I recently installed a new monitor in my setup as the old tube finally died. After installing the new monitor I upgraded to the latest gameex. Now when running gameex I notice that the mouse pauses and jumps around (sometimes returning to where I started). The keyboard navigation seems to work fine.
I am running the windows 7/64.I am also unsure of the version of gameex I was running but it had been a while since I upgraded.
I hope I am clear enough on my explanation.
Any ideas?
Sounds like it may be a display driver issue. Have you confirmed that you have the latest video drivers and correct video settings for the new monitor?
That is a good idea but wouldn't it effect how the mouse works in windows? It is almost as if something is lagging down the app in a long operation. I would have to do some additional testing but It is almost as if it happens when gameex is loading the screensshots or playing sounds.
Touchscreen setting is not enabled.
I did some additional tests. If I move the mouse around in open area it works fine without any delays. It is when I need to mouse over something that it has issues.
Please provide copies of your gameex.ini and log.txt files as previously requested and we will be glad to try to further diagnose the cause for you. Thanks!
Tom requested the log file (indirectly). I wanted a copy of the gameex.ini file - not previously asked for but asked for just the same. :) Thanks for providing both.
I noticed in the log you are running a plugin of your own creation called The Controlinator. Have you tried disabling the plugin, starting GameEx, and test to see if you have the same behavior? Otherwise, I noticed that your mouse and trackball settings are the same as mine, yet I am not encountering the issue that you are. Of course, I am running on version 12.50 of GameEx and it may be worth your while to upgrade to the latest version.
I was working on this last night and tried removing the plugin and I couldn't reproduce it. I tried putting the plugin back in and I still couldn't reproduce it. I think the theme got changed as well...not sure how that happened as I don't recall doing anything. I will chalk this up to something weird.
Does your plugin use a timer event?
No. All my plugin does is make the P1 & P2 controls control P1 when launching a game. I use it so that when playing a two player (alternating turns) game you don't need to move away from the machine to allow the second player to use the controls. Even when playing by myself I like to use player two as it's joystick is more in the middle of the machine and more like the real thing.
