[RESOLVED] Problem with toolbar and mouse
You may have inadvertently disabled the mouse (input settings), be using GameLauncher mode or the theme you are using may have the mouse disabled. There is also a plugin accessible via the plugin manager utility that may have inadvertably beeen turned on.
Unless he's having a similar problem to mine where my mouse disappears after returning from Attract Mode (although not after playing a MAME game)... Just food for thought. ;)
The toolbar doesn't appears and i can't see the cursor, help please.
Great software, thanks!
I just updated GameEx when I updated my Mame version and now have the same problem. I can not see the toolbar or the mouse cursor. I can scroll through the game lists, but if I move the cursor passed the list it is not visible. I can not bring it up to the right hand corner of the screen to close out GameEx, for example. Please help when able.
Thanks!
In the interim, you should be able to use the arrow keys to navigate to the exit menu.
  • 6 months later...
Thanks for you help. This was resolved with a GameEx upgrade. Works like a charm now. GameEx makes my arcade cabinet awesome.
Murb
