I set MAME to auto save-state every time that I exit so that I could retain high scores. However, I am finding that this may not be worth the hassles that come along with it. For example, if I quit a game in mid-game, I will need to go back and finish that game out the next time I load it up. Right? Or am I missing something? There are a 1,000 different scenarios that could present themselves where this would be far less than ideal.
I think you will find your answer here. Save states are not supported by all games, you will return to where you left off if save states are supported by the game, however, not all save states are compatible between all versions of MAME.
Turn auto save off and just save manually when you want to.shift +f7,then choose a slot A-Z
Why the need for this anyway? Hiscore patch not hitting your hammer? ;)
Adultery,
What do you mean by "Hiscore patch not hitting your hammer?"
Its been awhile since I set up my machine, but my recollection was that there were only two ways to track high scores in Mame:
1. Compile your own version of Mame (not even sure what this means so it appears to be out of my leaugue)
2. Set up auto-save
Originally, I set up the auto save in Mame to track high scores. It worked well except that there were so many negatives I didn't count on (eg. you can't quit in the middle of a round of Golden Tee without finishing that round the next time you start up).
Is there any easier way to maintain high scores? I hate to keep losing my high score in Donkey Kong and I'm optimistic about this patch that you mention!
It's really quite easy to compile your own version of MAME using Headkaze's tool. This patch not only removes all your MAME nag screens but adds in hiscore support to games that didn't initially save your score. If you'd be interested in using the awesome patch, I can help you compile and have you up and running in no time. Just say the word and we can get started.
I've been using a custom compiled MAME version for ions and never even considered looking back. Try it, you'll like it! :)
OK, so let's get started!
1. Download the Mame Compiler from Headkaze's web site here. Install it to your computer.
2. Create a folder inside MingGW's directory named after your MAME version. For this we'll assume that it's MAME 0.142. So your directory will look like this:
C:/MingGW/Source/MAME0142
3. Grab the Hiscore patch for your version of MAME here. The version you need to compile this specific build is 142. Right click the link and save it to:
C:/MingGW/Patches/
4. Also snag the MAME source code here. In this case we aren't using DIFF patches so you need MAME 0.142s. Extract the file to your source folder you created earlier:
5. Run MAME Compiler. The MingGW folder should be:
C:/MingGW
Then select your folder you put the source code in using the Browse button next to the field for it in MAME Compiler:
6. Under the field for Diff Patch File, click the browse button to select the patch file (142.txt) you downloaded in Step 3, and click the Apply Patch button.
7. Under Compile Options leave the "Compile For" box set to "None". If you have a 64-bit OS on the machine you're compiling on, tick that box. If not, don't. Do the same for the "Dual Core" or "Quad Core" boxes. Leave the rest unticked.
NOTE: If you're compiling MAMEUI, the process is a bit different. I'll post alternate instructions if that's the version of MAME you use.
8. Click the GO! button. It takes a bit to compile, so go grab a beer and chillax for a bit.
If you followed these instructions, you should find your newly compiled MAME.EXE in the folder your source code is in. In this case it's:
9. Play it, enjoy it, love it! Also be proud to now have the functionality of nagless games and Hi Score support. ;)
.:EDIT:. I should also mention that if you're not already using MAME on your machine, you will need to download the vanilla MAME compile for the support files (ie chdman.exe and the other EXE's in that folder) since this only compiles MAME and not the other EXEs. ;)
Not much to change really, just need to apply the diff patch for MAME32. It's only one extra step unless you also use the MAME u updates.
If you set it up in default, it made a MAME Compiler 64 folder in your start menu. ;)
Ok, I followed all of your instructions. Next question, what do I need to change in GameEx in order for it to be aware of the newly compiled version of Mame? I thought that I would go into the Mame setup in GamEx and point it toward C:/MingGW/Source/MAME0142. However, when I tried that, GameEx was unable to load. I just keep getting frozen at the initial loading screen.
i just copy your new MAME.EXE over where the old one was and point GameEx at that.
Still stuck on the "Please wait while loading..." screen. When I run the task manager, it appears as if there is a procees running called "7-zip self extracting archive". If I terminate this process, the issue clears up. Any idea what this is or how I can stop it from happening?
Can you post your log file please?
04:54:13.9 6/24/2011: Opening Configuration File
04:54:13.9 6/24/2011: GameEx: Version 11.83: Starting Log
04:54:13.9 6/24/2011: Operating System Platform: Win32NT
04:54:13.9 6/24/2011: Operating System Name: Windows XP
04:54:13.9 6/24/2011: Operating System Version: 5.1.2600
04:54:13.9 6/24/2011: Checking for versions of .net Framework installed
04:54:13.9 6/24/2011: .net Framework 2.0 Installed
04:54:13.9 6/24/2011: AMD Athlon 64 Processor 3200+, 446MB
04:54:13.9 6/24/2011: 1.99Ghz
04:54:13.9 6/24/2011: Running Randomize()
04:54:14.0 6/24/2011: Loading PlugIns
04:54:14.0 6/24/2011: Checking for applications to Launch On Startup
04:54:14.0 6/24/2011: Running Misc startup tasks
04:54:14.0 6/24/2011: Setting Menu types
04:54:14.0 6/24/2011: Getting Configuration Values
04:54:14.0 6/24/2011: Using Theme: Default - Media Center
04:54:14.0 6/24/2011: Checking for alternate Image Directory for Theme: Default - Media Center
04:54:14.0 6/24/2011: Using Images from theme: Default - Media Center V1\MEDIA\
04:54:14.0 6/24/2011: Launching HideOS.exe
04:54:14.0 6/24/2011: Initialising Video/MNG DLL's
04:54:14.0 6/24/2011: GameEx will check for media insertion (may affect performance)
04:54:14.0 6/24/2011: Hiding Taskbar
04:54:14.0 6/24/2011: Is Media Center running?
04:54:14.0 6/24/2011: Checking/Creating LCD Registry values
04:54:14.0 6/24/2011: Check Media Center Exit/Start Mode
04:54:14.0 6/24/2011: Media Center Mode 2
04:54:14.0 6/24/2011: Video previews on. Warning: Only recommended on modern systems
04:54:14.0 6/24/2011: Snap Delay set to: 2
04:54:14.0 6/24/2011: Get other settings
04:54:14.0 6/24/2011: Desktop set to Hide ICONS and set Background to Black
04:54:14.0 6/24/2011: Set: Find emulator artwork on best match basis
04:54:14.0 6/24/2011: Start work for Form
04:54:14.0 6/24/2011: Getting Original Screen Size
04:54:14.0 6/24/2011: Opening Database Connection
04:54:14.2 6/24/2011: Initializing Component
04:54:14.3 6/24/2011: Retrieving resolution setting
04:54:14.3 6/24/2011: MAME Path is: C:\MAME
04:54:14.3 6/24/2011: MAME EXE file is: mame0142s.exe
04:54:14.4 6/24/2011: ROM Path is: F:\Mame Roms
04:54:14.4 6/24/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
04:54:14.4 6/24/2011: controls.ini is located at: C:\GameEx\data\controls.ini
04:54:14.4 6/24/2011: History.dat is located at: C:\GameEx\DATA\history.dat
04:54:14.4 6/24/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
04:54:14.4 6/24/2011: command.dat is located at: C:\GameEx\DATA\command.dat
04:54:14.4 6/24/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
04:54:14.9 6/24/2011: Loading Controls.ini map file
04:54:14.9 6/24/2011: Loading Custom Emulators
04:54:14.9 6/24/2011: Loading Emulator 1: [Console] Atari 2600 (Stella)
04:54:15.3 6/24/2011: Loading Emulator 2: [Console] Nintendo NES (Nestopia)
04:54:15.4 6/24/2011: Loading Emulator 3: [Console] Sega Genesis (GENS+)
04:54:16.0 6/24/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
04:54:16.2 6/24/2011: Loading Emulator 7: [Console] Nintendo SNES (ZSNES)
04:54:16.2 6/24/2011: Loading Emulator 8: [Console] Sony Playstation (ePSXe)
04:54:16.2 6/24/2011: Snap Path is: C:\Assets\MAME\Snaps
04:54:16.2 6/24/2011: AVI Snap Path: Not Found
04:54:16.2 6/24/2011: Flyer Path: Not Found
04:54:16.2 6/24/2011: Cabinet Path: Not Found
04:54:16.2 6/24/2011: Cabinet 3D Path: Not Found
04:54:16.2 6/24/2011: Title Path: Not Found
04:54:16.2 6/24/2011: PCB Path: Not Found
04:54:16.2 6/24/2011: Artwork Preview Path: Not Found
04:54:16.2 6/24/2011: Panel Path: Not Found
04:54:16.2 6/24/2011: Manual Path: Not Found
04:54:16.2 6/24/2011: Icon Path: Not Found
04:54:16.2 6/24/2011: Marquee Path: Not Found
04:54:16.3 6/24/2011: Using Version 3 Themes Animations
04:54:16.3 6/24/2011: Using General Font: Trebuchet MS
04:54:16.3 6/24/2011: Using Title Font: Trebuchet MS
04:54:16.3 6/24/2011: Initialising Direct3D
04:54:16.4 6/24/2011: Applying GameEx is Loading Image
04:54:16.4 6/24/2011: Setting Resolution to 1024x768 32 bit color
04:54:16.5 6/24/2011: Creating Surfaces
04:54:17.0 6/24/2011: Creating Primary Surface - Full Screen Mode
04:54:17.0 6/24/2011: Creating Back Buffer
04:54:17.0 6/24/2011: Loading graphic Surfaces
04:54:17.0 6/24/2011: Display is running at: 1024x768 32bit color, 60hz
04:54:17.1 6/24/2011: Creating Surfaces Misc and Dialogs
04:54:17.2 6/24/2011: Creating Surfaces Volume
04:54:17.2 6/24/2011: Creating Surfaces Arrows
04:54:17.2 6/24/2011: Creating Surfaces GameEXlogo Text
04:54:17.2 6/24/2011: Creating Surfaces Toolbar
04:54:17.2 6/24/2011: Creating Surfaces Backgrounds
04:54:17.2 6/24/2011: Creating Surfaces Toolbar Controls
04:54:17.2 6/24/2011: Creating Surfaces GameEx Logo
04:54:17.2 6/24/2011: Creating Surface Unselected
04:54:17.2 6/24/2011: Creating Surfaces Snaps
04:54:17.2 6/24/2011: Creating Surfaces Menu and List Bars
04:54:17.6 6/24/2011: Creating Fonts
04:54:17.6 6/24/2011: Creating Game Font
04:54:17.7 6/24/2011: Creating Game Font Faded
04:54:17.8 6/24/2011: Creating Title Font
04:54:17.8 6/24/2011: Restoring Title Font From Cache
04:54:18.1 6/24/2011: Creating Font Black
04:54:18.2 6/24/2011: Creating Font Black Small
04:54:18.2 6/24/2011: Fonts Created Succesfully
04:54:18.2 6/24/2011: 3MB Video Memory Used
04:54:18.2 6/24/2011: Initialising Bass Audio Library
04:54:18.2 6/24/2011: Creating instance of global keyboard hook
04:54:18.7 6/24/2011: Attempting to load game list
04:54:18.9 6/24/2011: Applying Language/Text
04:54:18.9 6/24/2011: Text/Language: Custom
04:54:18.9 6/24/2011: Running: mame0142s.exe -help
04:54:18.9 6/24/2011: Running: C: C:\MAME\mame0142s.exe -help > C:\MAME\help.txt
04:57:15.6 6/24/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
04:57:15.6 6/24/2011: Loading last used Game List
04:57:15.8 6/24/2011: Creating DirectSound Device
04:57:15.9 6/24/2011: Trying: Primary Sound Driver
04:57:15.9 6/24/2011: Loading Sound Files
04:57:15.9 6/24/2011: DirectSound Device Created Successfully
04:57:15.9 6/24/2011: Initialising DirectInput for Gamepad support
04:57:16.1 6/24/2011: Unable to create a joystick device
04:57:16.1 6/24/2011: Initializing MCE Remote
04:57:16.1 6/24/2011: Playing intro sound file
04:57:16.1 6/24/2011: Initialization OK! Starting GameEx!
04:57:16.1 6/24/2011: Testing Main Loop Once: Processing Frame
04:57:17.2 6/24/2011: Testing Main Loop Once: Main Loop ran successfully
04:57:40.5 6/24/2011: Validating: Emulator_1: Custom Background:
04:57:40.5 6/24/2011: Warning: Emulator_1: Custom Background Does not exist
04:57:40.5 6/24/2011: Validating: Emulator_1: Snap Path: C:\Assets\Atari 2600\Snaps
04:57:40.6 6/24/2011: Validating: Emulator_1: Control Panel Path: C:\Assets\Atari 2600\Controls
04:57:40.6 6/24/2011: Validating: Emulator_1: Database: [Console] Atari 2600
04:57:40.7 6/24/2011: Validating: Emulator_1: Title Snap Path: C:\Assets\Atari 2600\Titles
04:57:40.7 6/24/2011: Validating: Emulator_1: Box Art Path: C:\Assets\Atari 2600\Boxes
04:57:40.7 6/24/2011: Validating: Emulator_1: Cart Art Path: C:\Assets\Atari 2600\Cartridges
04:57:40.7 6/24/2011: Validating: Emulator_1: Manual Path: C:\Assets\Atari 2600\Manuals
04:57:40.7 6/24/2011: Validating: Emulator_2: Custom Background:
04:57:40.7 6/24/2011: Warning: Emulator_2: Custom Background Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo NES\Snaps
04:57:40.7 6/24/2011: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo NES\Controls
04:57:40.7 6/24/2011: Validating: Emulator_2: Database: [Console] Nintendo NES
04:57:40.7 6/24/2011: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo NES\Titles
04:57:40.7 6/24/2011: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo NES\Boxes
04:57:40.7 6/24/2011: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
04:57:40.7 6/24/2011: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo NES\Manuals
04:57:40.7 6/24/2011: Validating: Emulator_3: Custom Background:
04:57:40.7 6/24/2011: Warning: Emulator_3: Custom Background Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_3: Snap Path: C:\Assets\Sega Genesis\Snaps
04:57:40.7 6/24/2011: Validating: Emulator_3: Control Panel Path: C:\Assets\Sega Genesis\Controls
04:57:40.7 6/24/2011: Validating: Emulator_3: Database: [Console] Sega Genesis
04:57:40.7 6/24/2011: Validating: Emulator_3: Title Snap Path: C:\Assets\Sega Genesis\Titles
04:57:40.7 6/24/2011: Validating: Emulator_3: Box Art Path: C:\Assets\Sega Genesis\Boxes
04:57:40.7 6/24/2011: Validating: Emulator_3: Cart Art Path: C:\Assets\Sega Genesis\Cartridges
04:57:40.7 6/24/2011: Validating: Emulator_3: Manual Path: C:\Assets\Sega Genesis\Manuals
04:57:40.7 6/24/2011: Validating: Emulator_5: Custom Background:
04:57:40.7 6/24/2011: Warning: Emulator_5: Custom Background Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_5: Snap Path: C:\Assets\Atari 7800\Snaps
04:57:40.7 6/24/2011: Validating: Emulator_5: Control Panel Path: C:\Assets\Atari 7800\Controls
04:57:40.7 6/24/2011: Warning: Emulator_5: Control Panel Path Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_5: Database: [Console] Atari 7800
04:57:40.7 6/24/2011: Validating: Emulator_5: Title Snap Path: C:\Assets\Atari 7800\Titles
04:57:40.7 6/24/2011: Warning: Emulator_5: Title Snap Path Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_5: Box Art Path: C:\Assets\Atari 7800\Boxes
04:57:40.7 6/24/2011: Warning: Emulator_5: Box Art Path Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_5: Cart Art Path: C:\Assets\Atari 7800\Cartridges
04:57:40.7 6/24/2011: Warning: Emulator_5: Cart Art Path Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_5: Manual Path: C:\Assets\Atari 7800\Manuals
04:57:40.7 6/24/2011: Warning: Emulator_5: Manual Path Does not exist
04:57:40.7 6/24/2011: Validating: Emulator_7: Custom Background:
04:57:40.8 6/24/2011: Warning: Emulator_7: Custom Background Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_7: Snap Path: C:\Assets\Nintendo SNES\Snaps
04:57:40.8 6/24/2011: Validating: Emulator_7: Control Panel Path: C:\Assets\Nintendo SNES\Controls
04:57:40.8 6/24/2011: Warning: Emulator_7: Control Panel Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_7: Database: [Console] Nintendo SNES
04:57:40.8 6/24/2011: Validating: Emulator_7: Title Snap Path: C:\Assets\Nintendo SNES\Titles
04:57:40.8 6/24/2011: Warning: Emulator_7: Title Snap Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_7: Box Art Path: C:\Assets\Nintendo SNES\Boxes
04:57:40.8 6/24/2011: Warning: Emulator_7: Box Art Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_7: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
04:57:40.8 6/24/2011: Warning: Emulator_7: Cart Art Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_7: Manual Path: C:\Assets\Nintendo SNES\Manuals
04:57:40.8 6/24/2011: Warning: Emulator_7: Manual Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Custom Background:
04:57:40.8 6/24/2011: Warning: Emulator_8: Custom Background Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Snap Path: C:\Assets\Sony Playstation\Snaps
04:57:40.8 6/24/2011: Validating: Emulator_8: Control Panel Path: C:\Assets\Sony Playstation\Controls
04:57:40.8 6/24/2011: Warning: Emulator_8: Control Panel Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Database: [Console] Sony Playstation
04:57:40.8 6/24/2011: Validating: Emulator_8: Title Snap Path: C:\Assets\Sony Playstation\Titles
04:57:40.8 6/24/2011: Warning: Emulator_8: Title Snap Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Box Art Path: C:\Assets\Sony Playstation\Boxes
04:57:40.8 6/24/2011: Warning: Emulator_8: Box Art Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
04:57:40.8 6/24/2011: Warning: Emulator_8: Cart Art Path Does not exist
04:57:40.8 6/24/2011: Validating: Emulator_8: Manual Path: C:\Assets\Sony Playstation\Manuals
04:57:40.8 6/24/2011: Warning: Emulator_8: Manual Path Does not exist
04:57:40.8 6/24/2011: Warning: Emulator_8: MAPFile Does Not Exist
04:57:40.9 6/24/2011: Restoring Emulator from Cache
04:57:41.0 6/24/2011: Restoring Emulator Database From Cache
04:57:41.4 6/24/2011: Restoring Emulator from Cache
04:57:41.5 6/24/2011: Restoring Emulator Database From Cache
04:57:41.7 6/24/2011: Restoring Emulator from Cache
04:57:41.8 6/24/2011: Restoring Emulator Database From Cache
04:57:42.1 6/24/2011: Restoring Emulator from Cache
04:57:42.2 6/24/2011: Restoring Emulator Database From Cache
04:57:42.4 6/24/2011: Restoring Emulator from Cache
04:57:42.4 6/24/2011: Restoring Emulator Database From Cache
04:57:42.7 6/24/2011: Restoring Emulator from Cache
04:57:42.7 6/24/2011: No Database Data
04:58:16.3 6/24/2011: Writing Game List to disk
04:58:16.4 6/24/2011: Updating MAME Game List
04:58:16.4 6/24/2011: Running: C: C:\MAME\mame0142s.exe -listxml > C:\MAME\listinfo.dat
04:58:21.0 6/24/2011: Opening Listinfo.dat
04:58:22.5 6/24/2011: Reading ListInfo.dat
Even after I go into the task manager and 'end task' for the 7-zip self extracting archive, I am now getting frozen on the 'Updating Mame Game List' page.
Unless you renamed MAME.EXE to this, it's not right. ;)
To me it would seem that the user is using the source file instead of the binary.
Just what I was thinking. ;)
The instructions called for downloading the source code. Should I have downloaded the binary? I am thinking that I should completely remove Mame from my machine and try to start over?
The source file is the file needed when compiling. Once compiled it will compile a new MAME.exe. As stated in an earlier post, that's the file you need to copy over. Not the source file. Then you should be good to go. That explains the 7-zip process you're seeing as well since the source file starting when calling that file since it's a compressed file that contains all the source files needed and am sure causes problems because trying to run with incorrect parameters.
What a cluster-cuss! I should have just let it alone and lived without hi-scores. Do you agree with my suggestion - just remove all of Mame from my machine and start over with a clean download?
You shouldn't have to. But you can if you want. ;) Did you compile correctly? If so then just copy your MAME.exe to your MAME folder and use that exe in GameEx.
