Hmm I just had a look in my /media folder and I dont have the startbak.bmp, I do have the .png version and it works fine for me on multiple systems. Can you tell me if you have the .png version in your media folder
post-1355-0-75970300-1309442042_thumb.pn
Regards
Regards
Very odd,
Can you do me a favour and open that .png in photoshop (or whatever image editor you use) and save as the bmp in the same location
sure will
I am in the middle of updating my MAME list,so i will see if that worked in a bit
Unfortunately that did not work.Here is the new log
Can someone else give this theme a go and let me know the outcome?
Mesk: Can you upload the bmp and the theme.ini for me?
.:EDIT:.
15:09:48.6 6/30/2011: Applying GameEx is Loading Image
15:09:48.6 6/30/2011: ERROR when loading Image. Probably does not exist.
This theme does not employ a GameExIsLoading.png?
.:EDIT:.
If that function is disabled in the setup wiz then it should boot I would think.
.:EDIT:.
Sorry for the delay.crazy ass day! here they are
darkchampion.zip
OK mesk, do me a solid and delete (or move rather) your startbak.bmp and put this one in its place:
Let me know if it works for you or not.
Nope same problem.thanks for trying guys,ive given up on this theme
I tried it out on my side with the startbak.png file provided by Adultery and have no issues with it starting up or with navigation thus far. Correct me if I am wrong but shouldn't GEX pull from the default theme if it cannot find a file, whether it is a background or a logo missing in the selected theme?
EDIT: One thing I noticed when opening this theme is that the folder containing the theme Dark Champion - Carbon 720p is nested within another folder named Darkchampion - Carbon 720p.
@Mesk - did you extract this folder from within Darkchampion - Carbon 720p so that it is immediately following \gameex\themes\Dark Champion - Carbon 720p ? This may explain why GEx is not finding the startbak.png file because it needs to find the file under \gameex\themes\Dark Champion - Carbon 720p and not \gameex\themes\Darkchampion - Carbon 720p\Dark Champion - Carbon 720p.
Edited by Draco1962
Additional info
@Drac: Exactly right. Ha! I didn't notice that when I tested.
I am going to mark this as [RESOLVED] as I believe the issue was with the folder depth within the them itself as I previously noted.
@massop - can you correct this and coordinate with Tom to replace the current copy with the corrected copy?
Thanks! Appreciate the info!
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
