Is there a way to change which folder the setup wizard gets the logo's to use for a system.I use the blackglass theme.and I have added amny logo's myself,but when trying to select those logo's they are not there.it looks like it is only listing logo's that are in the default theme folder.I was only able to select my logo's by using the old advanced config utility,because with that you were able to actually type in the name of the logo while with the setup wizard it is a drop down arrow and you are not able to type in your choice.
Not really that big of a deal for me,but it may stump some newer users.just a heads up ;)
When I am using the Setup Wizard, I see the logos that are in the \MEDIA\LOGO folder of the theme I am using. Do you have yours setup the same or under a different path?
for some reason it seems to be using the logo;s that are in the default-default folder,IDK how,ive never changed it.
Only reason for that I'm aware of is it can't find your logos and is reverting to the default location.
Somehow it has lost its way - may need to delete cache files and restart GameEx. You can probably confirm your suspicions by looking at the log file before doing so.
it is only listing the logo's from default-default.only way i was able to use them was use the old advanced config and type them in.im going to update to 11.83 now and see if its any different
I have a custom theme I am using and to show the logos I have for that theme, I have to make sure they are named the exact name of the emulator or whatever. For Nintendo 64 the name is [Console] Nintendo 64, thus my png in the custom folder MEDIA, it has to be the same, [Console] Nintendo 64.png. Then it will show that icon for that system instead of the default-default icon.
So wait, your not putting the image name into the emu's config? In the Emulator Logo field?
:confused:
Ok it seems to work after updating to 11.83.Im using the black glass theme BTW.ok the original issue was when clicking the dropdown arrow for logo's under emulator setup it was only showing logo's from the default-default folder.my logo's(actually Draco's logo's,or ANY logo's I added myself)were not showing up as a choice.they are now.thanks for the help HK & all!
