hi,
i think i have found an bug.. i have some snes-roms with screenshots.. these screenshots are making by zsnes.exe and ending with _0000.png.. gameex wont show all screenshots.. some screenshots working.. some not.. example: Ace wo Nerae! (ENG)_0000.png working.. Adventure Island_0000.png not working.. with an imageviewer all screenshots are okay..
some ideas?
Did you confirm that the image file is named exactly the same as the ROM?
yes.. sure.. zsnes used the romname for the screenshotname and added _0000.png
The added _0000.png is the problem. GameEx will try to match the screenshot to the closest name and its finding the screenshot some times.. The best way to ensure that GmeEx finds the correct screenshot is to have the screenshot have the exact same name as the rom.
You should give Skinny Match a shot. It will rename your artwork according to your rom name. Great little tool, made by Tempest.
thanks! :D
an slideshow with more as one screenshot is not possible.. like _001 _002 _003
