Krakerman Posted June 7, 2011 Share Posted June 7, 2011 1. I posted about this topic and boom my post disappeared wt*! Anyways enuff ranting 2. I was trying to request if at all possible if you can add more emulator groups to the setup wizard as five is a bit on the small size as the number of emulators are growing there is a need for more groups that we can easily setup. Right now if you want more than 5 you have to do it manually. 3. Also I mentioned this awhile back but when using groups to group emulators you can't have the last 5 games played within the emulator show even if you have it enabled within each emulator. Can this be added to groups at all?Thanks! Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 7, 2011 Share Posted June 7, 2011 1. I posted about this topic and boom my post disappeared wt*! Anyways enuff ranting 2. I was trying to request if at all possible if you can add more emulator groups to the setup wizard as five is a bit on the small size as the number of emulators are growing there is a need for more groups that we can easily setup. Right now if you want more than 5 you have to do it manually. 3. Also I mentioned this awhile back but when using groups to group emulators you can't have the last 5 games played within the emulator show even if you have it enabled within each emulator. Can this be added to groups at all?Thanks! It didn't disappear. It was moved to the request thread so that Tom can see it. Here it is. The request thread is a more appropriate place for it. In the general forums it will get lost and Tom may overlook it. I guess I could have left it as moved in the main forums but then again that would kind of defeat the purpose and not be as tidy. For requests, please post in the dedicated thread. Link to comment Share on other sites More sharing options...
Krakerman Posted June 7, 2011 Author Share Posted June 7, 2011 I thought it might of been moved, but I did a search for my post and it didn't find it. That is why I was baffled. Thanks for moving it so Tom could see it Link to comment Share on other sites More sharing options...
nullPointer Posted June 7, 2011 Share Posted June 7, 2011 2. I was trying to request if at all possible if you can add more emulator groups to the setup wizard as five is a bit on the small size as the number of emulators are growing there is a need for more groups that we can easily setup. Right now if you want more than 5 you have to do it manually. I would definitely second this request (although I know that this thread isn't the proper place to do so). My real reason for posting is to ask how you manually add more emulator groups. I haven't exceeded the limit of 5 yet, but as I continue to add more systems to GameEx I can definitely foresee that eventual possibility. I apologize in advance if I missed a post describing this process, but my search didn't turn up any promising leads. I guess what I'm really asking is what files need to be edited in order to accomplish this?3. Also I mentioned this awhile back but when using groups to group emulators you can't have the last 5 games played within the emulator show even if you have it enabled within each emulator. Can this be added to groups at all?I also wanted to point out that this component of the request didn't get included in the official requests thread. This would also be an awesome addition even if it's implemented separately from the above request. (Not sure if I'd be stepping on toes to simply carry this request over to the appropriate thread)Thanks! Link to comment Share on other sites More sharing options...
Krakerman Posted June 8, 2011 Author Share Posted June 8, 2011 Just went into the GameEx config file using WordPad and added a new entry then saved it. Example:[EmulatorGroup_6]Enabled=TrueSTARTPAGENAME=TITLETEXT=StartPageLogo=Emulators=ShowUnderEmulators=TrueJust fill in the blanks with your info. You can search for "Group" using WordPad's find feature. Then add like the entry above under [EmulatorGroup_5].Thats how I did it, but would be more user friendly if we had more available under the setup wizard. Link to comment Share on other sites More sharing options...
headkaze Posted June 8, 2011 Share Posted June 8, 2011 Just went into the GameEx config file using WordPad and added a new entry then saved it.Thanks for checking that out for us. I've just added support to the Setup Wizard but I need Tom to tell me the maximum number of groups GX supports.EDIT: Okay next release will have 30 emulator groups in the Setup Wizard. Link to comment Share on other sites More sharing options...
Krakerman Posted June 8, 2011 Author Share Posted June 8, 2011 Very kool! Thanks guys Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 8, 2011 Share Posted June 8, 2011 Thanks! Link to comment Share on other sites More sharing options...
nullPointer Posted June 8, 2011 Share Posted June 8, 2011 Awesome! Thanks for all the recent enhancements to the Setup Wizard headkaze! Link to comment Share on other sites More sharing options...
Draco1962 Posted June 8, 2011 Share Posted June 8, 2011 Before long I won't have need of the Advanced Config... thanks! Link to comment Share on other sites More sharing options...
headkaze Posted June 9, 2011 Share Posted June 9, 2011 Before long I won't have need of the Advanced Config... thanks!Is there any reason to still use the Advanced Config? If there is something missing from the Setup Wizard please let me know and I'll look into adding it. Link to comment Share on other sites More sharing options...
Draco1962 Posted June 9, 2011 Share Posted June 9, 2011 To be honest I can't think of any reason to use it - the changes you have made to the Setup Wizard are very complete from what I have seen. I know that sometimes it is easier to point someone to the Advanced Config because you can count to a specific page in the depth of the option being tweaked. That is probably more habit that anything. It may be preferable from a support standpoint to only have one app available that all use. I know that I will use Advanced Config when making changes while GameEx is loaded. If there was a way to integrate Setup Wizard access through GameEx to make changes on the fly without having to take it down, that would be an awesome enhancement. Link to comment Share on other sites More sharing options...
headkaze Posted June 10, 2011 Share Posted June 10, 2011 If there was a way to integrate Setup Wizard access through GameEx to make changes on the fly without having to take it down, that would be an awesome enhancement.There should be something like this in the next release Link to comment Share on other sites More sharing options...
Draco1962 Posted June 10, 2011 Share Posted June 10, 2011 Will give it a try and report back in the 11.76 thread! Thanks! Link to comment Share on other sites More sharing options...
