gStAv Posted January 1, 2011 Posted January 1, 2011 Hi!Using instantsheller for my visual pinball cab and it works like a charm!BUT, when I check the box for "Hide Starup, Login, Shutdown Screens and Set Auto Login"Sadly this also kills my activ desktop which I want to keep for displaying an animated GIF.Is there any way around this so I kan keep the activ desktop support?Best regards!
Draco1962 Posted January 7, 2011 Posted January 7, 2011 The problem I see is that InstantSheller is designed to replace Windows Explorer, of which, Active Desktop is an integrated component. I do not believe that you can have it it both ways in this case.
gStAv Posted January 7, 2011 Author Posted January 7, 2011 Thanks for the reply Draco1962! To bad as windows isn´t hidden good enough with explorer in there.Do you guys know any other app that could do what I want so I can skip the active desktop function?I need a re-sizeable window showing an animated gif, without any border and that it remembers the size and position when it´s opened.Any help appreciated!Regards!/Gustav
