  Reveal hidden contents
15:08:49.6 5/13/2011: GameEx: Version 11.72: Starting Log
15:08:49.6 5/13/2011: Operating System Platform: Win32NT
15:08:49.6 5/13/2011: Operating System Name: Windows 7
15:08:49.6 5/13/2011: Operating System Version: 6.1.7600
15:08:49.6 5/13/2011: Aero running
15:08:49.6 5/13/2011: Initializing Vista/Windows 7 volume control
15:08:49.6 5/13/2011: Checking for versions of .net Framework installed
15:08:49.6 5/13/2011: .net Framework 2.0 Installed
15:08:49.6 5/13/2011: .net Framework 3.0 Installed
15:08:49.6 5/13/2011: .net Framework 3.5 Installed
15:08:49.6 5/13/2011: Intel® Core™2 Quad CPU Q6600 @ 2.40GHz, 8126MB
15:08:49.6 5/13/2011: 2.39Ghz - 4 Cores or CPU's
15:08:49.6 5/13/2011: Running Randomize()
15:08:49.6 5/13/2011: Loading PlugIns
15:08:49.6 5/13/2011: Checking for applications to Launch On Startup
15:08:49.6 5/13/2011: Running Misc startup tasks
15:08:49.6 5/13/2011: Setting Menu types
15:08:49.6 5/13/2011: Opening Configuration File
15:08:49.6 5/13/2011: Getting Configuration Values
15:08:49.6 5/13/2011: Using Theme: Enter the Dragon
15:08:49.6 5/13/2011: Checking for alternate Image Directory for Theme: Enter the Dragon
15:08:49.6 5/13/2011: Initialising Video/MNG DLL's
15:08:49.6 5/13/2011: GameEx will check for media insertion (may affect performance)
15:08:49.6 5/13/2011: Is Media Center running?
15:08:49.6 5/13/2011: Checking/Creating LCD Registry values
15:08:49.6 5/13/2011: Check Media Center Exit/Start Mode
15:08:49.6 5/13/2011: Media Center Mode 2
15:08:49.6 5/13/2011: Video previews on. Warning: Only recommended on modern systems
15:08:49.6 5/13/2011: Snap Delay set to: 7
15:08:49.6 5/13/2011: Get other settings
15:08:49.6 5/13/2011: Desktop set to Hide ICONS and set Background to Black
15:08:49.6 5/13/2011: Set: Find emulator artwork on best match basis
15:08:49.6 5/13/2011: Start work for Form
15:08:49.6 5/13/2011: Getting Original Screen Size
15:08:49.6 5/13/2011: Opening Database Connection
15:08:49.7 5/13/2011: Initializing Component
15:08:49.7 5/13/2011: Retrieving resolution setting
15:08:49.7 5/13/2011: MAME Path is: C:\Emulators\MameUI64
15:08:49.7 5/13/2011: Model 2 Path Path is: C:\Emulators\Model 2
15:08:49.7 5/13/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
15:08:49.7 5/13/2011: Model 2 EXE file is: emulator_multicpu.exe
15:08:49.7 5/13/2011: Model 2 emulator with command line support detected
15:08:49.7 5/13/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
15:08:49.7 5/13/2011: MAME EXE file is: MameUI64.exe
15:08:49.7 5/13/2011: ROM Path is: E:\Roms\MAME\ROMS
15:08:49.7 5/13/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
15:08:49.7 5/13/2011: controls.ini is located at: C:\GameEx\data\controls.ini
15:08:49.7 5/13/2011: History.dat is located at: C:\GameEx\DATA\history.dat
15:08:49.7 5/13/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
15:08:49.7 5/13/2011: command.dat is located at: C:\GameEx\DATA\command.dat
15:08:49.7 5/13/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
15:08:49.7 5/13/2011: Loading Controls.ini map file
15:08:49.8 5/13/2011: Snap Path is: E:\Assets\MAME\snap
15:08:49.8 5/13/2011: AVI Snap Path: Not Found
15:08:49.8 5/13/2011: Flyer Path is: E:\Assets\MAME\flyers
15:08:49.8 5/13/2011: Cabinet Path: Not Found
15:08:49.8 5/13/2011: Cabinet 3D Path: Not Found
15:08:49.8 5/13/2011: Title Path is: E:\Assets\MAME\titles
15:08:49.8 5/13/2011: PCB Path is: E:\Assets\MAME\pcb
15:08:49.8 5/13/2011: Artwork Preview Path is: E:\Assets\MAME\artworkpreview
15:08:49.8 5/13/2011: Panel Path is: E:\Assets\MAME\cpanel
15:08:49.8 5/13/2011: Manual Path is: E:\Assets\MAME\manual
15:08:49.8 5/13/2011: Icon Path is: E:\Assets\MAME\icons
15:08:49.8 5/13/2011: Marquee Path is: E:\Assets\MAME\marquees
15:08:49.8 5/13/2011: Loading Custom Emulators
15:08:49.8 5/13/2011: Loading Emulator 1: Atari 5200
15:08:49.8 5/13/2011: Loading Emulator 2: Nintendo SNES
15:08:49.8 5/13/2011: Loading Emulator 3: Nintendo N64
15:08:49.8 5/13/2011: Using Version 3 Themes Animations
15:08:49.8 5/13/2011: Using General Font: Microsoft Sans Serif
15:08:49.8 5/13/2011: Using Title Font: Trebuchet MS
15:08:49.8 5/13/2011: Initialising Direct3D
15:08:49.8 5/13/2011: Applying GameEx is Loading Image
15:08:49.9 5/13/2011: Creating Surfaces
15:08:50.0 5/13/2011: Creating Primary Surface - Windowed Mode
15:08:50.0 5/13/2011: Creating Back Buffer
15:08:50.0 5/13/2011: Version 2 Theme being used. Loading.
15:08:50.0 5/13/2011: Loading Button Data
15:08:50.0 5/13/2011: Loading Font Data
15:08:50.0 5/13/2011: Loading Layout Data
15:08:50.0 5/13/2011: ----------
15:08:50.0 5/13/2011: Error: GameEx could not load your theme. Switching to default theme.
15:08:50.0 5/13/2011: Loading graphic Surfaces
15:08:50.0 5/13/2011: Display is running at: 1680x1050 32bit color, 60hz
15:08:50.1 5/13/2011: Creating Surfaces Misc and Dialogs
15:08:50.2 5/13/2011: Creating Surfaces Volume
15:08:50.2 5/13/2011: Creating Surfaces Arrows
15:08:50.2 5/13/2011: Creating Surfaces GameEXlogo Text
15:08:50.2 5/13/2011: Creating Surfaces Toolbar
15:08:50.2 5/13/2011: Creating Surfaces Backgrounds
15:08:50.2 5/13/2011: Creating Surfaces Toolbar Controls
15:08:50.2 5/13/2011: Creating Surfaces GameEx Logo
15:08:50.2 5/13/2011: Creating Surface Unselected
15:08:50.2 5/13/2011: Creating Surfaces Snaps
15:08:50.2 5/13/2011: Creating Surfaces Menu and List Bars
15:08:50.3 5/13/2011: Creating Fonts
15:08:50.3 5/13/2011: Creating Game Font
15:08:50.5 5/13/2011: Creating Game Font Faded
15:08:50.7 5/13/2011: Creating Title Font
15:08:50.7 5/13/2011: Restoring Title Font From Cache
15:08:50.9 5/13/2011: Creating Font Black
15:08:50.9 5/13/2011: Creating Font Black Small
15:08:51.0 5/13/2011: Fonts Created Succesfully
15:08:51.0 5/13/2011: Initialising Bass Audio Library
15:08:51.0 5/13/2011: Creating instance of global keyboard hook
15:08:51.0 5/13/2011: --**--
15:08:51.0 5/13/2011: Error: C:\GameEx\themes\Default - Media Center\MEDIA\StartBak.bmp
15:08:51.1 5/13/2011: at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
15:08:51.1 5/13/2011: at System.Drawing.Image.FromFile(String filename)
15:08:51.1 5/13/2011: at ag.a(Graphics& A_0, String A_1, Image A_2, Bitmap& A_3, x& A_4)
15:08:51.1 5/13/2011: at ag.b8()
15:08:51.1 5/13/2011: at ag.a(Boolean A_0, String A_1, Boolean A_2)
15:08:51.1 5/13/2011: at ag..ctor()
15:08:51.1 5/13/2011: Closing database connection
15:08:51.1 5/13/2011: Disposing Plugins
15:08:51.1 5/13/2011: GameEx is exiting with errors
15:08:51.1 5/13/2011: Deleting search cache
15:08:51.2 5/13/2011: ERRORS DETECTED: EXITING
I was testing a some new theme elements and simply replaced the startbak.png and startbak_foreground.png files of an existing theme and the error as noted in the log occured and GameEx closed. Not sure why this is happening as I have performed these substitutions many times in the past without any problems.
A couple thoughts I had:
Are all these the same resolution? I think there might be a problem with layout vs the theme.ini.
The other thing I was thinking is that GameEx may be looking to add elements that aren't specified in the new layout, or the bg cache may need to be cleared.
You could try using a copy of the theme folder with a modified ini and see if that works?
You know when Drac hits a wall it's probably a really big wall! :)
LOL! It's OK Ian, it's what I do. Not sure *why* it was behaving that way, but I was able to work around it by using a different "seed" theme for my new theme. Sometimes it just happens. We can mark this one as resolved!
