windows 7 64bit 3.5 core 2 duo 6 gig of ram and nvidia qutro fx 1800 800 meg gpu ram. but internal sound card.
Whats your system specs?.. and no, sound seems ok for me.
what is your config? do you know where to get alternate plugins?
Maybe try the following in Demul:
Config >>> Plugins >>> Uncheck Multi threaded Spu mode (need restart) in the Sound plugin group. >>> restart! >>> run game to see if it helped any.
Also changing titles to your recents topics so that correct name of the emulator returns results in search for future reference.
I will try that. Thanks
What is the title convention I should use?
Well you had DMUAL as the title where the emulator is called Demul. So the convention you used is fine. I just changed it to the correct name so that users can find it from search results.
Do you use custom lists for MAME?
