Hi! :)
I have utilized the application instant sheller with set backgroud and wallpaper to black option active and now I canâ??t bring back starting settings because the background is all black. How can I do?
I use windows xp with service pack 3 like operative system.
Thank you
Ctrl-Alt-Delete should bring up Task Manager. From there, locate Instant Sheller and end program new task, Windows Explorer (see Tom's response below).
I have two icons setup on my desktop called "Run Explorer on Startup" and "Run GameEx on Startup". When I'm in maintenance mode I double click the former icon and when it's ready to go I launch the latter.
Here are the two scripts, just be aware if your GameEx install location is different you will have to edit it in Notepad.
ShellSwitch.zip
Thank you guys, now it is returned like the initial settings.. :)
Does your maintenanceâ??s system works also when the application instant sheller is active?
How can I copy these two registry keys from my operating system on my desktop to use them if necessary?
Thank you
