not in directly, but the in page 1 of input settings all the EDIT buttons crash when open them. The ones for custom controls
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
With the latest update
You may wish to use the Setup Wizard as the Advanced Configuration Editor is no longer supported. Please try your changes there and provide us with a copy of your complete log.txt file and gameex.ini file if you are still having problems after. Let us know if using the Setup Wizard resolves your issue. Thanks!
