[RESOLVED] Demul 5.6 Loader for Atomisware
I was wondering if anyone had or could create if they had time a Loader for DMUAL so I can load Atomisware roms in full screen via Game EX? I attached the EMU and bios
You do not really need a wrapper for newest version of Demul since it can now be run from the command line. Here is my working GameEx config for Atomiswave games that runs them full screen. If you would like the Naomi config also, just let me know.
[Emulator_2]
STARTPAGENAME=Arcade - Atomiswave
TITLETEXT=Atomiswave - Arcade
StartPageLogo=Arcade
ROMFilter=
RomPath=C:\demul32-0.5.6\roms
RomsInFolders=True
SnapPath=C:\mame32\video
TitlePath=C:\mame32\snap
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=C:\demul32-0.5.6
MapKeys=True
WaitBeforeKeys=6000
SendKeys=%{ENTER}
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=True
Debug=
MAPFile=C:\GameEx\MAP FILES\DEMUL 0.5.6 (Atomiswave).map
AlsoLaunch=
Command=demul.exe -run=atomiswave -rom=[ROM]
SelectionMusicFolder=
PCGame=
DATABASE=
UseDbName=
GamesIn7Zips=True
MergeSets=True
PlayInScreenSaver=True
ShowMostPlayed=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
  On 3/1/2011 at 12:12 AM, Brian Hoffman said:
Ill look at the fullscreen problem, i believe there is a CFG file you can edit and tell it to go fullscreen.
I don't see one Brian, thats why I use
WaitBeforeKeys=6000
SendKeys=%{ENTER}
in the GameEx config
WaitBeforeKeys=6000
SendKeys=%{ENTER}
That is correct! There isn't a setting to set to fullscreen which is why the sendkeys is suggested.
Don't forget the quotes though:
SendKeys="%{ENTER}"
That's the command I use for Handy and it seems to need the quotes to send these commands together instead of sending them individually.
great I will try but a quick question. Can I rename the rom files? as I tried to do that and Demul could not find them out side of GameEx
SendKeys="%{ENTER}"
K first off my hat goes off to all of you on the form Kick A*$ :) it is all working. I just want to rename the zip files to the full game name if I can as it looks cleaner and easier to select game if yo don't know the naming of the rom :) anyway of doing this
Sorry spelling error Forum lol. other quick Q as I have so many lol. for my EMUS how do I add pix for my roms? I know they have to be in snap folder but what naming convention and extenuation? how Do I point correctly in Game EX?? sorry I ask way to many questions but if I dont ask I will never know :)
Snap naming conventions should follow the same as the ROMs in order to be found. Make sure that the paths are setup for each in GameEx. Should be minimal issue.
SendKeys="%{ENTER}"
I don't use the " " in my config (listed above), and it works fine for me.
To get correct proper names in your list you need to use the Map file for Atomiswave. If you are using the config program, go into the config for the emulator and select the map file listed below:
If you do not have that map file, you can download it from Frequency's submissions and place it into the MAP FILES directory in your GameEx installation. The files are located in this post: http://www.gameex.info/forums/index.php?showtopic=3&st=20
Any way to rename the Roms to the full game name?
k now I am going to look even more new but how do I make that?
  On 3/1/2011 at 4:43 PM, Brian Hoffman said:
Use the map file Jombee suggested. :)
NM I need to read the whole reply lol. I have the map file I will edit if needed and test. Thanks again for your patience with me I kinda jump the jun lol.
K it is all working now thanks a 1 000 000 000 you all rock. and in case you are wondering yes I am @ work and testing this lol. Have a good one Guys and thanks again.
Sorry all I spoke to soon. For the Naomi part of Demul is that any way to switch from Standard control and Alternative? as some games use Digital control and some analog.
I got it all working but I cant add any games to my favorites. GameEX tells me it is added but not there. I can add any other EMU just not this one. could it be because of the map file?
I am having the same problem. I've posted about this in another thread, and uploaded the 3 files Tom requested. We just need to wait until he has time to look at this issue and get back to us.
do you have issues with Demul 0.5.6 and sound being choppy? what is the best config? do you have alternate sound plugins?
