Hey guys.
Got an odd issue here, I cant seem to figure this one out.
I am using Kega Fusion that is working perfectly for Game Gear, Master system, 32x. in Game EX however it refuses to load the correct ROM path. It is loading an old ROM path I used ages ago.
I went to GameEX\DATA and Deleted all the *.DBCACHE, *.DBCACHEINI and *.DBCACHENODATA File files but it still reverts back to the original ROM path (that no longer exists)
This is my last log file.
14:46:06.2 11/05/2011: GameEx: Version 11.71: Starting Log
14:46:06.2 11/05/2011: Operating System Platform: Win32NT
14:46:06.2 11/05/2011: Operating System Name: Windows Vista
14:46:06.2 11/05/2011: Operating System Version: 6.1.7601
14:46:06.2 11/05/2011: Aero running
14:46:06.2 11/05/2011: Initializing Vista/Windows 7 volume control
14:46:06.2 11/05/2011: Checking for versions of .net Framework installed
14:46:06.2 11/05/2011: .net Framework 2.0 Installed
14:46:06.2 11/05/2011: .net Framework 3.0 Installed
14:46:06.2 11/05/2011: .net Framework 3.5 Installed
14:46:06.2 11/05/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
14:46:06.2 11/05/2011: 3.07Ghz - 4 Cores or CPU's
14:46:06.2 11/05/2011: Running Randomize()
14:46:06.2 11/05/2011: Loading PlugIns
14:46:06.2 11/05/2011: Checking for applications to Launch On Startup
14:46:06.2 11/05/2011: Running Misc startup tasks
14:46:06.2 11/05/2011: Setting Menu types
14:46:06.2 11/05/2011: Opening Configuration File
14:46:06.2 11/05/2011: Getting Configuration Values
14:46:06.2 11/05/2011: Using Theme: Default - Dark Gloss
14:46:06.2 11/05/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss
14:46:06.2 11/05/2011: Launching HideOS.exe
14:46:06.2 11/05/2011: Initialising Video/MNG DLL's
14:46:06.2 11/05/2011: GameEx will check for media insertion (may affect performance)
14:46:06.2 11/05/2011: Hiding Taskbar
14:46:06.2 11/05/2011: Is Media Center running?
14:46:06.2 11/05/2011: Checking/Creating LCD Registry values
14:46:06.2 11/05/2011: Check Media Center Exit/Start Mode
14:46:06.2 11/05/2011: Media Center Mode 2
14:46:06.2 11/05/2011: Video previews on. Warning: Only recommended on modern systems
14:46:06.2 11/05/2011: Custom Game Device Input enabled: Getting custom codes
14:46:06.2 11/05/2011: Snap Delay set to: 7
14:46:06.2 11/05/2011: Get other settings
14:46:06.2 11/05/2011: Desktop set to Hide ICONS and set Background to Black
14:46:06.2 11/05/2011: Set: Find emulator artwork on best match basis
14:46:06.2 11/05/2011: Start work for Form
14:46:06.2 11/05/2011: Getting Original Screen Size
14:46:06.2 11/05/2011: Compacting Database
14:46:06.4 11/05/2011: Opening Database Connection
14:46:06.4 11/05/2011: Initializing Component
14:46:06.4 11/05/2011: Retrieving resolution setting
14:46:06.4 11/05/2011: MAME Path is: E:\Games\emulated\Mame32
14:46:06.4 11/05/2011: Model 2 Path Path is: E:\Games\emulated\Model 2
14:46:06.4 11/05/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
14:46:06.4 11/05/2011: Model 2 EXE file is: emulator_multicpu.exe
14:46:06.4 11/05/2011: Model 2 emulator with command line support detected
14:46:06.4 11/05/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
14:46:06.4 11/05/2011: ZiNc Path is: E:\Games\emulated\zinc
14:46:06.4 11/05/2011: ZiNc EXE file is: zinc.exe
14:46:06.4 11/05/2011: Use ZiNc on. zinc.exe will launch PSX games
14:46:06.4 11/05/2011: MAME EXE file is: MameUI32.exe
14:46:06.4 11/05/2011: ROM Path is: E:\Games\ROMs\Mame
14:46:06.4 11/05/2011: Catver.ini is located at: E:\GameEx\DATA\catver.ini
14:46:06.4 11/05/2011: controls.ini is located at: E:\GameEx\data\controls.ini
14:46:06.4 11/05/2011: History.dat is located at: E:\GameEx\DATA\history.dat
14:46:06.4 11/05/2011: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
14:46:06.4 11/05/2011: command.dat is located at: E:\GameEx\DATA\command.dat
14:46:06.4 11/05/2011: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
14:46:06.4 11/05/2011: Loading Controls.ini map file
14:46:06.4 11/05/2011: Snap Path is: E:\Games\emulated\Mame32\snap
14:46:06.4 11/05/2011: AVI Snap Path is: E:\Video\avisnap
14:46:06.4 11/05/2011: Flyer Path is: E:\Games\emulated\Mame32\flyers
14:46:06.4 11/05/2011: Cabinet Path is: E:\Games\emulated\Mame32\cabinets
14:46:06.4 11/05/2011: Cabinet 3D Path is: E:\Games\emulated\Mame32\cabinets
14:46:06.4 11/05/2011: Title Path is: E:\Games\emulated\Mame32\titles
14:46:06.4 11/05/2011: PCB Path is: E:\Games\emulated\Mame32\pcb
14:46:06.5 11/05/2011: Artwork Preview Path is: E:\Games\emulated\Mame32\artwork
14:46:06.5 11/05/2011: Panel Path is: E:\Games\emulated\Mame32\cpanel
14:46:06.5 11/05/2011: Manual Path: Not Found
14:46:06.5 11/05/2011: Icon Path is: E:\Games\emulated\Mame32\icons
14:46:06.5 11/05/2011: Marquee Path is: E:\Games\emulated\Mame32\marquees
14:46:06.5 11/05/2011: Loading Custom Emulators
14:46:06.5 11/05/2011: Loading Emulator 1: Panasonic 3DO
14:46:06.5 11/05/2011: Loading Emulator 3: [Console] Atari 2600 (Stella)
14:46:06.5 11/05/2011: Loading Emulator 4: [Console] Atari 5200 (MESS)
14:46:06.5 11/05/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
14:46:06.5 11/05/2011: Loading Emulator 6: Atari Jaguar
14:46:06.5 11/05/2011: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
14:46:06.5 11/05/2011: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
14:46:06.5 11/05/2011: Loading Emulator 9: [Console] Coleco Vision (MESS)
14:46:06.5 11/05/2011: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
14:46:06.5 11/05/2011: Loading Emulator 11: [Arcade] Arcade (FB Alpha)
14:46:06.5 11/05/2011: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
14:46:06.5 11/05/2011: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
14:46:06.5 11/05/2011: Loading Emulator 14: Mattel Intellivision (MESS)
14:46:06.5 11/05/2011: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
14:46:06.5 11/05/2011: Loading Emulator 17: [Console] Nintendo N64 (Project64)
14:46:06.5 11/05/2011: Loading Emulator 18: [Console] Nintendo NES (Jnes)
14:46:06.5 11/05/2011: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
14:46:06.5 11/05/2011: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
14:46:06.5 11/05/2011: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
14:46:06.5 11/05/2011: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
14:46:06.5 11/05/2011: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
14:46:06.5 11/05/2011: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
14:46:06.5 11/05/2011: Loading Emulator 25: Sam Coupe
14:46:06.5 11/05/2011: Loading Emulator 26: [Console] Sega Dreamcast (nullDC)
14:46:06.5 11/05/2011: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
14:46:06.5 11/05/2011: Loading Emulator 28: [Console] Sega Master System (Fusion)
14:46:06.5 11/05/2011: Loading Emulator 29: [Console] Sega Genesis (Fusion)
14:46:06.5 11/05/2011: Loading Emulator 30: [PC] Microsoft MSX (MESS)
14:46:06.5 11/05/2011: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
14:46:06.5 11/05/2011: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
14:46:06.5 11/05/2011: Loading Emulator 38: [Console] Sega Saturn (SSF)
14:46:06.5 11/05/2011: Loading Emulator 39: [PC] Microsoft Windows
14:46:06.5 11/05/2011: Loading Emulator 40: [Console] Sega 32X (Fusion)
14:46:06.5 11/05/2011: Loading Emulator 42: [PC] Microsoft Windows CD
14:46:06.5 11/05/2011: Loading Emulator 43: [Arcade] Arcade (ZiNc)
14:46:06.5 11/05/2011: Using 3D Alpha Blended Animations.
14:46:06.5 11/05/2011: Using General Font: Trebuchet MS
14:46:06.5 11/05/2011: Using Title Font: Trebuchet MS
14:46:06.6 11/05/2011: Initialising Direct3D
14:46:06.6 11/05/2011: Applying GameEx is Loading Image
14:46:06.6 11/05/2011: Setting Resolution to 1360x768 32 bit color
14:46:06.6 11/05/2011: Creating Surfaces
14:46:06.8 11/05/2011: Creating Primary Surface - Full Screen Mode
14:46:06.8 11/05/2011: Creating Back Buffer
14:46:06.8 11/05/2011: Loading graphic Surfaces
14:46:06.8 11/05/2011: Display is running at: 1360x768 32bit color, 60hz
14:46:06.9 11/05/2011: Creating Surfaces Misc and Dialogs
14:46:06.9 11/05/2011: Creating Surfaces Volume
14:46:06.9 11/05/2011: Creating Surfaces Arrows
14:46:06.9 11/05/2011: Creating Surfaces GameEXlogo Text
14:46:06.9 11/05/2011: Creating Surfaces Toolbar
14:46:06.9 11/05/2011: Creating Surfaces Backgrounds
14:46:06.9 11/05/2011: Creating Surfaces Toolbar Controls
14:46:06.9 11/05/2011: Creating Surfaces GameEx Logo
14:46:06.9 11/05/2011: Creating Surface Unselected
14:46:06.9 11/05/2011: Creating Surfaces Snaps
14:46:06.9 11/05/2011: Creating Surfaces Menu and List Bars
14:46:07.0 11/05/2011: Creating Fonts
14:46:07.0 11/05/2011: Creating Game Font
14:46:07.0 11/05/2011: Creating Game Font Faded
14:46:07.1 11/05/2011: Creating Title Font
14:46:07.1 11/05/2011: Restoring Title Font From Cache
14:46:07.2 11/05/2011: Creating Font Black
14:46:07.3 11/05/2011: Creating Font Black Small
14:46:07.3 11/05/2011: Fonts Created Succesfully
14:46:07.3 11/05/2011: Initialising Bass Audio Library
14:46:07.3 11/05/2011: Creating instance of global keyboard hook
14:46:07.6 11/05/2011: Playing Startup Video on thread
14:46:07.6 11/05/2011: Attempting to load game list
14:46:07.7 11/05/2011: Applying Language/Text
14:46:07.7 11/05/2011: Text/Language: English
14:46:07.7 11/05/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
14:46:07.7 11/05/2011: Loading last used Game List
14:46:07.7 11/05/2011: Creating DirectSound Device
14:46:07.7 11/05/2011: Trying: Primary Sound Driver
14:46:07.8 11/05/2011: Loading Sound Files
14:46:07.8 11/05/2011: DirectSound Device Created Successfully
14:46:07.8 11/05/2011: Initialising DirectInput for Gamepad support
14:46:07.9 11/05/2011: Using Device Controller (XBOX 360 For Windows)
14:46:07.9 11/05/2011: Using Device Nintendo RVL-CNT-01
14:46:08.0 11/05/2011: Initializing MCE Remote
14:46:08.0 11/05/2011: Playing intro sound file
14:46:08.1 11/05/2011: Initialization OK! Starting GameEx!
14:46:08.1 11/05/2011: Testing Main Loop Once: Processing Frame
14:46:08.3 11/05/2011: Testing Main Loop Once: Main Loop ran successfully
14:46:15.9 11/05/2011: Validating: Emulator_1: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_1: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_1: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_1: Database: [Console] Panasonic 3DO
14:46:15.9 11/05/2011: Validating: Emulator_3: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_3: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_3: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_3: Database: [Console] Atari 2600
14:46:15.9 11/05/2011: Validating: Emulator_4: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_4: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_4: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_4: Database: [Console] Atari 5200
14:46:15.9 11/05/2011: Validating: Emulator_5: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_5: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_5: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_5: Database: [Console] Atari 7800
14:46:15.9 11/05/2011: Validating: Emulator_6: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_6: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_6: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_6: Database: [Console] Atari Jaguar
14:46:15.9 11/05/2011: Validating: Emulator_7: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_7: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_7: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_7: Database: [Handheld] Atari Lynx
14:46:15.9 11/05/2011: Validating: Emulator_8: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_8: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_8: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_8: Database: [Handheld] Bandai WonderSwan Color
14:46:15.9 11/05/2011: Validating: Emulator_9: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_9: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_9: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_9: Database: [Console] Coleco Vision
14:46:15.9 11/05/2011: Validating: Emulator_10: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_10: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_10: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_10: Database: [Console] Fairchild Channel F
14:46:15.9 11/05/2011: Validating: Emulator_11: Custom Background: E:\Games\emulated\mame\Snaps
14:46:15.9 11/05/2011: Warning: Emulator_11: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Snap Path: E:\Games\emulated\mame\Snaps
14:46:15.9 11/05/2011: Warning: Emulator_11: Snap Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Control Panel Path: E:\Games\emulated\mame\Controls
14:46:15.9 11/05/2011: Warning: Emulator_11: Control Panel Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Title Snap Path: E:\Games\emulated\mame\Titles
14:46:15.9 11/05/2011: Warning: Emulator_11: Title Snap Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Box Art Path: E:\Games\emulated\mame\Boxes
14:46:15.9 11/05/2011: Warning: Emulator_11: Box Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Cart Art Path: E:\Games\emulated\mame\Cartridges
14:46:15.9 11/05/2011: Warning: Emulator_11: Cart Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_11: Manual Path: E:\Games\emulated\mame\Manuals
14:46:15.9 11/05/2011: Warning: Emulator_11: Manual Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_12: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_12: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_12: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
14:46:15.9 11/05/2011: Validating: Emulator_13: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_13: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_13: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_13: Database: [Handheld] Nintendo DS
14:46:15.9 11/05/2011: Validating: Emulator_14: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_14: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_14: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_14: Database: [Console] Mattel Intellivision
14:46:15.9 11/05/2011: Validating: Emulator_16: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_16: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_16: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_16: Database: [Handheld] SNK Neo-Geo Pocket
14:46:15.9 11/05/2011: Validating: Emulator_17: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_17: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_17: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_17: Database: [Console] Nintendo N64
14:46:15.9 11/05/2011: Validating: Emulator_18: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_18: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_18: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_18: Database: [Console] Nintendo NES
14:46:15.9 11/05/2011: Validating: Emulator_19: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_19: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_19: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_19: Database: [Console] Nintendo GameCube
14:46:15.9 11/05/2011: Validating: Emulator_20: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_20: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_20: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_20: Database: [Handheld] Nintendo Virtual Boy
14:46:15.9 11/05/2011: Validating: Emulator_21: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_21: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_21: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_21: Database: [Console] Nintendo GameCube
14:46:15.9 11/05/2011: Validating: Emulator_22: Custom Background: E:\Games\emulated\PC Engine\Snaps
14:46:15.9 11/05/2011: Warning: Emulator_22: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Snap Path: E:\Games\emulated\PC Engine\Snaps
14:46:15.9 11/05/2011: Warning: Emulator_22: Snap Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Control Panel Path: E:\Games\emulated\PC Engine\Controls
14:46:15.9 11/05/2011: Warning: Emulator_22: Control Panel Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Database: [Console] NEC TurboGrafx-16
14:46:15.9 11/05/2011: Validating: Emulator_22: Title Snap Path: E:\Games\emulated\PC Engine\Titles
14:46:15.9 11/05/2011: Warning: Emulator_22: Title Snap Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Box Art Path: E:\Games\emulated\PC Engine\Boxes
14:46:15.9 11/05/2011: Warning: Emulator_22: Box Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Cart Art Path: E:\Games\emulated\PC Engine\Cartridges
14:46:15.9 11/05/2011: Warning: Emulator_22: Cart Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_22: Manual Path: E:\Games\emulated\PC Engine\Manuals
14:46:15.9 11/05/2011: Warning: Emulator_22: Manual Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_23: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_23: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_23: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_23: Database: [Console] Sony Playstation
14:46:15.9 11/05/2011: Warning: Emulator_23: MAPFile Does Not Exist
14:46:15.9 11/05/2011: Validating: Emulator_24: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_24: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_24: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_24: Database: [Console] Sony Playstation 2
14:46:15.9 11/05/2011: Warning: Emulator_24: MAPFile Does Not Exist
14:46:15.9 11/05/2011: Validating: Emulator_25: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_25: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_25: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_25: Database: Template
14:46:15.9 11/05/2011: Validating: Emulator_26: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_26: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_26: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_26: Database: [Console] Sega Dreamcast
14:46:15.9 11/05/2011: Validating: Emulator_27: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_27: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_27: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_27: Database: [Handheld] Sega Game Gear
14:46:15.9 11/05/2011: Validating: Emulator_28: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_28: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_28: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_28: Database: [Console] Sega Master System
14:46:15.9 11/05/2011: Validating: Emulator_29: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_29: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_29: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_29: Database: [Console] Sega Genesis
14:46:15.9 11/05/2011: Validating: Emulator_29: Box Art Path: E:\Games\emu
14:46:15.9 11/05/2011: Warning: Emulator_29: Box Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_30: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_30: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_30: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_30: Database: [PC] Microsoft MSX
14:46:15.9 11/05/2011: Validating: Emulator_31: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_31: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_31: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_31: Database: [PC] Microsoft MSX 2
14:46:15.9 11/05/2011: Validating: Emulator_32: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_32: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_32: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_32: Database: [Console] Nintendo SNES
14:46:15.9 11/05/2011: Validating: Emulator_38: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_38: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_38: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_38: Database: [Console] Sega Saturn
14:46:15.9 11/05/2011: Validating: Emulator_39: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_39: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_39: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_40: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_40: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_40: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_40: Database: [Console] Sega 32X
14:46:15.9 11/05/2011: Validating: Emulator_40: Box Art Path: E:\Games\emu
14:46:15.9 11/05/2011: Warning: Emulator_40: Box Art Path Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_42: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_42: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_42: Snap Path:
14:46:15.9 11/05/2011: Validating: Emulator_43: Custom Background:
14:46:15.9 11/05/2011: Warning: Emulator_43: Custom Background Does not exist
14:46:15.9 11/05/2011: Validating: Emulator_43: Snap Path:
14:46:15.9 11/05/2011: Not Restoring Emulator from Cache
14:46:16.0 11/05/2011: Not Restoring Emulator Database From Cache
14:46:16.0 11/05/2011: Not Restoring Emulator from Cache
14:46:16.5 11/05/2011: Not Restoring Emulator from Cache
14:46:16.5 11/05/2011: Not Restoring Emulator Database From Cache
14:46:17.1 11/05/2011: Not Restoring Emulator from Cache
14:46:17.1 11/05/2011: Not Restoring Emulator Database From Cache
14:46:17.2 11/05/2011: Not Restoring Emulator from Cache
14:46:17.2 11/05/2011: Not Restoring Emulator Database From Cache
14:46:17.3 11/05/2011: Not Restoring Emulator from Cache
14:46:17.3 11/05/2011: Not Restoring Emulator Database From Cache
14:46:17.5 11/05/2011: Not Restoring Emulator from Cache
14:46:17.5 11/05/2011: Not Restoring Emulator Database From Cache
14:46:17.6 11/05/2011: Not Restoring Emulator from Cache
14:46:17.6 11/05/2011: Not Restoring Emulator Database From Cache
14:46:18.0 11/05/2011: Not Restoring Emulator from Cache
14:46:18.0 11/05/2011: Not Restoring Emulator Database From Cache
14:46:18.3 11/05/2011: Not Restoring Emulator from Cache
14:46:18.4 11/05/2011: Not Restoring Emulator from Cache
14:46:18.7 11/05/2011: Not Restoring Emulator Database From Cache
14:46:18.8 11/05/2011: Not Restoring Emulator from Cache
14:46:18.8 11/05/2011: Not Restoring Emulator Database From Cache
14:46:19.1 11/05/2011: Not Restoring Emulator from Cache
14:46:19.1 11/05/2011: Not Restoring Emulator Database From Cache
14:46:19.2 11/05/2011: Not Restoring Emulator from Cache
14:46:19.2 11/05/2011: Not Restoring Emulator Database From Cache
14:46:19.3 11/05/2011: Not Restoring Emulator from Cache
14:46:19.3 11/05/2011: Not Restoring Emulator Database From Cache
14:46:20.4 11/05/2011: Not Restoring Emulator from Cache
14:46:20.5 11/05/2011: Not Restoring Emulator Database From Cache
14:46:20.7 11/05/2011: Not Restoring Emulator from Cache
14:46:20.7 11/05/2011: Not Restoring Emulator Database From Cache
14:46:20.8 11/05/2011: Not Restoring Emulator from Cache
14:46:20.8 11/05/2011: Not Restoring Emulator Database From Cache
14:46:21.0 11/05/2011: Not Restoring Emulator from Cache
14:46:21.1 11/05/2011: Not Restoring Emulator Database From Cache
14:46:21.3 11/05/2011: Not Restoring Emulator from Cache
14:46:21.3 11/05/2011: Not Restoring Emulator Database From Cache
14:46:21.4 11/05/2011: Not Restoring Emulator from Cache
14:46:21.5 11/05/2011: Not Restoring Emulator Database From Cache
14:46:21.5 11/05/2011: Not Restoring Emulator from Cache
14:46:21.6 11/05/2011: Not Restoring Emulator from Cache
14:46:21.6 11/05/2011: Not Restoring Emulator Database From Cache
14:46:21.9 11/05/2011: Not Restoring Emulator from Cache
14:46:21.9 11/05/2011: Not Restoring Emulator Database From Cache
14:46:22.2 11/05/2011: Not Restoring Emulator from Cache
14:46:22.2 11/05/2011: Not Restoring Emulator Database From Cache
14:46:22.6 11/05/2011: Not Restoring Emulator from Cache
14:46:22.6 11/05/2011: Not Restoring Emulator Database From Cache
14:46:22.7 11/05/2011: Not Restoring Emulator from Cache
14:46:22.7 11/05/2011: Not Restoring Emulator Database From Cache
14:46:23.5 11/05/2011: Not Restoring Emulator from Cache
14:46:23.5 11/05/2011: Not Restoring Emulator Database From Cache
14:46:23.7 11/05/2011: Not Restoring Emulator from Cache
14:46:23.7 11/05/2011: Not Restoring Emulator Database From Cache
14:46:31.9 11/05/2011: Restoring Emulator from Cache
14:46:39.7 11/05/2011: Exiting GameEx!
14:46:39.7 11/05/2011: Saving Settings
14:46:41.4 11/05/2011: Disposing Plugins
14:46:41.4 11/05/2011: Closing database connection
14:46:41.4 11/05/2011: Checking for applications to Launch On Exit
14:46:41.4 11/05/2011: Media Center was not open when starting GameEx, so not launching
This is the config
[Emulator_29]
STARTPAGENAME=[Console] Sega Genesis (Fusion)
TITLETEXT=Sega Genesis
StartPageLogo=Sega Genesis
ROMFilter=*.smd; *.bin
RomPath=E:\Games\ROMs\Sega megadrive\Europe
RomsInFolders=False
SnapPath=
TitlePath=
BoxPath=E:\Games\emu
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=E:\Games\emulated\sega megadrive, Game Gear, Master system
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=Fusion.exe -gen -fullscreen "[ROMPATH]\[ROMFILE]"
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
DATABASE=[Console] Sega Genesis
UseDbName=
GamesIn7Zips=False
MergeSets=
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
GameExtenderCustomArtPath=
GameExtenderConstants=
System=Sega Genesis
Category=Console
Emulator=Fusion
Version=3.64
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Fusion.7z
RequiredFiles=
Website=http://www.eidolons-inn.net/tiki-index.php?page=Kega
Info=Fusion(formerly known as Kega II and Kega Fusion) is a Sega SG1000, SC3000, Master System, Game Gear, Genesis/Megadrive, SegaCD/MegaCD and 32X emulator
OLDatZip=
lastgame=
I have no Idea what I am doing wrong here
That is correct but in gameEX when I load the emulator it reverts to a "Sega Genesis-Mega Drive & 32x Roms [5,871] [Full Set]" folder that literally does not exist on my machine.
Any help would be awesome.
Regards
Post your long when trying to run a game please.
What is the exactly location that's loading instead of?...:
Why does your Working path have commas?:
Thanks for the prompt response, there are commas in the directory path, I guess I was not thinking when I built it like that, it does work however.
Found something interesting here.
I just ran sega master system that uses the same working path as the genesis one. game worked perfect no issues.
Log
15:14:30.6 11/05/2011: GameEx: Version 11.71: Starting Log
15:14:30.6 11/05/2011: Operating System Platform: Win32NT
15:14:30.6 11/05/2011: Operating System Name: Windows Vista
15:14:30.6 11/05/2011: Operating System Version: 6.1.7601
15:14:30.6 11/05/2011: Aero running
15:14:30.6 11/05/2011: Initializing Vista/Windows 7 volume control
15:14:30.6 11/05/2011: Checking for versions of .net Framework installed
15:14:30.6 11/05/2011: .net Framework 2.0 Installed
15:14:30.6 11/05/2011: .net Framework 3.0 Installed
15:14:30.6 11/05/2011: .net Framework 3.5 Installed
15:14:30.6 11/05/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
15:14:30.6 11/05/2011: 3.07Ghz - 4 Cores or CPU's
15:14:30.6 11/05/2011: Running Randomize()
15:14:30.6 11/05/2011: Loading PlugIns
15:14:30.6 11/05/2011: Checking for applications to Launch On Startup
15:14:30.6 11/05/2011: Running Misc startup tasks
15:14:30.6 11/05/2011: Setting Menu types
15:14:30.6 11/05/2011: Opening Configuration File
15:14:30.6 11/05/2011: Getting Configuration Values
15:14:30.6 11/05/2011: Using Theme: Default - Dark Gloss
15:14:30.6 11/05/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss
15:14:30.6 11/05/2011: Launching HideOS.exe
15:14:30.6 11/05/2011: Initialising Video/MNG DLL's
15:14:30.6 11/05/2011: GameEx will check for media insertion (may affect performance)
15:14:30.6 11/05/2011: Hiding Taskbar
15:14:30.6 11/05/2011: Is Media Center running?
15:14:30.6 11/05/2011: Checking/Creating LCD Registry values
15:14:30.7 11/05/2011: Check Media Center Exit/Start Mode
15:14:30.7 11/05/2011: Media Center Mode 2
15:14:30.7 11/05/2011: Video previews on. Warning: Only recommended on modern systems
15:14:30.7 11/05/2011: Custom Game Device Input enabled: Getting custom codes
15:14:30.7 11/05/2011: Snap Delay set to: 7
15:14:30.7 11/05/2011: Get other settings
15:14:30.7 11/05/2011: Desktop set to Hide ICONS and set Background to Black
15:14:30.7 11/05/2011: Set: Find emulator artwork on best match basis
15:14:30.7 11/05/2011: Start work for Form
15:14:30.7 11/05/2011: Getting Original Screen Size
15:14:30.7 11/05/2011: Opening Database Connection
15:14:30.7 11/05/2011: Initializing Component
15:14:30.7 11/05/2011: Retrieving resolution setting
15:14:30.7 11/05/2011: MAME Path is: E:\Games\emulated\Mame32
15:14:30.7 11/05/2011: Model 2 Path Path is: E:\Games\emulated\Model 2
15:14:30.7 11/05/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
15:14:30.7 11/05/2011: Model 2 EXE file is: emulator_multicpu.exe
15:14:30.7 11/05/2011: Model 2 emulator with command line support detected
15:14:30.7 11/05/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
15:14:30.7 11/05/2011: ZiNc Path is: E:\Games\emulated\zinc
15:14:30.7 11/05/2011: ZiNc EXE file is: zinc.exe
15:14:30.7 11/05/2011: Use ZiNc on. zinc.exe will launch PSX games
15:14:30.7 11/05/2011: MAME EXE file is: MameUI32.exe
15:14:30.7 11/05/2011: ROM Path is: E:\Games\ROMs\Mame
15:14:30.7 11/05/2011: Catver.ini is located at: E:\GameEx\DATA\catver.ini
15:14:30.7 11/05/2011: controls.ini is located at: E:\GameEx\data\controls.ini
15:14:30.7 11/05/2011: History.dat is located at: E:\GameEx\DATA\history.dat
15:14:30.7 11/05/2011: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
15:14:30.7 11/05/2011: command.dat is located at: E:\GameEx\DATA\command.dat
15:14:30.7 11/05/2011: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
15:14:30.7 11/05/2011: Loading Controls.ini map file
15:14:30.7 11/05/2011: Snap Path is: E:\Games\emulated\Mame32\snap
15:14:30.7 11/05/2011: AVI Snap Path is: E:\Video\avisnap
15:14:30.7 11/05/2011: Flyer Path is: E:\Games\emulated\Mame32\flyers
15:14:30.7 11/05/2011: Cabinet Path is: E:\Games\emulated\Mame32\cabinets
15:14:30.7 11/05/2011: Cabinet 3D Path is: E:\Games\emulated\Mame32\cabinets
15:14:30.7 11/05/2011: Title Path is: E:\Games\emulated\Mame32\titles
15:14:30.7 11/05/2011: PCB Path is: E:\Games\emulated\Mame32\pcb
15:14:30.7 11/05/2011: Artwork Preview Path is: E:\Games\emulated\Mame32\artwork
15:14:30.7 11/05/2011: Panel Path is: E:\Games\emulated\Mame32\cpanel
15:14:30.7 11/05/2011: Manual Path: Not Found
15:14:30.7 11/05/2011: Icon Path is: E:\Games\emulated\Mame32\icons
15:14:30.7 11/05/2011: Marquee Path is: E:\Games\emulated\Mame32\marquees
15:14:30.8 11/05/2011: Loading Custom Emulators
15:14:30.8 11/05/2011: Loading Emulator 1: Panasonic 3DO
15:14:30.8 11/05/2011: Loading Emulator 3: [Console] Atari 2600 (Stella)
15:14:30.8 11/05/2011: Loading Emulator 4: [Console] Atari 5200 (MESS)
15:14:30.8 11/05/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
15:14:30.8 11/05/2011: Loading Emulator 6: Atari Jaguar
15:14:30.8 11/05/2011: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
15:14:30.8 11/05/2011: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
15:14:30.8 11/05/2011: Loading Emulator 9: [Console] Coleco Vision (MESS)
15:14:30.8 11/05/2011: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
15:14:30.8 11/05/2011: Loading Emulator 11: [Arcade] Arcade (FB Alpha)
15:14:30.8 11/05/2011: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
15:14:30.8 11/05/2011: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
15:14:30.8 11/05/2011: Loading Emulator 14: Mattel Intellivision (MESS)
15:14:30.8 11/05/2011: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
15:14:30.8 11/05/2011: Loading Emulator 17: [Console] Nintendo N64 (Project64)
15:14:30.8 11/05/2011: Loading Emulator 18: [Console] Nintendo NES (Jnes)
15:14:30.8 11/05/2011: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
15:14:30.8 11/05/2011: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
15:14:30.8 11/05/2011: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
15:14:30.8 11/05/2011: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
15:14:30.8 11/05/2011: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
15:14:30.8 11/05/2011: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
15:14:30.8 11/05/2011: Loading Emulator 25: Sam Coupe
15:14:30.8 11/05/2011: Loading Emulator 26: [Console] Sega Dreamcast (nullDC)
15:14:30.8 11/05/2011: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
15:14:30.8 11/05/2011: Loading Emulator 28: [Console] Sega Master System (Fusion)
15:14:30.8 11/05/2011: Loading Emulator 29: [Console] Sega Genesis (Fusion)
15:14:30.8 11/05/2011: Loading Emulator 30: [PC] Microsoft MSX (MESS)
15:14:30.8 11/05/2011: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
15:14:30.8 11/05/2011: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
15:14:30.8 11/05/2011: Loading Emulator 38: [Console] Sega Saturn (SSF)
15:14:30.8 11/05/2011: Loading Emulator 39: [PC] Microsoft Windows
15:14:30.8 11/05/2011: Loading Emulator 40: [Console] Sega 32X (Fusion)
15:14:30.8 11/05/2011: Loading Emulator 42: [PC] Microsoft Windows CD
15:14:30.8 11/05/2011: Loading Emulator 43: [Arcade] Arcade (ZiNc)
15:14:30.8 11/05/2011: Using 3D Alpha Blended Animations.
15:14:30.8 11/05/2011: Using General Font: Trebuchet MS
15:14:30.8 11/05/2011: Using Title Font: Trebuchet MS
15:14:30.9 11/05/2011: Initialising Direct3D
15:14:30.9 11/05/2011: Applying GameEx is Loading Image
15:14:30.9 11/05/2011: Setting Resolution to 1360x768 32 bit color
15:14:30.9 11/05/2011: Creating Surfaces
15:14:31.1 11/05/2011: Creating Primary Surface - Full Screen Mode
15:14:31.1 11/05/2011: Creating Back Buffer
15:14:31.1 11/05/2011: Loading graphic Surfaces
15:14:31.1 11/05/2011: Display is running at: 1360x768 32bit color, 60hz
15:14:31.1 11/05/2011: Creating Surfaces Misc and Dialogs
15:14:31.2 11/05/2011: Creating Surfaces Volume
15:14:31.2 11/05/2011: Creating Surfaces Arrows
15:14:31.2 11/05/2011: Creating Surfaces GameEXlogo Text
15:14:31.2 11/05/2011: Creating Surfaces Toolbar
15:14:31.2 11/05/2011: Creating Surfaces Backgrounds
15:14:31.2 11/05/2011: Creating Surfaces Toolbar Controls
15:14:31.2 11/05/2011: Creating Surfaces GameEx Logo
15:14:31.2 11/05/2011: Creating Surface Unselected
15:14:31.2 11/05/2011: Creating Surfaces Snaps
15:14:31.2 11/05/2011: Creating Surfaces Menu and List Bars
15:14:31.2 11/05/2011: Creating Fonts
15:14:31.2 11/05/2011: Creating Game Font
15:14:31.3 11/05/2011: Creating Game Font Faded
15:14:31.3 11/05/2011: Creating Title Font
15:14:31.4 11/05/2011: Restoring Title Font From Cache
15:14:31.5 11/05/2011: Creating Font Black
15:14:31.6 11/05/2011: Creating Font Black Small
15:14:31.6 11/05/2011: Fonts Created Succesfully
15:14:31.6 11/05/2011: Initialising Bass Audio Library
15:14:31.6 11/05/2011: Creating instance of global keyboard hook
15:14:31.9 11/05/2011: Playing Startup Video on thread
15:14:31.9 11/05/2011: Attempting to load game list
15:14:32.0 11/05/2011: Applying Language/Text
15:14:32.0 11/05/2011: Text/Language: English
15:14:32.0 11/05/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
15:14:32.0 11/05/2011: Loading last used Game List
15:14:32.0 11/05/2011: Creating DirectSound Device
15:14:32.0 11/05/2011: Trying: Primary Sound Driver
15:14:32.0 11/05/2011: Loading Sound Files
15:14:32.1 11/05/2011: DirectSound Device Created Successfully
15:14:32.1 11/05/2011: Initialising DirectInput for Gamepad support
15:14:32.2 11/05/2011: Using Device Nintendo RVL-CNT-01
15:14:32.2 11/05/2011: Initializing MCE Remote
15:14:32.2 11/05/2011: Playing intro sound file
15:14:32.3 11/05/2011: Initialization OK! Starting GameEx!
15:14:32.3 11/05/2011: Testing Main Loop Once: Processing Frame
15:14:32.5 11/05/2011: Testing Main Loop Once: Main Loop ran successfully
15:14:47.7 11/05/2011: Validating: Emulator_1: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_1: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_1: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_1: Database: [Console] Panasonic 3DO
15:14:47.7 11/05/2011: Validating: Emulator_3: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_3: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_3: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_3: Database: [Console] Atari 2600
15:14:47.7 11/05/2011: Validating: Emulator_4: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_4: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_4: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_4: Database: [Console] Atari 5200
15:14:47.7 11/05/2011: Validating: Emulator_5: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_5: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_5: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_5: Database: [Console] Atari 7800
15:14:47.7 11/05/2011: Validating: Emulator_6: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_6: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_6: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_6: Database: [Console] Atari Jaguar
15:14:47.7 11/05/2011: Validating: Emulator_7: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_7: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_7: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_7: Database: [Handheld] Atari Lynx
15:14:47.7 11/05/2011: Validating: Emulator_8: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_8: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_8: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_8: Database: [Handheld] Bandai WonderSwan Color
15:14:47.7 11/05/2011: Validating: Emulator_9: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_9: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_9: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_9: Database: [Console] Coleco Vision
15:14:47.7 11/05/2011: Validating: Emulator_10: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_10: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_10: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_10: Database: [Console] Fairchild Channel F
15:14:47.7 11/05/2011: Validating: Emulator_11: Custom Background: E:\Games\emulated\mame\Snaps
15:14:47.7 11/05/2011: Warning: Emulator_11: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Snap Path: E:\Games\emulated\mame\Snaps
15:14:47.7 11/05/2011: Warning: Emulator_11: Snap Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Control Panel Path: E:\Games\emulated\mame\Controls
15:14:47.7 11/05/2011: Warning: Emulator_11: Control Panel Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Title Snap Path: E:\Games\emulated\mame\Titles
15:14:47.7 11/05/2011: Warning: Emulator_11: Title Snap Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Box Art Path: E:\Games\emulated\mame\Boxes
15:14:47.7 11/05/2011: Warning: Emulator_11: Box Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Cart Art Path: E:\Games\emulated\mame\Cartridges
15:14:47.7 11/05/2011: Warning: Emulator_11: Cart Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_11: Manual Path: E:\Games\emulated\mame\Manuals
15:14:47.7 11/05/2011: Warning: Emulator_11: Manual Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_12: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_12: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_12: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
15:14:47.7 11/05/2011: Validating: Emulator_13: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_13: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_13: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_13: Database: [Handheld] Nintendo DS
15:14:47.7 11/05/2011: Validating: Emulator_14: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_14: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_14: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_14: Database: [Console] Mattel Intellivision
15:14:47.7 11/05/2011: Validating: Emulator_16: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_16: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_16: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_16: Database: [Handheld] SNK Neo-Geo Pocket
15:14:47.7 11/05/2011: Validating: Emulator_17: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_17: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_17: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_17: Database: [Console] Nintendo N64
15:14:47.7 11/05/2011: Validating: Emulator_18: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_18: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_18: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_18: Database: [Console] Nintendo NES
15:14:47.7 11/05/2011: Validating: Emulator_19: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_19: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_19: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_19: Database: [Console] Nintendo GameCube
15:14:47.7 11/05/2011: Validating: Emulator_20: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_20: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_20: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_20: Database: [Handheld] Nintendo Virtual Boy
15:14:47.7 11/05/2011: Validating: Emulator_21: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_21: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_21: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_21: Database: [Console] Nintendo GameCube
15:14:47.7 11/05/2011: Validating: Emulator_22: Custom Background: E:\Games\emulated\PC Engine\Snaps
15:14:47.7 11/05/2011: Warning: Emulator_22: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Snap Path: E:\Games\emulated\PC Engine\Snaps
15:14:47.7 11/05/2011: Warning: Emulator_22: Snap Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Control Panel Path: E:\Games\emulated\PC Engine\Controls
15:14:47.7 11/05/2011: Warning: Emulator_22: Control Panel Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Database: [Console] NEC TurboGrafx-16
15:14:47.7 11/05/2011: Validating: Emulator_22: Title Snap Path: E:\Games\emulated\PC Engine\Titles
15:14:47.7 11/05/2011: Warning: Emulator_22: Title Snap Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Box Art Path: E:\Games\emulated\PC Engine\Boxes
15:14:47.7 11/05/2011: Warning: Emulator_22: Box Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Cart Art Path: E:\Games\emulated\PC Engine\Cartridges
15:14:47.7 11/05/2011: Warning: Emulator_22: Cart Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_22: Manual Path: E:\Games\emulated\PC Engine\Manuals
15:14:47.7 11/05/2011: Warning: Emulator_22: Manual Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_23: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_23: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_23: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_23: Database: [Console] Sony Playstation
15:14:47.7 11/05/2011: Warning: Emulator_23: MAPFile Does Not Exist
15:14:47.7 11/05/2011: Validating: Emulator_24: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_24: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_24: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_24: Database: [Console] Sony Playstation 2
15:14:47.7 11/05/2011: Warning: Emulator_24: MAPFile Does Not Exist
15:14:47.7 11/05/2011: Validating: Emulator_25: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_25: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_25: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_25: Database: Template
15:14:47.7 11/05/2011: Validating: Emulator_26: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_26: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_26: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_26: Database: [Console] Sega Dreamcast
15:14:47.7 11/05/2011: Validating: Emulator_27: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_27: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_27: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_27: Database: [Handheld] Sega Game Gear
15:14:47.7 11/05/2011: Validating: Emulator_28: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_28: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_28: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_28: Database: [Console] Sega Master System
15:14:47.7 11/05/2011: Validating: Emulator_29: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_29: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_29: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_29: Database: [Console] Sega Genesis
15:14:47.7 11/05/2011: Validating: Emulator_29: Box Art Path: E:\Games\emu
15:14:47.7 11/05/2011: Warning: Emulator_29: Box Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_30: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_30: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_30: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_30: Database: [PC] Microsoft MSX
15:14:47.7 11/05/2011: Validating: Emulator_31: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_31: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_31: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_31: Database: [PC] Microsoft MSX 2
15:14:47.7 11/05/2011: Validating: Emulator_32: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_32: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_32: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_32: Database: [Console] Nintendo SNES
15:14:47.7 11/05/2011: Validating: Emulator_38: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_38: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_38: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_38: Database: [Console] Sega Saturn
15:14:47.7 11/05/2011: Validating: Emulator_39: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_39: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_39: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_40: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_40: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_40: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_40: Database: [Console] Sega 32X
15:14:47.7 11/05/2011: Validating: Emulator_40: Box Art Path: E:\Games\emu
15:14:47.7 11/05/2011: Warning: Emulator_40: Box Art Path Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_42: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_42: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_42: Snap Path:
15:14:47.7 11/05/2011: Validating: Emulator_43: Custom Background:
15:14:47.7 11/05/2011: Warning: Emulator_43: Custom Background Does not exist
15:14:47.7 11/05/2011: Validating: Emulator_43: Snap Path:
15:14:47.7 11/05/2011: Restoring Emulator from Cache
15:14:47.8 11/05/2011: Restoring Emulator Database From Cache
15:14:47.8 11/05/2011: Restoring Emulator from Cache
15:14:47.9 11/05/2011: Restoring Emulator Database From Cache
15:14:47.9 11/05/2011: Restoring Emulator from Cache
15:14:48.0 11/05/2011: Restoring Emulator from Cache
15:14:48.0 11/05/2011: Restoring Emulator Database From Cache
15:14:48.1 11/05/2011: Restoring Emulator from Cache
15:14:48.1 11/05/2011: Restoring Emulator Database From Cache
15:14:48.1 11/05/2011: Not Restoring Emulator from Cache
15:14:48.1 11/05/2011: No Database Data
15:14:48.2 11/05/2011: Restoring Emulator Database From Cache
15:14:48.2 11/05/2011: Restoring Emulator from Cache
15:14:48.3 11/05/2011: Restoring Emulator Database From Cache
15:14:48.4 11/05/2011: Restoring Emulator from Cache
15:14:48.4 11/05/2011: No Database Data
15:14:48.4 11/05/2011: Restoring Emulator Database From Cache
15:14:48.5 11/05/2011: Restoring Emulator Database From Cache
15:14:48.5 11/05/2011: Restoring Emulator from Cache
15:14:48.5 11/05/2011: No Database Data
15:14:48.6 11/05/2011: Restoring Emulator from Cache
15:14:48.6 11/05/2011: Restoring Emulator Database From Cache
15:14:48.7 11/05/2011: Restoring Emulator from Cache
15:14:48.7 11/05/2011: Restoring Emulator Database From Cache
15:14:48.7 11/05/2011: Not Restoring Emulator from Cache
15:14:48.8 11/05/2011: Restoring Emulator from Cache
15:14:48.8 11/05/2011: Restoring Emulator Database From Cache
15:14:48.9 11/05/2011: Restoring Emulator from Cache
15:14:48.9 11/05/2011: No Database Data
15:14:48.9 11/05/2011: Restoring Emulator Database From Cache
15:14:50.9 11/05/2011: Gamepad inserted. Attached devices: 2
15:15:05.8 11/05/2011: Running: cmd.exe /c E: Fusion.exe -sms -fullscreen "E:\Games\ROMs\Sega Master system\Unzipped7-Zip\Alex Kidd in Miracle World (J) [!].sms"
15:15:06.0 11/05/2011: Shutting down display
15:15:12.9 11/05/2011: Exiting Game
15:15:12.9 11/05/2011: Closing Process
15:15:15.6 11/05/2011: Writing Stats
15:15:15.6 11/05/2011: Plugin: Game Exit
15:15:15.6 11/05/2011: Plugin: Process Commands
15:15:15.6 11/05/2011: Refreshing Keyboard
15:15:15.7 11/05/2011: Initialising Audio
15:15:15.9 11/05/2011: Restoring Window
15:15:15.9 11/05/2011: Reinitializing Graphics System
15:15:16.7 11/05/2011: Reloading Game Info Page
15:15:16.9 11/05/2011: Returning to GameEx
15:15:18.2 11/05/2011: Exiting GameEx!
15:15:18.2 11/05/2011: Saving Settings
15:15:19.9 11/05/2011: Disposing Plugins
15:15:19.9 11/05/2011: Closing database connection
15:15:19.9 11/05/2011: Checking for applications to Launch On Exit
15:15:19.9 11/05/2011: Media Center was not open when starting GameEx, so not launching
runitbat
E:
CD "E:\Games\emulated\sega megadrive, Game Gear, Master system"
Now when I tried to open the Genesis roms I got this
log
15:16:31.1 11/05/2011: GameEx: Version 11.71: Starting Log
15:16:31.1 11/05/2011: Operating System Platform: Win32NT
15:16:31.1 11/05/2011: Operating System Name: Windows Vista
15:16:31.1 11/05/2011: Operating System Version: 6.1.7601
15:16:31.1 11/05/2011: Aero running
15:16:31.1 11/05/2011: Initializing Vista/Windows 7 volume control
15:16:31.1 11/05/2011: Checking for versions of .net Framework installed
15:16:31.1 11/05/2011: .net Framework 2.0 Installed
15:16:31.1 11/05/2011: .net Framework 3.0 Installed
15:16:31.1 11/05/2011: .net Framework 3.5 Installed
15:16:31.1 11/05/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
15:16:31.1 11/05/2011: 3.07Ghz - 4 Cores or CPU's
15:16:31.1 11/05/2011: Running Randomize()
15:16:31.1 11/05/2011: Loading PlugIns
15:16:31.1 11/05/2011: Checking for applications to Launch On Startup
15:16:31.1 11/05/2011: Running Misc startup tasks
15:16:31.1 11/05/2011: Setting Menu types
15:16:31.1 11/05/2011: Opening Configuration File
15:16:31.1 11/05/2011: Getting Configuration Values
15:16:31.1 11/05/2011: Using Theme: Default - Dark Gloss
15:16:31.1 11/05/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss
15:16:31.1 11/05/2011: Launching HideOS.exe
15:16:31.1 11/05/2011: Initialising Video/MNG DLL's
15:16:31.1 11/05/2011: GameEx will check for media insertion (may affect performance)
15:16:31.1 11/05/2011: Hiding Taskbar
15:16:31.1 11/05/2011: Is Media Center running?
15:16:31.1 11/05/2011: Checking/Creating LCD Registry values
15:16:31.1 11/05/2011: Check Media Center Exit/Start Mode
15:16:31.1 11/05/2011: Media Center Mode 2
15:16:31.1 11/05/2011: Video previews on. Warning: Only recommended on modern systems
15:16:31.1 11/05/2011: Custom Game Device Input enabled: Getting custom codes
15:16:31.1 11/05/2011: Snap Delay set to: 7
15:16:31.1 11/05/2011: Get other settings
15:16:31.1 11/05/2011: Desktop set to Hide ICONS and set Background to Black
15:16:31.1 11/05/2011: Set: Find emulator artwork on best match basis
15:16:31.1 11/05/2011: Start work for Form
15:16:31.1 11/05/2011: Getting Original Screen Size
15:16:31.1 11/05/2011: Opening Database Connection
15:16:31.1 11/05/2011: Initializing Component
15:16:31.1 11/05/2011: Retrieving resolution setting
15:16:31.1 11/05/2011: MAME Path is: E:\Games\emulated\Mame32
15:16:31.2 11/05/2011: Model 2 Path Path is: E:\Games\emulated\Model 2
15:16:31.2 11/05/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
15:16:31.2 11/05/2011: Model 2 EXE file is: emulator_multicpu.exe
15:16:31.2 11/05/2011: Model 2 emulator with command line support detected
15:16:31.2 11/05/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
15:16:31.2 11/05/2011: ZiNc Path is: E:\Games\emulated\zinc
15:16:31.2 11/05/2011: ZiNc EXE file is: zinc.exe
15:16:31.2 11/05/2011: Use ZiNc on. zinc.exe will launch PSX games
15:16:31.2 11/05/2011: MAME EXE file is: MameUI32.exe
15:16:31.2 11/05/2011: ROM Path is: E:\Games\ROMs\Mame
15:16:31.2 11/05/2011: Catver.ini is located at: E:\GameEx\DATA\catver.ini
15:16:31.2 11/05/2011: controls.ini is located at: E:\GameEx\data\controls.ini
15:16:31.2 11/05/2011: History.dat is located at: E:\GameEx\DATA\history.dat
15:16:31.2 11/05/2011: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
15:16:31.2 11/05/2011: command.dat is located at: E:\GameEx\DATA\command.dat
15:16:31.2 11/05/2011: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
15:16:31.2 11/05/2011: Loading Controls.ini map file
15:16:31.2 11/05/2011: Snap Path is: E:\Games\emulated\Mame32\snap
15:16:31.2 11/05/2011: AVI Snap Path is: E:\Video\avisnap
15:16:31.2 11/05/2011: Flyer Path is: E:\Games\emulated\Mame32\flyers
15:16:31.2 11/05/2011: Cabinet Path is: E:\Games\emulated\Mame32\cabinets
15:16:31.2 11/05/2011: Cabinet 3D Path is: E:\Games\emulated\Mame32\cabinets
15:16:31.2 11/05/2011: Title Path is: E:\Games\emulated\Mame32\titles
15:16:31.2 11/05/2011: PCB Path is: E:\Games\emulated\Mame32\pcb
15:16:31.2 11/05/2011: Artwork Preview Path is: E:\Games\emulated\Mame32\artwork
15:16:31.2 11/05/2011: Panel Path is: E:\Games\emulated\Mame32\cpanel
15:16:31.2 11/05/2011: Manual Path: Not Found
15:16:31.2 11/05/2011: Icon Path is: E:\Games\emulated\Mame32\icons
15:16:31.2 11/05/2011: Marquee Path is: E:\Games\emulated\Mame32\marquees
15:16:31.2 11/05/2011: Loading Custom Emulators
15:16:31.2 11/05/2011: Loading Emulator 1: Panasonic 3DO
15:16:31.2 11/05/2011: Loading Emulator 3: [Console] Atari 2600 (Stella)
15:16:31.2 11/05/2011: Loading Emulator 4: [Console] Atari 5200 (MESS)
15:16:31.2 11/05/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
15:16:31.2 11/05/2011: Loading Emulator 6: Atari Jaguar
15:16:31.2 11/05/2011: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
15:16:31.2 11/05/2011: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
15:16:31.2 11/05/2011: Loading Emulator 9: [Console] Coleco Vision (MESS)
15:16:31.2 11/05/2011: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
15:16:31.2 11/05/2011: Loading Emulator 11: [Arcade] Arcade (FB Alpha)
15:16:31.2 11/05/2011: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
15:16:31.2 11/05/2011: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
15:16:31.2 11/05/2011: Loading Emulator 14: Mattel Intellivision (MESS)
15:16:31.2 11/05/2011: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
15:16:31.2 11/05/2011: Loading Emulator 17: [Console] Nintendo N64 (Project64)
15:16:31.2 11/05/2011: Loading Emulator 18: [Console] Nintendo NES (Jnes)
15:16:31.2 11/05/2011: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
15:16:31.2 11/05/2011: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
15:16:31.2 11/05/2011: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
15:16:31.2 11/05/2011: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
15:16:31.2 11/05/2011: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
15:16:31.2 11/05/2011: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
15:16:31.2 11/05/2011: Loading Emulator 25: Sam Coupe
15:16:31.2 11/05/2011: Loading Emulator 26: [Console] Sega Dreamcast (nullDC)
15:16:31.2 11/05/2011: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
15:16:31.2 11/05/2011: Loading Emulator 28: [Console] Sega Master System (Fusion)
15:16:31.2 11/05/2011: Loading Emulator 29: [Console] Sega Genesis (Fusion)
15:16:31.2 11/05/2011: Loading Emulator 30: [PC] Microsoft MSX (MESS)
15:16:31.2 11/05/2011: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
15:16:31.2 11/05/2011: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
15:16:31.2 11/05/2011: Loading Emulator 38: [Console] Sega Saturn (SSF)
15:16:31.2 11/05/2011: Loading Emulator 39: [PC] Microsoft Windows
15:16:31.2 11/05/2011: Loading Emulator 40: [Console] Sega 32X (Fusion)
15:16:31.2 11/05/2011: Loading Emulator 42: [PC] Microsoft Windows CD
15:16:31.2 11/05/2011: Loading Emulator 43: [Arcade] Arcade (ZiNc)
15:16:31.2 11/05/2011: Using 3D Alpha Blended Animations.
15:16:31.2 11/05/2011: Using General Font: Trebuchet MS
15:16:31.2 11/05/2011: Using Title Font: Trebuchet MS
15:16:31.3 11/05/2011: Initialising Direct3D
15:16:31.3 11/05/2011: Applying GameEx is Loading Image
15:16:31.3 11/05/2011: Setting Resolution to 1360x768 32 bit color
15:16:31.3 11/05/2011: Creating Surfaces
15:16:31.5 11/05/2011: Creating Primary Surface - Full Screen Mode
15:16:31.5 11/05/2011: Creating Back Buffer
15:16:31.5 11/05/2011: Loading graphic Surfaces
15:16:31.5 11/05/2011: Display is running at: 1360x768 32bit color, 60hz
15:16:31.5 11/05/2011: Creating Surfaces Misc and Dialogs
15:16:31.6 11/05/2011: Creating Surfaces Volume
15:16:31.6 11/05/2011: Creating Surfaces Arrows
15:16:31.6 11/05/2011: Creating Surfaces GameEXlogo Text
15:16:31.6 11/05/2011: Creating Surfaces Toolbar
15:16:31.6 11/05/2011: Creating Surfaces Backgrounds
15:16:31.6 11/05/2011: Creating Surfaces Toolbar Controls
15:16:31.6 11/05/2011: Creating Surfaces GameEx Logo
15:16:31.6 11/05/2011: Creating Surface Unselected
15:16:31.6 11/05/2011: Creating Surfaces Snaps
15:16:31.6 11/05/2011: Creating Surfaces Menu and List Bars
15:16:31.6 11/05/2011: Creating Fonts
15:16:31.6 11/05/2011: Creating Game Font
15:16:31.7 11/05/2011: Creating Game Font Faded
15:16:31.8 11/05/2011: Creating Title Font
15:16:31.8 11/05/2011: Restoring Title Font From Cache
15:16:31.9 11/05/2011: Creating Font Black
15:16:32.0 11/05/2011: Creating Font Black Small
15:16:32.0 11/05/2011: Fonts Created Succesfully
15:16:32.0 11/05/2011: Initialising Bass Audio Library
15:16:32.0 11/05/2011: Creating instance of global keyboard hook
15:16:32.3 11/05/2011: Playing Startup Video on thread
15:16:32.3 11/05/2011: Attempting to load game list
15:16:32.4 11/05/2011: Applying Language/Text
15:16:32.4 11/05/2011: Text/Language: English
15:16:32.4 11/05/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
15:16:32.4 11/05/2011: Loading last used Game List
15:16:32.5 11/05/2011: Creating DirectSound Device
15:16:32.5 11/05/2011: Trying: Primary Sound Driver
15:16:32.5 11/05/2011: Loading Sound Files
15:16:32.5 11/05/2011: DirectSound Device Created Successfully
15:16:32.5 11/05/2011: Initialising DirectInput for Gamepad support
15:16:32.6 11/05/2011: Using Device Controller (XBOX 360 For Windows)
15:16:32.6 11/05/2011: Using Device Nintendo RVL-CNT-01
15:16:32.6 11/05/2011: Initializing MCE Remote
15:16:32.6 11/05/2011: Playing intro sound file
15:16:32.7 11/05/2011: Initialization OK! Starting GameEx!
15:16:32.7 11/05/2011: Testing Main Loop Once: Processing Frame
15:16:32.9 11/05/2011: Testing Main Loop Once: Main Loop ran successfully
15:16:42.5 11/05/2011: Validating: Emulator_1: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_1: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_1: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_1: Database: [Console] Panasonic 3DO
15:16:42.5 11/05/2011: Validating: Emulator_3: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_3: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_3: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_3: Database: [Console] Atari 2600
15:16:42.5 11/05/2011: Validating: Emulator_4: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_4: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_4: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_4: Database: [Console] Atari 5200
15:16:42.5 11/05/2011: Validating: Emulator_5: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_5: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_5: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_5: Database: [Console] Atari 7800
15:16:42.5 11/05/2011: Validating: Emulator_6: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_6: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_6: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_6: Database: [Console] Atari Jaguar
15:16:42.5 11/05/2011: Validating: Emulator_7: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_7: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_7: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_7: Database: [Handheld] Atari Lynx
15:16:42.5 11/05/2011: Validating: Emulator_8: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_8: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_8: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_8: Database: [Handheld] Bandai WonderSwan Color
15:16:42.5 11/05/2011: Validating: Emulator_9: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_9: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_9: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_9: Database: [Console] Coleco Vision
15:16:42.5 11/05/2011: Validating: Emulator_10: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_10: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_10: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_10: Database: [Console] Fairchild Channel F
15:16:42.5 11/05/2011: Validating: Emulator_11: Custom Background: E:\Games\emulated\mame\Snaps
15:16:42.5 11/05/2011: Warning: Emulator_11: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Snap Path: E:\Games\emulated\mame\Snaps
15:16:42.5 11/05/2011: Warning: Emulator_11: Snap Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Control Panel Path: E:\Games\emulated\mame\Controls
15:16:42.5 11/05/2011: Warning: Emulator_11: Control Panel Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Title Snap Path: E:\Games\emulated\mame\Titles
15:16:42.5 11/05/2011: Warning: Emulator_11: Title Snap Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Box Art Path: E:\Games\emulated\mame\Boxes
15:16:42.5 11/05/2011: Warning: Emulator_11: Box Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Cart Art Path: E:\Games\emulated\mame\Cartridges
15:16:42.5 11/05/2011: Warning: Emulator_11: Cart Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_11: Manual Path: E:\Games\emulated\mame\Manuals
15:16:42.5 11/05/2011: Warning: Emulator_11: Manual Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_12: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_12: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_12: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
15:16:42.5 11/05/2011: Validating: Emulator_13: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_13: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_13: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_13: Database: [Handheld] Nintendo DS
15:16:42.5 11/05/2011: Validating: Emulator_14: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_14: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_14: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_14: Database: [Console] Mattel Intellivision
15:16:42.5 11/05/2011: Validating: Emulator_16: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_16: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_16: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_16: Database: [Handheld] SNK Neo-Geo Pocket
15:16:42.5 11/05/2011: Validating: Emulator_17: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_17: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_17: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_17: Database: [Console] Nintendo N64
15:16:42.5 11/05/2011: Validating: Emulator_18: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_18: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_18: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_18: Database: [Console] Nintendo NES
15:16:42.5 11/05/2011: Validating: Emulator_19: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_19: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_19: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_19: Database: [Console] Nintendo GameCube
15:16:42.5 11/05/2011: Validating: Emulator_20: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_20: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_20: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_20: Database: [Handheld] Nintendo Virtual Boy
15:16:42.5 11/05/2011: Validating: Emulator_21: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_21: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_21: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_21: Database: [Console] Nintendo GameCube
15:16:42.5 11/05/2011: Validating: Emulator_22: Custom Background: E:\Games\emulated\PC Engine\Snaps
15:16:42.5 11/05/2011: Warning: Emulator_22: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Snap Path: E:\Games\emulated\PC Engine\Snaps
15:16:42.5 11/05/2011: Warning: Emulator_22: Snap Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Control Panel Path: E:\Games\emulated\PC Engine\Controls
15:16:42.5 11/05/2011: Warning: Emulator_22: Control Panel Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Database: [Console] NEC TurboGrafx-16
15:16:42.5 11/05/2011: Validating: Emulator_22: Title Snap Path: E:\Games\emulated\PC Engine\Titles
15:16:42.5 11/05/2011: Warning: Emulator_22: Title Snap Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Box Art Path: E:\Games\emulated\PC Engine\Boxes
15:16:42.5 11/05/2011: Warning: Emulator_22: Box Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Cart Art Path: E:\Games\emulated\PC Engine\Cartridges
15:16:42.5 11/05/2011: Warning: Emulator_22: Cart Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_22: Manual Path: E:\Games\emulated\PC Engine\Manuals
15:16:42.5 11/05/2011: Warning: Emulator_22: Manual Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_23: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_23: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_23: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_23: Database: [Console] Sony Playstation
15:16:42.5 11/05/2011: Warning: Emulator_23: MAPFile Does Not Exist
15:16:42.5 11/05/2011: Validating: Emulator_24: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_24: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_24: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_24: Database: [Console] Sony Playstation 2
15:16:42.5 11/05/2011: Warning: Emulator_24: MAPFile Does Not Exist
15:16:42.5 11/05/2011: Validating: Emulator_25: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_25: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_25: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_25: Database: Template
15:16:42.5 11/05/2011: Validating: Emulator_26: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_26: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_26: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_26: Database: [Console] Sega Dreamcast
15:16:42.5 11/05/2011: Validating: Emulator_27: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_27: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_27: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_27: Database: [Handheld] Sega Game Gear
15:16:42.5 11/05/2011: Validating: Emulator_28: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_28: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_28: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_28: Database: [Console] Sega Master System
15:16:42.5 11/05/2011: Validating: Emulator_29: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_29: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_29: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_29: Database: [Console] Sega Genesis
15:16:42.5 11/05/2011: Validating: Emulator_29: Box Art Path: E:\Games\emu
15:16:42.5 11/05/2011: Warning: Emulator_29: Box Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_30: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_30: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_30: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_30: Database: [PC] Microsoft MSX
15:16:42.5 11/05/2011: Validating: Emulator_31: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_31: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_31: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_31: Database: [PC] Microsoft MSX 2
15:16:42.5 11/05/2011: Validating: Emulator_32: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_32: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_32: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_32: Database: [Console] Nintendo SNES
15:16:42.5 11/05/2011: Validating: Emulator_38: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_38: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_38: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_38: Database: [Console] Sega Saturn
15:16:42.5 11/05/2011: Validating: Emulator_39: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_39: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_39: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_40: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_40: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_40: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_40: Database: [Console] Sega 32X
15:16:42.5 11/05/2011: Validating: Emulator_40: Box Art Path: E:\Games\emu
15:16:42.5 11/05/2011: Warning: Emulator_40: Box Art Path Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_42: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_42: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_42: Snap Path:
15:16:42.5 11/05/2011: Validating: Emulator_43: Custom Background:
15:16:42.5 11/05/2011: Warning: Emulator_43: Custom Background Does not exist
15:16:42.5 11/05/2011: Validating: Emulator_43: Snap Path:
15:16:42.5 11/05/2011: Restoring Emulator from Cache
15:16:42.5 11/05/2011: Restoring Emulator Database From Cache
15:16:42.6 11/05/2011: Restoring Emulator from Cache
15:16:42.6 11/05/2011: Restoring Emulator Database From Cache
15:16:42.7 11/05/2011: Restoring Emulator from Cache
15:16:42.7 11/05/2011: Restoring Emulator Database From Cache
15:16:42.8 11/05/2011: Restoring Emulator from Cache
15:16:42.8 11/05/2011: Restoring Emulator Database From Cache
15:16:42.9 11/05/2011: Restoring Emulator Database From Cache
15:16:42.9 11/05/2011: Not Restoring Emulator from Cache
15:16:42.9 11/05/2011: Restoring Emulator from Cache
15:16:42.9 11/05/2011: No Database Data
15:16:43.0 11/05/2011: Restoring Emulator from Cache
15:16:43.0 11/05/2011: Restoring Emulator Database From Cache
15:16:43.2 11/05/2011: Restoring Emulator from Cache
15:16:43.2 11/05/2011: No Database Data
15:16:43.2 11/05/2011: Restoring Emulator Database From Cache
15:16:43.3 11/05/2011: Restoring Emulator from Cache
15:16:43.3 11/05/2011: No Database Data
15:16:43.3 11/05/2011: Restoring Emulator Database From Cache
15:16:43.4 11/05/2011: Restoring Emulator from Cache
15:16:43.4 11/05/2011: Restoring Emulator Database From Cache
15:16:43.5 11/05/2011: Not Restoring Emulator from Cache
15:16:43.5 11/05/2011: Restoring Emulator from Cache
15:16:43.5 11/05/2011: Restoring Emulator Database From Cache
15:16:43.6 11/05/2011: Restoring Emulator from Cache
15:16:43.6 11/05/2011: Restoring Emulator Database From Cache
15:16:43.7 11/05/2011: Restoring Emulator from Cache
15:16:43.7 11/05/2011: No Database Data
15:16:43.7 11/05/2011: Restoring Emulator Database From Cache
15:16:47.7 11/05/2011: Restoring Emulator from Cache
15:16:53.0 11/05/2011: Running: cmd.exe /c E: Fusion.exe -gen -fullscreen "E:\Games\ROMs\Sega megadrive\Europe\Sega Genesis-Mega Drive & 32x Roms [5,871] [Full Set].7z"
15:16:53.1 11/05/2011: Shutting down display
15:17:06.7 11/05/2011: Exiting Game
15:17:06.7 11/05/2011: Closing Process
15:17:09.6 11/05/2011: Writing Stats
15:17:09.6 11/05/2011: Plugin: Game Exit
15:17:09.6 11/05/2011: Plugin: Process Commands
15:17:09.6 11/05/2011: Refreshing Keyboard
15:17:09.7 11/05/2011: Initialising Audio
15:17:09.9 11/05/2011: Restoring Window
15:17:09.9 11/05/2011: Reinitializing Graphics System
15:17:10.7 11/05/2011: Reloading Game Info Page
15:17:10.8 11/05/2011: Returning to GameEx
15:17:12.8 11/05/2011: Exiting GameEx!
15:17:12.8 11/05/2011: Saving Settings
15:17:14.5 11/05/2011: Disposing Plugins
15:17:14.5 11/05/2011: Closing database connection
15:17:14.5 11/05/2011: Checking for applications to Launch On Exit
15:17:14.5 11/05/2011: Media Center was not open when starting GameEx, so not launching
runitbat
E:
that "E:\Games\ROMs\Sega megadrive\Europe\Sega Genesis-Mega Drive & 32x Roms [5,871] [Full Set].7z" does not exist 100% somewhere Game EX is remembering that path, but I have no idea where.
I enabled and disabled 7z support and even disbled to scan subdirectories.
Definitley stuck on this one
Please fix your working path. Also you can meet me in chat if you want real-time support. Chat is found on top of forums. There's a tab there for you to click.
Seems like it's trying to load a file called that. A 7zip file. Do you have that file? Maybe your list needs to be rebuilt. Is that file being called when you load any file or does that appear on the list?
[RESOLVED] There was in fact a file called that previously. The map file needed to be rebuilt. The weird thing is that I didn't see a map file for it. I noticed that rom filters had spaces (i.e. "*.bin; *.smd") and I corrected this and then noticed that the map file was built. I then deleted it and it rebuilt just fine and issue was resolved. So I'm assuming that having spaces in the rom filter is not a good thing? Also where is this info cached as it wasn't cached in the any of the cache files related to that emu number?
No, the ROM filter has to be without spaces: *.smc;*.zip etc.
Are you talking about the db cache?
That was the odd thing, Massop did not insert spaces. Not sure how they got there.
No. Not the db cache as those don't store this data.
Actually he did have spaces as indicated in my post. Spaces were after the semi-colon.
I could have sworn the map file was not there but when I made the change to the rom filter then it was. But I could be wrong about that. The thing is when it was refreshed, it was a file created at an earlier date according to the file and it created based off an old file he had before. So not sure if it were cached somewhere or what. :blink:
So understand better:
  • Opened DATA folder so that I could manually delete map file according to this emulator but was not there (or at least don't think it was. LOL.).
  • Then I noticed the filters and I changed them in hopes that the map file would be created correctly.
  • Then noticed the map file there but it had a timestamp from an earlier date.
  • Deleted it
  • Resolved as the list rebuilt.
So either I didn't notice map file before or it was created based on something else. According to massop, he deleted all files in the data folder according to that emulator.
Hmm, unusual for sure. I can see the cache file having a problem in building with the spaces in the ROM filter. The crazy part to me is that GameEx pulled an old cache file from thin air somehow. I had a similar issue many builds ago, but not sure when it was resolved. I was waffling between using GoodMerge SNES roms, and for some reason when I switched to a folder that only had US roms in it the list was empty. When I switched back to the 7z files, the list came back up. To fix it I ended up deleting the emulator completely from GameEx and redoing it. Never had an issue again. *shrugs*
