This is the best da@! frontend ever. I am new and I need a little help tweaking gamex for my needs. I have it working 99% percent the way I want just wanted to know if there is a way to turn off the part that shows start in the upper left hand corner. I know it's peddie but is it possible? I would actually not like anything to show in the upper left corner in the different menus.
Thanks for your help and please don't flame.
We wouldnt flame you. We're not like that here.
What you need to do is go into the config - Text/Language. Set the language to custom then change as required. To get nothing to show for a particular text item put " " (A space enclosed in quotes)
Thanks Tom. I appreciate it.
