Is it possible to port over full screen when running two monitors from one video card?? Thank you and Happy Thanksgiving!!
I run two monitors from a single card and GameEx fullscreen with no problem on one or the other.
^--- +1!
Sorry-maybe I was not clear..did you do hardware or software to enable this?? Thanks!
What do you mean? Windows handles dual displays and GameEx also manipulates the 2nd monitor.
GameEx setting is what I am inquiring about..forgot what does that! Thanks!
Look for Run on Second Monitor under Display Settings within the Setup Wizard.
Exactly what I was looking for! Thanks! I am just trying to get it to work-may be some limitations on this card I have. I can extend it but I still can't get GameEx on to extend on both screens, or clone, but that doesn't do what I need. Will keep messing with it! Thanks again for your help!
