(SOLVED)
Hi everybody,
I just bought the registered GameEx and really think it will work great for what I want but I just created a slight problem: I had all my SNES games listed on the first GameEx run but after that, I exited GameEx, rename de "Roms" folder to "Archives", then created an empty "Roms" folder and though only a dozen roms in it.
Since then, when I launch GameEx, it says I dont have any SNES game. I checked the path, but a simple copy/paste from the configuration to Explorer shows the path is correct and my smc files are there.
I then tried to rollback my action by deleting the newly created "Roms" folder and renaming "Archives" to "Roms" but still I cant list any SNES game, whereas games for other problems show without a problem.
Thanks for yor help !
Nothing of use in the logs:
07:04:51.7  07/05/2011:  GameEx: Version 11.71: Starting Log
07:04:51.7 07/05/2011: Operating System Platform: Win32NT
07:04:51.7 07/05/2011: Operating System Name: Windows Vista
07:04:51.7 07/05/2011: Operating System Version: 6.1.7601
07:04:51.7 07/05/2011: Aero running
07:04:51.7 07/05/2011: Initializing Vista/Windows 7 volume control
07:04:51.7 07/05/2011: Checking for versions of .net Framework installed
07:04:51.7 07/05/2011: .net Framework 2.0 Installed
07:04:51.7 07/05/2011: .net Framework 3.0 Installed
07:04:51.7 07/05/2011: .net Framework 3.5 Installed
07:04:51.7 07/05/2011: Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz, 4094MB
07:04:51.8 07/05/2011: 3Ghz - 4 Cores or CPU's
07:04:51.8 07/05/2011: Running Randomize()
07:04:51.8 07/05/2011: Loading PlugIns
07:04:51.8 07/05/2011: Checking for applications to Launch On Startup
07:04:51.8 07/05/2011: Running Misc startup tasks
07:04:51.8 07/05/2011: Setting Menu types
07:04:51.8 07/05/2011: Opening Configuration File
07:04:51.8 07/05/2011: Getting Configuration Values
07:04:51.8 07/05/2011: Using Theme: Default - Dark Gloss V1
07:04:51.8 07/05/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss V1
07:04:51.8 07/05/2011: Using Images from theme: Default - Dark Gloss\MEDIA\
07:04:51.8 07/05/2011: Initialising Video/MNG DLL's
07:04:51.8 07/05/2011: GameEx will check for media insertion (may affect performance)
07:04:51.8 07/05/2011: Is Media Center running?
07:04:51.8 07/05/2011: Checking/Creating LCD Registry values
07:04:51.8 07/05/2011: Check Media Center Exit/Start Mode
07:04:51.8 07/05/2011: Media Center Mode 2
07:04:51.8 07/05/2011: Video previews on. Warning: Only recommended on modern systems
07:04:51.8 07/05/2011: Snap Delay set to: 5
07:04:51.8 07/05/2011: Get other settings
07:04:51.8 07/05/2011: Desktop set to Hide ICONS and set Background to Black
07:04:51.8 07/05/2011: Set: Find emulator artwork on best match basis
07:04:51.8 07/05/2011: Start work for Form
07:04:51.8 07/05/2011: Getting Original Screen Size
07:04:51.8 07/05/2011: Opening Database Connection
07:04:51.8 07/05/2011: Initializing Component
07:04:51.9 07/05/2011: Retrieving resolution setting
07:04:51.9 07/05/2011: Loading Controls.ini map file
07:04:51.9 07/05/2011: Loading Custom Emulators
07:04:51.9 07/05/2011: Loading Emulator 1: [Console] Nintendo SNES
07:04:51.9 07/05/2011: Loading Emulator 2: [Console] Nintendo N64
07:04:51.9 07/05/2011: Loading Emulator 4: [Console] Sega Genesis
07:04:51.9 07/05/2011: Loading Emulator 5: [Console] Sega Master System
07:04:51.9 07/05/2011: Loading Emulator 6: [Handheld] Nintendo DS
07:04:51.9 07/05/2011: Loading Emulator 7: [Handheld] Nintendo Game Boy Color
07:04:51.9 07/05/2011: Loading Emulator 8: [Handheld] Sega Game Gear
07:04:51.9 07/05/2011: Loading Emulator 9: [PC] Microsoft DOS
07:04:51.9 07/05/2011: Loading Emulator 10: [PC] Scumm
07:04:51.9 07/05/2011: Loading Emulator 11: [Pinball] Pinball
07:04:51.9 07/05/2011: Using 3D Alpha Blended Animations.
07:04:51.9 07/05/2011: Using General Font: Trebuchet MS
07:04:51.9 07/05/2011: Using Title Font: Trebuchet MS
07:04:51.9 07/05/2011: Initialising Direct3D
07:04:51.9 07/05/2011: Applying GameEx is Loading Image
07:04:52.0 07/05/2011: Creating Surfaces
07:04:52.0 07/05/2011: Creating Primary Surface - Windowed Mode
07:04:52.0 07/05/2011: Creating Back Buffer
07:04:52.0 07/05/2011: Loading graphic Surfaces
07:04:52.0 07/05/2011: Display is running at: 1440x900 32bit color, 60hz
07:04:52.1 07/05/2011: Creating Surfaces Misc and Dialogs
07:04:52.1 07/05/2011: Creating Surfaces Volume
07:04:52.1 07/05/2011: Creating Surfaces Arrows
07:04:52.1 07/05/2011: Creating Surfaces GameEXlogo Text
07:04:52.2 07/05/2011: Creating Surfaces Toolbar
07:04:52.2 07/05/2011: Creating Surfaces Backgrounds
07:04:52.2 07/05/2011: Creating Surfaces Toolbar Controls
07:04:52.2 07/05/2011: Creating Surfaces GameEx Logo
07:04:52.2 07/05/2011: Creating Surface Unselected
07:04:52.2 07/05/2011: Creating Surfaces Home & Exit
07:04:52.2 07/05/2011: Creating Surfaces Snaps
07:04:52.2 07/05/2011: Creating Surfaces Menu and List Bars
07:04:52.3 07/05/2011: Creating Fonts
07:04:52.3 07/05/2011: Creating Game Font
07:04:52.4 07/05/2011: Creating Game Font Faded
07:04:52.4 07/05/2011: Creating Title Font
07:04:52.4 07/05/2011: Restoring Title Font From Cache
07:04:52.5 07/05/2011: Creating Menu Font
07:04:52.5 07/05/2011: Creating Font Black
07:04:52.6 07/05/2011: Creating Font Black Small
07:04:52.6 07/05/2011: Fonts Created Succesfully
07:04:52.6 07/05/2011: 1MB Video Memory Used
07:04:52.6 07/05/2011: Initialising Bass Audio Library
07:04:52.6 07/05/2011: Creating instance of global keyboard hook
07:04:52.8 07/05/2011: Starting GameExtender on: 192.168.0.10:80
07:04:52.8 07/05/2011: Applying Language/Text
07:04:52.8 07/05/2011: Text/Language: French
07:04:52.8 07/05/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
07:04:52.8 07/05/2011: Loading last used Game List
07:04:52.8 07/05/2011: Creating DirectSound Device
07:04:52.8 07/05/2011: Trying: Périphérique audio principal
07:04:52.8 07/05/2011: Loading Sound Files
07:04:52.8 07/05/2011: DirectSound Device Created Successfully
07:04:52.8 07/05/2011: Initialising DirectInput for Gamepad support
07:04:53.0 07/05/2011: Using Device Logitech Cordless RumblePad 2
07:04:53.2 07/05/2011: Initializing MCE Remote
07:04:53.2 07/05/2011: Initialization OK! Starting GameEx!
07:04:53.2 07/05/2011: Testing Main Loop Once: Processing Frame
07:04:53.5 07/05/2011: Testing Main Loop Once: Main Loop ran successfully
07:05:03.2 07/05/2011: Validating: Emulator_1: Custom Background: Y:\Emulateurs\Assets\Nintendo SNES\Snaps
07:05:03.2 07/05/2011: Warning: Emulator_1: Custom Background Does not exist
07:05:03.2 07/05/2011: Validating: Emulator_1: Snap Path: Y:\Emulateurs\Assets\Nintendo SNES\Snaps
07:05:03.2 07/05/2011: Validating: Emulator_1: Control Panel Path: Y:\Emulateurs\Assets\Nintendo SNES\Controls
07:05:03.2 07/05/2011: Validating: Emulator_1: Database: [Console] Nintendo SNES
07:05:03.2 07/05/2011: Validating: Emulator_1: Title Snap Path: Y:\Emulateurs\Assets\Nintendo SNES\Titles
07:05:03.2 07/05/2011: Validating: Emulator_1: Box Art Path: Y:\Emulateurs\Assets\Nintendo SNES\Boxes
07:05:03.2 07/05/2011: Validating: Emulator_1: Cart Art Path: Y:\Emulateurs\Assets\Nintendo SNES\Cartridges
07:05:03.2 07/05/2011: Validating: Emulator_1: Manual Path: Y:\Emulateurs\Assets\Nintendo SNES\Manuals
07:05:03.2 07/05/2011: Validating: Emulator_2: Custom Background: Y:\Emulateurs\Assets\Nintendo N64\Snaps
07:05:03.2 07/05/2011: Warning: Emulator_2: Custom Background Does not exist
07:05:03.2 07/05/2011: Validating: Emulator_2: Snap Path: Y:\Emulateurs\Assets\Nintendo N64\Snaps
07:05:03.2 07/05/2011: Validating: Emulator_2: Control Panel Path: Y:\Emulateurs\Assets\Nintendo N64\Controls
07:05:03.2 07/05/2011: Validating: Emulator_2: Database: [Console] Nintendo N64
07:05:03.2 07/05/2011: Validating: Emulator_2: Title Snap Path: Y:\Emulateurs\Assets\Nintendo N64\Titles
07:05:03.2 07/05/2011: Validating: Emulator_2: Box Art Path: Y:\Emulateurs\Assets\Nintendo N64\Boxes
07:05:03.2 07/05/2011: Validating: Emulator_2: Cart Art Path: Y:\Emulateurs\Assets\Nintendo N64\Cartridges
07:05:03.2 07/05/2011: Validating: Emulator_2: Manual Path: Y:\Emulateurs\Assets\Nintendo N64\Manuals
07:05:03.2 07/05/2011: Validating: Emulator_4: Custom Background: Y:\Emulateurs\Assets\Sega Genesis\Snaps
07:05:03.2 07/05/2011: Warning: Emulator_4: Custom Background Does not exist
07:05:03.2 07/05/2011: Validating: Emulator_4: Snap Path: Y:\Emulateurs\Assets\Sega Genesis\Snaps
07:05:03.2 07/05/2011: Validating: Emulator_4: Control Panel Path: Y:\Emulateurs\Assets\Sega Genesis\Controls
07:05:03.2 07/05/2011: Validating: Emulator_4: Database: [Console] Sega Genesis
07:05:03.2 07/05/2011: Validating: Emulator_4: Title Snap Path: Y:\Emulateurs\Assets\Sega Genesis\Titles
07:05:03.2 07/05/2011: Validating: Emulator_4: Box Art Path: Y:\Emulateurs\Assets\Sega Genesis\Boxes
07:05:03.2 07/05/2011: Validating: Emulator_4: Cart Art Path: Y:\Emulateurs\Assets\Sega Genesis\Cartridges
07:05:03.2 07/05/2011: Validating: Emulator_4: Manual Path: Y:\Emulateurs\Assets\Sega Genesis\Manuals
07:05:03.2 07/05/2011: Validating: Emulator_5: Custom Background: Y:\Emulateurs\Assets\Sega Master System\Snaps
07:05:03.2 07/05/2011: Warning: Emulator_5: Custom Background Does not exist
07:05:03.2 07/05/2011: Validating: Emulator_5: Snap Path: Y:\Emulateurs\Assets\Sega Master System\Snaps
07:05:03.2 07/05/2011: Validating: Emulator_5: Control Panel Path: Y:\Emulateurs\Assets\Sega Master System\Controls
07:05:03.2 07/05/2011: Validating: Emulator_5: Database: [Console] Sega Master System
07:05:03.2 07/05/2011: Validating: Emulator_5: Title Snap Path: Y:\Emulateurs\Assets\Sega Master System\Titles
07:05:03.3 07/05/2011: Validating: Emulator_5: Box Art Path: Y:\Emulateurs\Assets\Sega Master System\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_5: Cart Art Path: Y:\Emulateurs\Assets\Sega Master System\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_5: Manual Path: Y:\Emulateurs\Assets\Sega Master System\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_6: Custom Background: Y:\Emulateurs\Assets\Nintendo DS\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_6: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_6: Snap Path: Y:\Emulateurs\Assets\Nintendo DS\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_6: Control Panel Path: Y:\Emulateurs\Assets\Nintendo DS\Controls
07:05:03.3 07/05/2011: Validating: Emulator_6: Database: [Handheld] Nintendo DS
07:05:03.3 07/05/2011: Validating: Emulator_6: Title Snap Path: Y:\Emulateurs\Assets\Nintendo DS\Titles
07:05:03.3 07/05/2011: Validating: Emulator_6: Box Art Path: Y:\Emulateurs\Assets\Nintendo DS\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_6: Cart Art Path: Y:\Emulateurs\Assets\Nintendo DS\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_6: Manual Path: Y:\Emulateurs\Assets\Nintendo DS\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_7: Custom Background: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_7: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_7: Snap Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_7: Control Panel Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Controls
07:05:03.3 07/05/2011: Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Color
07:05:03.3 07/05/2011: Validating: Emulator_7: Title Snap Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Titles
07:05:03.3 07/05/2011: Validating: Emulator_7: Box Art Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_7: Cart Art Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_7: Manual Path: Y:\Emulateurs\Assets\Nintendo Game Boy Color\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_8: Custom Background: Y:\Emulateurs\Assets\Sega Game Gear\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_8: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_8: Snap Path: Y:\Emulateurs\Assets\Sega Game Gear\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_8: Control Panel Path: Y:\Emulateurs\Assets\Sega Game Gear\Controls
07:05:03.3 07/05/2011: Validating: Emulator_8: Database: [Handheld] Sega Game Gear
07:05:03.3 07/05/2011: Validating: Emulator_8: Title Snap Path: Y:\Emulateurs\Assets\Sega Game Gear\Titles
07:05:03.3 07/05/2011: Validating: Emulator_8: Box Art Path: Y:\Emulateurs\Assets\Sega Game Gear\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_8: Cart Art Path: Y:\Emulateurs\Assets\Sega Game Gear\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_8: Manual Path: Y:\Emulateurs\Assets\Sega Game Gear\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_9: Custom Background: Y:\Emulateurs\Assets\Microsoft DOS\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_9: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_9: Snap Path: Y:\Emulateurs\Assets\Microsoft DOS\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_9: Control Panel Path: Y:\Emulateurs\Assets\Microsoft DOS\Controls
07:05:03.3 07/05/2011: Validating: Emulator_9: Title Snap Path: Y:\Emulateurs\Assets\Microsoft DOS\Titles
07:05:03.3 07/05/2011: Validating: Emulator_9: Box Art Path: Y:\Emulateurs\Assets\Microsoft DOS\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_9: Cart Art Path: Y:\Emulateurs\Assets\Microsoft DOS\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_9: Manual Path: Y:\Emulateurs\Assets\Microsoft DOS\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_10: Custom Background: Y:\Emulateurs\Assets\ScummVM\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_10: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_10: Snap Path: Y:\Emulateurs\Assets\ScummVM\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_10: Control Panel Path: Y:\Emulateurs\Assets\ScummVM\Controls
07:05:03.3 07/05/2011: Validating: Emulator_10: Database: [PC] ScummVM
07:05:03.3 07/05/2011: Validating: Emulator_10: Title Snap Path: Y:\Emulateurs\Assets\ScummVM\Titles
07:05:03.3 07/05/2011: Validating: Emulator_10: Box Art Path: Y:\Emulateurs\Assets\ScummVM\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_10: Cart Art Path: Y:\Emulateurs\Assets\ScummVM\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_10: Manual Path: Y:\Emulateurs\Assets\ScummVM\Manuals
07:05:03.3 07/05/2011: Validating: Emulator_11: Custom Background: Y:\Emulateurs\Assets\Visual Pinball\Snaps
07:05:03.3 07/05/2011: Warning: Emulator_11: Custom Background Does not exist
07:05:03.3 07/05/2011: Validating: Emulator_11: Snap Path: Y:\Emulateurs\Assets\Visual Pinball\Snaps
07:05:03.3 07/05/2011: Validating: Emulator_11: Control Panel Path: Y:\Emulateurs\Assets\Visual Pinball\Controls
07:05:03.3 07/05/2011: Validating: Emulator_11: Database: [Pinball] Visual Pinball
07:05:03.3 07/05/2011: Validating: Emulator_11: Title Snap Path: Y:\Emulateurs\Assets\Visual Pinball\Titles
07:05:03.3 07/05/2011: Validating: Emulator_11: Box Art Path: Y:\Emulateurs\Assets\Visual Pinball\Boxes
07:05:03.3 07/05/2011: Validating: Emulator_11: Cart Art Path: Y:\Emulateurs\Assets\Visual Pinball\Cartridges
07:05:03.3 07/05/2011: Validating: Emulator_11: Manual Path: Y:\Emulateurs\Assets\Visual Pinball\Manuals
07:05:03.4 07/05/2011: Restoring Emulator from Cache
07:05:03.4 07/05/2011: Restoring Emulator Database From Cache
07:05:03.5 07/05/2011: Restoring Emulator from Cache
07:05:03.5 07/05/2011: Restoring Emulator Database From Cache
07:05:03.8 07/05/2011: Restoring Emulator from Cache
07:05:03.8 07/05/2011: Restoring Emulator Database From Cache
Perhaps I should enable a debug thing somewhere ?
In the GameEx program folder, you need to go to the data folder and delete anything that ends in .cache
I honestly think it's either your rom filter or rom path. Can you plese post your emulator config? You can export it under 'Advanced Configuration', emulator 1, 3rd option from the top. Then zip the ini and post it to the forum so we can have a look.
Well that was fast, thanks.
I deleted *.*cache in the DATA folder but it didn't solve the problem.
I attached the INI file and am trying to find any issue in it at the same time, it may prove easier than in the config utility. Thanks again :)
Edit:
Well the file shows:
RomPath=Y:\Emulateurs\ROMs\Nintendo SNES\Roms
Let's give it a try:
 Le volume dans le lecteur Y s'appelle BigFat
Le numéro de série du volume est B284-839E
Répertoire de Y:\Emulateurs\ROMs\Nintendo SNES\Roms
07/05/2011 07:01 <REP> .
07/05/2011 07:01 <REP> ..
22/06/1999 11:24 1 048 576 Zool (U) (Sample).smc
23/08/2004 16:37 1 056 768 Zool (U) [t1].smc
23/08/2004 16:37 1 048 576 Zool (U).smc
23/08/2004 16:37 1 048 576 Zool no Yume Bouken (J).smc
23/08/2004 16:37 524 288 Zoop (E) [!].smc
23/08/2004 16:37 524 288 Zoop (U) [!].smc
23/08/2004 16:37 301 955 Zoop (U) [b1].smc
23/08/2004 16:37 524 288 Zoop (U) [b2].smc
23/08/2004 16:37 524 288 Zoop (U) [f1].smc
23/08/2004 16:37 524 288 Zoop (U) [h1C].smc
27/02/2000 22:33 33 280 Zophar's Domain Two Years Demo (PD).smc
11335 fichier(s) 17 801 996 239 octets
2 Rép(s) 1 535 005 720 576 octets libres
The path looks fine. No filter:
RomFilter=
Still searching...
SNES.zip
Edited by Kian
Kian - I took a look at the .ini file. Looks like all is fine to me there. Please take the following steps, in order, and report back.
1. Exit GameEx if it is running.
2. Delete ALL files containing the word cache in the filename or extension under the \gameex\data path. You will need to manually select the files as a wildcard *.*cache will not eliminate all cached files.
3. Start Snes9x and ensure that the ROM path setup there matches what you have in GameEx. Change it if not, save the change, then exit Snes9x.
4. Restart GameEx.
Let us know how this works for you.
The problem may be here:
GamesIn7Zips=True
This is looking for zipped roms where as the roms in the folder seem to be uncompressed in smc format. Set this to No in setup which will turn this False. Also the map file for this emulator is the one that needs to be deleted to rebuild the list if it doesn't rebuild. According to your setup, it would be the EMU_1.map file located in the DATA directory of your GameEx install.
GamesIn7Zips=True
Nice !!
I changed "GamesIn7Zips=True" to "False" and my games are now listed china.gif
I guess this "problem" was caused by myself and a mix between extensions (*.smc or whatever) and this setting, this was not a bug...
Thank you very much and thanks to everyone who contributed for my rescue !
I still dont know why they showed up before and not afterwards but I guess it must be from me... must have forgotten something at that time, I think I was not that sober ^^
[sOLVED] as we say :D
Thanks again.
Edited by Kian
Nice !!
Thanks again.
No problem! Glad you got it sorted out. Enjoy! ;)
