Hi guys just trying to make my first cabinet and installed game ex. havent donated yet as just trying it. went to load and get the following error report.
18:04:54.6 15/09/2011: Opening Configuration File
18:04:54.6 15/09/2011: GameEx Lite: Version 12.12: Starting Log
18:04:54.6 15/09/2011: Operating System Platform: Win32NT
18:04:54.6 15/09/2011: Operating System Name: Windows XP
18:04:54.6 15/09/2011: Operating System Version: 5.1.2600
18:04:54.6 15/09/2011: Checking for versions of .net Framework installed
18:04:54.6 15/09/2011: .net Framework 2.0 Installed
18:04:54.6 15/09/2011: Intel® Pentium® 4 CPU 2.26GHz, 511MB
18:04:54.6 15/09/2011: 2.26Ghz
18:04:54.6 15/09/2011: Running Randomize()
18:04:54.6 15/09/2011: Checking for applications to Launch On Startup
18:04:54.6 15/09/2011: Running Misc startup tasks
18:04:54.6 15/09/2011: Setting Menu types
18:04:54.6 15/09/2011: Getting Configuration Values
18:04:54.6 15/09/2011: Using Theme: Default - Media Center
18:04:54.6 15/09/2011: Checking for alternate Image Directory for Theme: Default - Media Center
18:04:54.6 15/09/2011: Using Images from theme: Default - Media Center V1\MEDIA\
18:04:54.6 15/09/2011: Launching HideOS.exe
18:04:54.6 15/09/2011: Initialising Video/MNG DLL's
18:04:54.6 15/09/2011: Hiding Taskbar
18:04:54.7 15/09/2011: Is Media Center running?
18:04:54.7 15/09/2011: Checking/Creating LCD Registry values
18:04:54.7 15/09/2011: Check Media Center Exit/Start Mode
18:04:54.7 15/09/2011: Media Center Mode 2
18:04:54.7 15/09/2011: Snap Delay set to: 2
18:04:54.7 15/09/2011: Get other settings
18:04:54.7 15/09/2011: Desktop set to Hide ICONS and set Background to Black
18:04:54.7 15/09/2011: Set: Find emulator artwork on best match basis
18:04:54.7 15/09/2011: Start work for Form
18:04:54.7 15/09/2011: Getting Original Screen Size
18:04:54.7 15/09/2011: Opening Database Connection
18:04:54.8 15/09/2011: Initializing Component
18:04:54.9 15/09/2011: Retrieving resolution setting
18:04:54.9 15/09/2011: MAME Path is: C:\GameEx
18:04:54.9 15/09/2011: MAME EXE file is: Sleep.exe
18:04:54.9 15/09/2011: ROM Paths are: C:\GameEx\DEMO;C:\GameEx\DEMO\MAME
18:04:54.9 15/09/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
18:04:54.9 15/09/2011: controls.ini is located at: C:\GameEx\DATA\controls.ini
18:04:54.9 15/09/2011: History.dat is located at: C:\GameEx\DATA\history.dat
18:04:54.9 15/09/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
18:04:54.9 15/09/2011: command.dat is located at: C:\GameEx\DATA\command.dat
18:04:54.9 15/09/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
18:04:54.9 15/09/2011: Loading Controls.ini map file
18:04:54.9 15/09/2011: Snap Path is: C:\GameEx\DEMO\MAME\snaps
18:04:54.9 15/09/2011: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
18:04:54.9 15/09/2011: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
18:04:54.9 15/09/2011: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
18:04:54.9 15/09/2011: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
18:04:54.9 15/09/2011: Title Path is: C:\GameEx\DEMO\MAME\titles
18:04:54.9 15/09/2011: PCB Path: Not Found
18:04:54.9 15/09/2011: Artwork Preview Path: Not Found
18:04:54.9 15/09/2011: Panel Path is: C:\GameEx\DEMO\MAME\cpanel
18:04:54.9 15/09/2011: Manual Path is: C:\GameEx\DEMO\MAME\manual
18:04:54.9 15/09/2011: Icon Path is: C:\GameEx\DEMO\MAME\icons
18:04:54.9 15/09/2011: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
18:04:54.9 15/09/2011: Applying Language/Text
18:04:54.9 15/09/2011: Text/Language: English
18:04:55.0 15/09/2011: Loading Custom Emulators
18:04:55.0 15/09/2011: Loading Emulator 1: [Arcade] Arcade (MAME)
18:04:55.0 15/09/2011: Loading Emulator 2: [Console] Nintendo NES (Nestopia)
18:04:55.0 15/09/2011: Loading Emulator 3: [Console] Nintendo SNES (Snes9x)
18:04:55.0 15/09/2011: Loading Emulator 4: [Console] Sega Genesis (Fusion)
18:04:55.0 15/09/2011: Loading Emulator 5: [Console] Sega Master System (Dega)
18:04:55.0 15/09/2011: Using Version 3 Themes Animations
18:04:55.0 15/09/2011: Using General Font: Trebuchet MS
18:04:55.0 15/09/2011: Using Title Font: Trebuchet MS
18:04:55.0 15/09/2011: GameEx will try to reduce CPU usage
18:04:55.1 15/09/2011: Initialising Direct3D
18:04:55.2 15/09/2011: Setting Resolution to 1280x1024 32 bit color
18:04:55.2 15/09/2011: Creating Surfaces
18:04:55.4 15/09/2011: Creating Primary Surface - Full Screen Mode
18:04:55.4 15/09/2011: Creating Back Buffer
18:04:55.4 15/09/2011: --**--
18:04:55.4 15/09/2011: Error: Error in the application.
18:04:55.5 15/09/2011: at Microsoft.DirectX.Direct3D.Texture..ctor(Device device, Int32 width, Int32 height, Int32 numLevels, Usage usage, Format format, Pool pool)
18:04:55.5 15/09/2011: at ᜎ.ᜂ()
18:04:55.5 15/09/2011: at ᜎ.ᜀ(Bitmap& A_0, Device& A_1)
18:04:55.5 15/09/2011: at ᜎ..ctor(Bitmap A_0, ᜆ A_1, ᜈ A_2)
18:04:55.5 15/09/2011: at a.ᜀ(ᜎ& A_0, String A_1, ᜆ A_2, Boolean A_3, Boolean A_4, Int32 A_5)
18:04:55.5 15/09/2011: at a.ᜀ(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
18:04:55.5 15/09/2011: at a.ᜁ(Boolean A_0, Boolean A_1, Boolean A_2)
18:04:55.5 15/09/2011: at a.ᜀ(Boolean A_0, String A_1, Boolean A_2)
18:04:55.5 15/09/2011: at a..ctor()
18:04:55.5 15/09/2011: Closing database connection
18:04:55.5 15/09/2011: GameEx is exiting with errors
18:04:56.9 15/09/2011: ERRORS DETECTED: EXITING
Any info would be grateful
Just ran the DirectX Diagnostic tool and says its a ati rage 128 pro ultra gl agp
Unless its a driver issue I am guessing its not supported. Sorry. You could however try running at a lower resolution and/or 16 bit colour.
It's not surprising that this issue occurs: the ATI Rage series was the predecessor of the Radeon ones, they were out starting from 1998 since the first years of 2000... too old in my opinion.
I remember when 128mb was a LOT of ram, not to mention 512! I agree with the other guys though, a new video card should be in your future plans. Preferably, an AGP or PCI-E if your motherboard supports it; PCI (or even ISA (if they still make them)) is gonna be too slow a thru-put for you to have any advantages. You can do a lot with GameEx on bare minimum, having flat 2D menus, no animations, no video previews, etc. But it's not work it IMO. GameEx is just more awesome with everything running full blast! But if you can't afford a new card in the forseeable future, I'd recommend cranking down those settings to see if you get any kind of better performance. If you're still getting that error message because of drivers/etc, you might just have to hold off on GameEx for awhile. :(
But ALWAYS make sure you have the latest drivers! It's not a hard thing to check. Here's the latest from ATI:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/WXPR1286133279.exe
via their website at:
http://support.amd.com/us/gpudownload/Pages/legacy-xp.aspx
Would definitely recommend increasing your system RAM. 512MB is a recommended minimum, optimal for XP would be 1GB. Replacing the video card would be good as well.
