Mark as solved! Another solved post be the OP. LOL. Good stuff! Glad you got it worked out. May be helpful to post how you solved it in case other users run into the same issue. ;)
I think he had run MAME with no sound set up in GameEx.
/end shot in dark
Don't know what it means, but perhaps you are right:
MAMEAudioMode=3
Apparently MAMEAudioMode=3 means don't play sound when AlphaUMi wants it. ;)
MAMEAudioMode=3
Actually it means "Pause GameEx Playlist audio and run MAME with no sound;3" neat little tool in the Config folder of GameEx called config.csv - had actually forgotten it is a trove of settings references without having to go into Advanced Configuration or Setup Wizard to look! B)
MAMEAudioMode=3
Yes, all of you are right. I missed to pay attention to that setting. Now I have MAMEAudioMode=1, which means "Pause Playlist audio and run MAME with sound". This is the best choice for me.
