[RESOLVED] Meka will not start up in fullscreen mode
Hi, I fairly new to Gameex and would appreciate help with adding other emulators now that I have MAME in good order on my cabinet. Thanks for all the help with that. I've added Stella successfully and I have Meka working for Colecovision games, but with one problem: the games do not start up in fullscreen. I have this option set up to work this way when I launch from Meka directly, but when I start from Gameex, I go to the Meka start page and have to manually select "fullscreen" from the "video" tab. Not the end of the world, but I figure there is a way to select the game from the Gameex menu and go right to the fullscreen rendering of the game.
I am using Windows XP, SP 2, Ultimarc Arcade VGA. I suspect this is a configuration problem and would appreciate your help.
Here is my config file:
[Emulator_11]
System=Coleco Vision
Category=Console
Emulator=Meka
Version=0.72
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/meka.7z
RequiredFiles=
Website=http://www.smspower.org/meka/
Info=Sega Game 1000 (SG-1000),Sega Computer 3000 (SC-3000),Sega Super Control Station (SF-7000),Sega Mark III (+ FM Unit),Sega Master System (SMS),Sega Game Gear (GG),ColecoVision (COLECO),Othello Multivision (OMV)
TitleText=Coleco Vision
StartPageName=Coleco Vision (Meka)
StartPageLogo=Coleco Vision
Command=MekaW.exe "[ROMPATH]\[ROMFILE]"
RomFilter=
Database=[Console] Coleco Vision
ConfigFile=[Mapping Off] Exit (Process Close)
MapFile=
RomPath=C:\Emulators\Meka\ColecoVision ROMs
SnapPath=C:\Assets\Coleco Vision\Snaps
TitlePath=C:\Assets\Coleco Vision\Titles
BoxPath=C:\Assets\Coleco Vision\Boxes
CartPath=C:\Assets\Coleco Vision\Cartridges
ManualPath=C:\Assets\Coleco Vision\Manuals
ControlPanelPath=C:\Assets\Coleco Vision\Controls
WorkingPath=C:\Emulators\Meka
MapKeys=True
WaitBeforeKeys=2000
SendKeys=%{enter}
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
My :runitgame.bat data is:
C:
CD "C:\Emulators\Meka"
MekaW.exe "C:\Emulators\Meka\ColecoVision ROMs\Burgertime (1982) (Data East) [!].rom"
I hope that is the information you need. Thanks so much for your help.
Murb
I don't use this emulator so this is untested but maybe try the following:
  • Click MAIN
  • Click Options
  • Check Switch to fullscreen mode after loading a game.
  • Click Close
Then try again. I would think this should be what you're looking for.
  • Click MAIN
  • Click Options
  • Click Close
Thanks for you help. I have that option checked in Mekaw (just double checked to make sure). When I run the game directly from the Mekaw program, the game comes up in a full screen. When I select the game from my menu in Gameex, I get a brief fullscreen view of the Mekaw start screen which quickly converts to a small window. I can go to the "video" selection at the top of this display and click on "fullscreen" to then get the game to fill the monitor. Not a huge deal but ideally the game would come up this way once I selected it from the Gameex menu. MAME and Stella work perfectly this way.
Thanks again for your assistance with this.
Murb
Murb
Ok. So that option is working from the GUI only and not the command-line? As mentioned I don't use this emulator so I guess I'll have to actually do some testing. But other option would be to use the SendKeys setting and just send Alt+Enter. I'll give directions on that if I can determine that the emulator can not run fullscreen from the command-line.
Ok. Here's what I came up with. Sorry, but had to download again and actually run it and test it on my machine. Steps are as follows:
  • Open mekaw.cfg file in notepad or other text editor
  • Scroll down to GRAPHICAL USER INTERFACE CONFIGURATION section
  • Change "start_in_gui = 1" to "start_in_gui = 0"
  • Click File and then Save
Thanks for all of your help. We are getting closer. After I made your suggested change, I get the colecovision game to come up in a fullscreen for about a second but then it converts to a small window. Your suggestion was successful in getting my selection from the Gameex menu to go directly to the game (and not to the main Mekaw screen), but for some reason it then converts to a small window.
I really appreciate you assistance. Any idea how to keep the game in fullscreen mode?
Thanks,
Murb
Thanks,
Murb
Are you using SendKeys or something? If not then please post your config.
I apologize, I seem to have contracted a computer virus. I can not start Gameex currently. Please allow me to get this resolved and I will then post the config file.
Thanks,
Mike
Edited by fRequEnCy
How ROMS are obtained is againt forum rules. Please refrain from doing this in the future. Post has been adjusted.
Thanks,
Mike
Sorry to hear about this. Hope you get it resolved. Will be here to help you when needed.
Hi, I'm back and virus free. Again, I truly appreciate all of your help. In the interim, I noted that when I started Mekaw outside of Gameex that it was now starting in a small window. In the Mekaw config file in the GUI video mode section, I changed the gui_video_driver to "auto" and now mekaw starts the gui in full screen. When I load a game, it stays in full screen. I thought that would fix the problem in Gameex as well, but no such luck. Since I change the
start_in_gui to 0, Gameex goes right to the game, but after initially showing the game briefly in full screen, it then converts to a window. This is the same size window as Mekaw was starting in prior to me changing the "gui_video_driver" from "auto_win" to "auto" as I noted above. For some reason, when I start Mekaw in Gameex it is reverting back to the small window.
Here is the Mekaw config file:
MEKA 0.72 - Configuration File
-----< VIDEO DRIVERS >------------------------------------------------------
This is a list of video/graphic card drivers available in this version
of Meka. Those are needed to create video modes in the MEKA.BLT file and
if you want to set a custom driver for the graphical user interface.
auto (Default / Fullscreen)
auto_win (Default / Windowed)
safe (Find any working mode)
directx (DirectX / Fullscreen)
directx_win (DirectX / Windowed)
directx_soft (DirectX Software / Fullscreen)
directx_safe (DirectX Safe)
directx_ovl (DirectX Overlay / Windowed)
gdi (GDI / Windowed)
-----< FRAME SKIPPING >-----------------------------------------------------
frameskip_mode = auto
frameskip_auto_speed = 60
frameskip_normal_speed = 1
-----< VIDEO >--------------------------------------------------------------
video_game_depth = 16
video_game_blitter = Fullscreen
(See MEKA.BLT file to configure blitters/fullscreen modes)
video_game_vsync = 0
video_game_triple_buffering = 1
video_game_page_flipping = 0
-----< INPUTS >--------------------------------------------------------------
(See MEKA.INP file to configure inputs sources)
-----< SOUND AND MUSIC >-----------------------------------------------------
sound_enabled = 1
sound_card = 3
sound_rate = 44100
(Set sound_card to -1 to be prompted to choose your soundcard again)
fm_enabled = no
fm_emulator = digital
(Available settings are 'none', 'opl' and 'digital'.
OPL is only available under DOS and Windows 95/98/ME if your soundcard
has an OPL chip. Digital emulator is slower but works everywhere.)
opl_speed = 4
(Increase opl_speed when using opl if you feel that FM music are partly skipped)
(Decrease opl_speed when using opl if you feel that FM music make things slow)
-----< GRAPHICAL USER INTERFACE VIDEO MODE >---------------------------------
gui_video_mode = 640x480
gui_video_depth = auto
gui_video_driver = auto
(Available video drivers are marked at the top of this file.
Please note that 'auto' does not always choose the fastest mode!)
gui_refresh_rate = auto
(Video mode refresh rate. Set 'auto' for default rate. Not all
drivers support non-default rate. Customized values then depends
on your video card and screen. Setting to 60 (Hz) is usually a
good thing as the screen will be refreshed at the same time as
the emulated systems.)
gui_vsync = 0
(enable vertical synchronisation for fast computers)
-----< GRAPHICAL USER INTERFACE CONFIGURATION >------------------------------
start_in_gui = 0
theme = Default
fb_width = 320
(File browser width, in pixel)
fb_height = 17
(File browser height, in number of files shown)
fb_uses_db = 1
fb_close_after_load = 1
fb_fullscreen_after_load = 1
last_directory = C:\\Emulators\\Meka\\ColecoVision ROMs
tile_viewer_displayed_tiles = 512
(Number of tiles displayed in tile viewer, 448 or 512. Usually, displaying
tiles over 448 shows garbage on SMS and GG, so the default is 448)
-----< MISCELLANEOUS OPTIONS >-----------------------------------------------
language = English
bios_logo = 1
(set to '0' to skip the Master System logo when loading a game)
rapidfire = 0
country = us/eur
(emulated machine country, either 'us/eur' or 'jap'
sprite_flickering = auto
(hardware sprite flickering emulator, either 'yes', 'no', or 'automatic'
tv_type = ntsc
(emulated TV type, either 'ntsc' or 'pal/secam'
show_product_number = 0
show_messages_fullscreen = 1
allow_opposite_directions = 0
screenshots_automatic_crop_align = 0
music_wav_filename_template = %s-%02d.wav
music_vgm_filename_template = %s-%02d.vgm
(see documentation for more information about templates)
music_vgm_log_accuracy = frame
(either 'frame' or 'sample')
-----< 3-D GLASSES EMULATION >-----------------------------------------------
3dglasses_mode = 2
('0' = show both sides and become blind)
('1' = play without 3-D Glasses, show only left side)
('2' = play without 3-D Glasses, show only right side)
('3' = uses real 3-D Glasses connected to COM port)
3dglasses_com_port = 1
(this is on which COM port the Glasses are connected. Either 1 or 2)
-----< EMULATION OPTIONS >---------------------------------------------------
iperiod = 228
iperiod_coleco = 228
iperiod_sg1000_sc3000 = 228
-----< DEBUGGING FUNCTIONNALITIES -------------------------------------------
debug_mode = 0
(set to 1 to permanently enable debug mode. you can also enable
it for a single session by starting MEKA with the /DEBUG parameter)
debugger_console_lines = 22
debugger_disassembly_lines = 14
debugger_disassembly_display_labels = 1
debugger_log = 1
memory_editor_lines = 16
memory_editor_columns = 16
(preferably make columns a multiple of 8)
-----< FACTS >---------------------------------------------------------------
nes_sucks = 1
Thanks a ton,
Murb
Please post your emulator config again as mentioned.
Sorry, here it is:
[Emulator_11]
Category=Console
Emulator=Meka
Version=0.72
Rating=
RequiredFiles=
TITLETEXT=Coleco Vision
STARTPAGENAME=Coleco Vision (Meka)
ROMFilter=
DATABASE=[Console] Coleco Vision
MAPFile=
MapKeys=True
WaitBeforeKeys=2000
SendKeys=%{enter}
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
GamesIn7Zips=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
RomsInFolders=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
UseDbName=
MergeSets=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
Thanks,
Murb
Please clear the WaitBeforeKeys and SendKeys settings as they are no longer required with the settings I mentioned above. That should be the fix. That's what I figured it was which is why I asked above. Hope that works.
That took care of it. Works like a charm. Thanks so much for all of your help.
Murb
No problem. Enjoy! Marking as [RESOLVED]!
