I got Project64 1.6 working great. I used advanced emulator config to have %{F4} be used when wanting to exit this emulator as that's what it wants to see to exit, and not the Escape key. The problem is that the escape key just seems to pause the emulator, and not exit. I can hit 'alt F4' on my keyboard and the emulator exits fine back to GameEx. But I won't have a keyboard on my cabinet, and not sure how to re-map my Escape key from my controller to 'alt F4' for just this emulator. Thank you very much!
Note: my GameEx worked great for years..but a crashed C drive lost all my config data, so now I seem to be a newbie at setting all this back up!...now I have a clone C drive to prevent this from happening in the future ;)
You should be able to selece MAPPING OFF [ALT+F4] from the Advanced Emulator Config on page 3 of the emulator config. :)
There may even be a config already for PJ64 in there.
I went where you said...and seen nothing for me to change no choice for MAPPING OFF [ALT+F4]
Page 3 is process wait page....
thanks for replying...should i post my config if it helps?
I did see a PJ64 config file...but it showed %{F4} as exit key??
which sounds right from what I read
Yeah that's it alright. That's the sendkeys code for ALT+F4. Enable it and save, and you should be good to go. And yes it was indeed page 4, not 3.
Sorry I was wrong about the exact verbage, I use PJ64 1.7 and ESC exits the emulator, so I don't need to use a special key code. :)
