocket (NeoPop)
09:40:52.0 2/19/2012: Loading Emulator 114: [Handheld] SNK Neo-Geo Pocket Color (mednafen)
09:40:52.0 2/19/2012: Loading Emulator 115: [HandHeld] Sony PSP (PCSP)
09:40:52.0 2/19/2012: Loading Emulator 116: [PC] Apple IIc (MESS)
09:40:52.0 2/19/2012: Loading Emulator 117: [PC] Commodore 128 (WinVice)
09:40:52.0 2/19/2012: Loading Emulator 118: [PC] Commodore 64 (CCS64)
09:40:52.0 2/19/2012: Loading Emulator 119: [PC] Commodore 64 (WinVice)
09:40:52.0 2/19/2012: Loading Emulator 120: [PC] Commodore Amiga (DemoBase)
09:40:52.0 2/19/2012: Loading Emulator 121: [PC] Commodore Amiga (GameBase)
09:40:52.1 2/19/2012: Loading Emulator 122: [PC] Commodore Amiga (SPS)
09:40:52.1 2/19/2012: Loading Emulator 123: [PC] Commodore Amiga (WHDLoad)
09:40:52.1 2/19/2012: Loading Emulator 124: [PC] Commodore Amiga (WinUAE)
09:40:52.1 2/19/2012: Loading Emulator 125: [PC] Commodore CBM-II (WinVice)
09:40:52.1 2/19/2012: Loading Emulator 126: [PC] Commodore PET (WinVice)
09:40:52.1 2/19/2012: Loading Emulator 127: [PC] Commodore PLUS4 (WinVice)
09:40:52.1 2/19/2012: Loading Emulator 128: [PC] Commodore VIC20 (WinVice)
09:40:52.1 2/19/2012: Loading Emulator 129: [PC] MGT Sam Coupe (SimCoupe)
09:40:52.1 2/19/2012: Loading Emulator 130: [PC] Microsoft DOS (DOSBox)
09:40:52.1 2/19/2012: Loading Emulator 131: [PC] Microsoft MSX (blueMSX)
09:40:52.2 2/19/2012: Loading Emulator 132: [PC] Microsoft MSX (MESS)
09:40:52.2 2/19/2012: Loading Emulator 133: [PC] Scumm (ScummVM)
09:40:52.2 2/19/2012: Loading Emulator 134: [PC] Sinclair ZX Spectrum (Spectaculator)
09:40:52.2 2/19/2012: Loading Emulator 135: [Pinball] Future Pinball
09:40:52.2 2/19/2012: Loading Emulator 136: [Pinball] Visual Pinball
09:40:52.2 2/19/2012: Loading Emulator 137: [Pinball] Visual PinMAME
09:40:52.2 2/19/2012: Using 2D Animations
09:40:52.2 2/19/2012: Retrieving resolution setting
09:40:52.2 2/19/2012: Using General Font: HandelGothic BT
09:40:52.2 2/19/2012: Using Title Font: HandelGothic BT
09:40:52.2 2/19/2012: GameEx will try to reduce CPU usage
09:40:52.2 2/19/2012: Initialising Direct3D
09:40:52.5 2/19/2012: Creating Surfaces
09:40:52.7 2/19/2012: --**--
09:40:52.7 2/19/2012: Error: Error in the application.
09:40:52.7 2/19/2012: at Microsoft.DirectX.Direct3D.Manager.GetDeviceCaps(Int32 adapter, DeviceType deviceType)
09:40:52.7 2/19/2012: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
09:40:52.7 2/19/2012: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
09:40:52.7 2/19/2012: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
09:40:52.7 2/19/2012: at ag.b(Boolean A_0, Boolean A_1, Boolean A_2)
09:40:52.7 2/19/2012: at ag.a(Boolean A_0, String A_1, Boolean A_2)
09:40:52.7 2/19/2012: at ag..ctor()
09:40:52.7 2/19/2012: Closing database connection
09:40:52.7 2/19/2012: Disposing Plugins
09:40:52.7 2/19/2012: GameEx is exiting with errors
09:40:52.9 2/19/2012: ERRORS DETECTED: EXITING
09:40:53.4 2/19/2012: Bye
You may want to start here with attempting to troubleshoot and change your DirectDraw settings. Make sure that you have the most recent nVidia driver for your GPU and OS - I found it here.
I loaded the latest driver with the clean install of XP. I started using older drivers when the latest didn't work. I will try again and post the results. Thanks for the response.
Keep in mind that the latest drivers with XP may not always be the latest from the manufacturer. XP driver support through Windows updates has been almost non-existent and all support from Microsoft ends April 2014.
True. The driver was downloaded from NVidia.
So I realize the computer is taking the driver however I only have 1024 x 768 16bit as an option and it's reading the TV as a generic monitor.. I tried 2 different video cards (both nvidia 7600 and 5700) and used driver cleaner pro after switching drivers ARRRGH!
The thing is at one point Gameex was working (back in early January) but the games wasn't working so I've uninstalled and reinstalled Gameex and Mame since. So I know it worked at one point.
I really don't want to wipe and reinstall again.
I think that a total wipe and reinstall of your OS is not necessary unless you are using an nlite'd or similar unofficial build of XP. You need to be able to express more than 16-bit color which I know is possible with a TV as a monitor. I am not certain about using driver cleaner pro.
Hmmmm. It worked before. So I know it is capable of working (at least bring up the games menu that's as far as I got it working). This one has me puzzled.
Oh and my XP is real.
Well crap. I figured out I only have the 1 1024 x 768 setting because I am remoted into the system. On the TV it's hard to navigate windows so I was remoting in to try and do the configuring. Guess I can't do that. I'll reload the driver again since I just switched back to the 7600.
Still doesn't answer why direct X is not recognizing the video card though
You may have to go into the display advanced settings to tinker with the DirectX/DirectDraw toggle.
For your tankstick, check out this thread guy.
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
