Hi Tom!!!
I've installed the latets version of GameEx and i'm having problems with spanish accents visualization.
When i see a word with accent the letter with accent disapear.
On the other hand, i uploaded the latets Spanish language file to the pinned post of translations.
Thanks.
I'm a Portuguese user and also had some problems with accentuation.
The only option for me is to use Brazilian-Portuguese, but that too gives me error.
Used the French option, altered/translated the ini file and works great now.
A question for Tom, is it possible to have a Portuguese (Portugal) option? If so, I'm happy to translate the file and send it to you.
You may think its the same as Brazilian-Portuguese but its not. ;)
Tom, keep up the great work. I'm a registered user and a BIG fan.
