Using 64 bit windows 7. When trying to run application a screen pops up for a few minutes trying to load GameEx. Then it proceeds to tell me that GameEx isn't working and I'm forced to close... I have used it on this system before and have recently updated and used it a couple of times since. Any ideas?! Thanx!
Please post log as per instructions by mod Tempest found here (Step 3).
Here it is. Thanx for taking a look!
21:01:27.3 10/20/2010: Is Media Center running?
21:01:27.3 10/20/2010: Checking/Creating LCD Registry values
21:01:27.4 10/20/2010: Check Media Center Exit/Start Mode
21:01:27.4 10/20/2010: Media Center Mode 2
21:01:27.4 10/20/2010: Video previews on. Warning: Only recommended on modern systems
21:01:27.4 10/20/2010: Snap Delay set to: 2
21:01:27.4 10/20/2010: Get other settings
21:01:27.4 10/20/2010: Desktop set to Hide ICONS and set Background to Black
21:01:27.4 10/20/2010: Set: Find emulator artwork on best match basis
21:01:27.4 10/20/2010: Start work for Form
21:01:27.4 10/20/2010: Getting Original Screen Size
21:01:27.4 10/20/2010: Compacting Database
21:01:29.0 10/20/2010: Opening Database Connection
21:01:30.0 10/20/2010: Initializing Component
21:01:30.2 10/20/2010: Retrieving resolution setting
21:01:30.2 10/20/2010: MAME Path is: C:\Emulators\Mame32
21:01:30.2 10/20/2010: Cannot Find MAME Path: MAME Disabled
21:01:30.2 10/20/2010: Loading Controls.ini map file
21:01:30.3 10/20/2010: Loading Custom Emulators
21:01:30.3 10/20/2010: Loading Emulator 1: Nintendo NES
21:01:30.4 10/20/2010: Loading Emulator 2: Nintendo SNES
21:01:30.5 10/20/2010: Loading Emulator 3: Sega Genesis
21:01:30.5 10/20/2010: Loading Emulator 4: Nintendo N64
21:01:30.5 10/20/2010: Loading Emulator 5: Nintendo Game Boy Advance
21:01:30.7 10/20/2010: Loading Emulator 6: Nintendo Game Boy Color
21:01:30.7 10/20/2010: Loading Emulator 7: Nintendo Game Boy
21:01:30.7 10/20/2010: Using Version 3 Themes Animations
21:01:30.7 10/20/2010: Using General Font: Trebuchet MS
21:01:30.7 10/20/2010: Using Title Font: Trebuchet MS
21:01:30.7 10/20/2010: Initialising Direct3D
21:01:30.8 10/20/2010: Applying GameEx is Loading Image
21:01:30.9 10/20/2010: Setting Resolution to 1776x1000 32 bit color
21:01:31.0 10/20/2010: Creating Surfaces
21:01:31.5 10/20/2010: Creating Primary Surface - Full Screen Mode
21:01:31.5 10/20/2010: Creating Back Buffer
21:01:31.5 10/20/2010: Loading graphic Surfaces
21:01:31.6 10/20/2010: Display is running at: 1776x1000 32bit color, 29hz
21:01:31.6 10/20/2010: Creating Surfaces Flags
21:01:31.8 10/20/2010: Creating Surfaces Misc and Dialogs
21:01:32.0 10/20/2010: Creating Surfaces Volume
21:01:32.0 10/20/2010: Creating Surfaces Arrows
21:01:32.2 10/20/2010: Creating Surfaces GameEXlogo Text
21:01:32.2 10/20/2010: Creating Surfaces Toolbar
21:01:32.3 10/20/2010: Creating Surfaces Backgrounds
21:01:32.3 10/20/2010: Creating Surfaces Toolbar Controls
21:01:32.4 10/20/2010: Creating Surfaces GameEx Logo
21:01:32.4 10/20/2010: Creating Surface Unselected
21:01:32.4 10/20/2010: Creating Surfaces Snaps
21:01:32.5 10/20/2010: Creating Surfaces Menu and List Bars
21:01:32.9 10/20/2010: Creating Fonts
21:01:32.9 10/20/2010: Creating Game Font
21:01:33.4 10/20/2010: Creating Game Font Faded
21:01:33.6 10/20/2010: Creating Title Font
21:01:33.6 10/20/2010: Restoring Title Font From Cache
21:01:34.1 10/20/2010: Creating Font Black
21:01:34.3 10/20/2010: Creating Font Black Small
21:01:34.4 10/20/2010: Fonts Created Succesfully
21:01:34.4 10/20/2010: Initialising Bass Audio Library
21:01:34.4 10/20/2010: Creating instance of global keyboard hook
21:01:34.9 10/20/2010: Applying Language/Text
21:01:35.0 10/20/2010: Text/Language: English
21:01:35.0 10/20/2010: MAME CMD options: -nowindow -joy -skip_gameinfo
21:01:35.0 10/20/2010: Loading last used Game List
21:01:35.1 10/20/2010: Loading music
That does not appear to be a complete log file. Can you attach the log file to a post?
It should look more like this:
19:00:26.0 10/20/2010: GameEx: Version 11.30: Starting Log
19:00:26.0 10/20/2010: Operating System Platform: Win32NT
19:00:26.0 10/20/2010: Operating System Name: Windows 7
19:00:26.0 10/20/2010: Operating System Version: 6.1.7600
19:00:26.0 10/20/2010: Aero running
19:00:26.0 10/20/2010: Initializing Vista/Windows 7 volume control
19:00:26.0 10/20/2010: Checking for versions of .net Framework installed
19:00:26.0 10/20/2010: .net Framework 2.0 Installed
19:00:26.0 10/20/2010: .net Framework 3.0 Installed
19:00:26.0 10/20/2010: .net Framework 3.5 Installed
19:00:26.0 10/20/2010: Intel® Core™2 Quad CPU Q6600 @ 2.40GHz, 8126MB
19:00:26.0 10/20/2010: 2.39Ghz - 4 Cores or CPU's
19:00:26.0 10/20/2010: Running Randomize()
19:00:26.0 10/20/2010: Loading PlugIns
19:00:26.0 10/20/2010: Checking for applications to Launch On Startup
19:00:26.0 10/20/2010: Running Misc startup tasks
19:00:26.0 10/20/2010: Setting Menu types
19:00:26.0 10/20/2010: Opening Configuration File
19:00:26.0 10/20/2010: Getting Configuration Values
19:00:26.0 10/20/2010: Using Theme: Carbon & Steel
19:00:26.0 10/20/2010: Checking for alternate Image Directory for Theme: Carbon & Steel
19:00:26.0 10/20/2010: Launching HideOS.exe
19:00:26.0 10/20/2010: Initialising Video/MNG DLL's
19:00:26.0 10/20/2010: GameEx will check for media insertion (may affect performance)
19:00:26.0 10/20/2010: Hiding Taskbar
19:00:26.0 10/20/2010: Is Media Center running?
19:00:26.0 10/20/2010: Checking/Creating LCD Registry values
19:00:26.1 10/20/2010: Check Media Center Exit/Start Mode
19:00:26.1 10/20/2010: Media Center Mode 2
19:00:26.1 10/20/2010: Video previews on. Warning: Only recommended on modern systems
19:00:26.1 10/20/2010: Warning: DirectDraw blitting set to NOT wait
19:00:26.1 10/20/2010: Snap Delay set to: 7
19:00:26.1 10/20/2010: Get other settings
19:00:26.1 10/20/2010: Desktop set to Hide ICONS and set Background to Black
19:00:26.1 10/20/2010: Set: Find emulator artwork on best match basis
19:00:26.1 10/20/2010: Start work for Form
19:00:26.1 10/20/2010: Getting Original Screen Size
19:00:26.1 10/20/2010: Opening Database Connection
19:00:26.2 10/20/2010: Initializing Component
19:00:26.2 10/20/2010: Retrieving resolution setting
19:00:26.3 10/20/2010: Initialising Windows Media Player Component
19:00:26.3 10/20/2010: MAME Path is: C:\Emulators\MameUI32
19:00:26.3 10/20/2010: Client/Server MAME Path is: C:\Emulators\ClientServerMAME
19:00:26.3 10/20/2010: Client/Server MAME EXE file is: vmame.exe
19:00:26.3 10/20/2010: Use Client/Server MAME On. vmame.exe will launch NetPlay games
19:00:26.3 10/20/2010: daphne Path is: C:\Emulators\Daphne
19:00:26.3 10/20/2010: daphne EXE file is: daphne.exe
19:00:26.3 10/20/2010: Use daphne on. daphne.exe will launch games
19:00:26.3 10/20/2010: MAME EXE file is: MameUI32.exe
19:00:26.3 10/20/2010: ROM Path is: C:\Emulators\MameUI32\roms
19:00:26.3 10/20/2010: Catver.ini is located at: C:\GameEx\DATA\catver.ini
19:00:26.3 10/20/2010: controls.ini is located at: C:\GameEx\data\controls.ini
19:00:26.3 10/20/2010: History.dat is located at: C:\GameEx\DATA\history.dat
19:00:26.3 10/20/2010: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
19:00:26.3 10/20/2010: command.dat is located at: C:\GameEx\DATA\command.dat
19:00:26.3 10/20/2010: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
19:00:26.3 10/20/2010: Loading Controls.ini map file
19:00:26.3 10/20/2010: Snap Path is: C:\Emulators\MameUI32\snap
19:00:26.3 10/20/2010: AVI Snap Path is: C:\Emulators\MameUI32\avisnap
19:00:26.3 10/20/2010: Flyer Path is: C:\Emulators\MameUI32\flyers
19:00:26.3 10/20/2010: Cabinet Path is: C:\Emulators\MameUI32\cabinets
19:00:26.3 10/20/2010: Cabinet 3D Path is: C:\GameEx\MEDIA\X Files
19:00:26.3 10/20/2010: Title Path is: C:\Emulators\MameUI32\titles
19:00:26.3 10/20/2010: PCB Path is: C:\Emulators\MameUI32\pcb
19:00:26.3 10/20/2010: Artwork Preview Path is: C:\Emulators\MameUI32\Artworkpreview
19:00:26.3 10/20/2010: Panel Path is: C:\Emulators\MameUI32\cpanel
19:00:26.3 10/20/2010: Manual Path is: C:\Emulators\MameUI32\Manual
19:00:26.3 10/20/2010: Icon Path is: C:\Emulators\MameUI32\icons
19:00:26.3 10/20/2010: Marquee Path is: C:\Emulators\MameUI32\marquees
19:00:26.4 10/20/2010: Loading Custom Emulators
19:00:26.4 10/20/2010: Loading Emulator 1: MAME
19:00:26.4 10/20/2010: Loading Emulator 2: WinKawaks
19:00:26.4 10/20/2010: Loading Emulator 3: Future Pinball
19:00:26.4 10/20/2010: Loading Emulator 4: Visual Pinball
19:00:26.4 10/20/2010: Loading Emulator 5: Visual PinMAME
19:00:26.4 10/20/2010: Loading Emulator 6: [Console] Atari 2600 (MESS)
19:00:26.4 10/20/2010: Loading Emulator 7: [Console] Atari 5200 (MESS)
19:00:26.4 10/20/2010: Loading Emulator 8: [Console] Atari 7800 (MESS)
19:00:26.4 10/20/2010: Loading Emulator 9: [Console] Nintendo NES (MESS)
19:00:26.4 10/20/2010: Loading Emulator 10: [Console] Nintendo SNES (MESS)
19:00:26.4 10/20/2010: Loading Emulator 11: [Console] Nintendo N64 (Project64)
19:00:26.4 10/20/2010: Loading Emulator 12: [Console] Nintendo GameCube (Dolphin)
19:00:26.4 10/20/2010: Using Version 3 Themes Animations
19:00:26.4 10/20/2010: Using General Font: SF Atarian System
19:00:26.4 10/20/2010: Using Title Font: Trebuchet MS
19:00:26.5 10/20/2010: Initialising Direct3D
19:00:26.5 10/20/2010: Applying GameEx is Loading Image
19:00:26.6 10/20/2010: Setting Resolution to 1680x1050 32 bit color
19:00:26.6 10/20/2010: Creating Surfaces
19:00:26.9 10/20/2010: Creating Primary Surface - Full Screen Mode
19:00:26.9 10/20/2010: Creating Back Buffer
19:00:26.9 10/20/2010: Version 2 Theme being used. Loading.
19:00:26.9 10/20/2010: Loading Button Data
19:00:26.9 10/20/2010: Loading Font Data
19:00:26.9 10/20/2010: Loading Layout Data
19:00:26.9 10/20/2010: Loading Taskbar Data
19:00:26.9 10/20/2010: Loading graphic Surfaces
19:00:26.9 10/20/2010: Display is running at: 1680x1050 32bit color, 60hz
19:00:26.9 10/20/2010: Creating Surfaces Flags
19:00:27.0 10/20/2010: Creating Surfaces Misc and Dialogs
19:00:27.1 10/20/2010: Creating Surfaces Volume
19:00:27.1 10/20/2010: Creating Surfaces Arrows
19:00:27.1 10/20/2010: Creating Surfaces GameEXlogo Text
19:00:27.1 10/20/2010: Creating Surfaces Toolbar
19:00:27.1 10/20/2010: Creating Surfaces Backgrounds
19:00:27.1 10/20/2010: Creating Surfaces Toolbar Controls
19:00:27.1 10/20/2010: Creating Surfaces GameEx Logo
19:00:27.1 10/20/2010: Creating Surface Unselected
19:00:27.1 10/20/2010: Creating Surfaces Snaps
19:00:27.1 10/20/2010: Creating Surfaces Menu and List Bars
19:00:27.2 10/20/2010: Creating Fonts
19:00:27.2 10/20/2010: Creating Game Font
19:00:27.6 10/20/2010: Creating Game Font Faded
19:00:28.2 10/20/2010: Creating Title Font
19:00:28.2 10/20/2010: Restoring Title Font From Cache
19:00:28.4 10/20/2010: Creating Font Black
19:00:28.5 10/20/2010: Creating Font Black Small
19:00:28.5 10/20/2010: Fonts Created Succesfully
19:00:28.5 10/20/2010: Initialising Bass Audio Library
19:00:28.5 10/20/2010: Creating instance of global keyboard hook
19:00:28.8 10/20/2010: Attempting to load game list
19:00:29.0 10/20/2010: Applying Language/Text
19:00:29.0 10/20/2010: Text/Language: English
19:00:29.0 10/20/2010: MAME CMD options: -nowindow -joy -skip_gameinfo
19:00:29.0 10/20/2010: Loading last used Game List
19:00:29.3 10/20/2010: Loading Start Page
19:00:29.4 10/20/2010: Creating DirectSound Device
19:00:29.4 10/20/2010: Trying: Primary Sound Driver
19:00:29.4 10/20/2010: Loading Sound Files
19:00:29.4 10/20/2010: DirectSound Device Created Successfully
19:00:29.4 10/20/2010: Creating ICONS
19:00:29.4 10/20/2010: Recreating ICONS
19:00:29.8 10/20/2010: Initialising DirectInput for Gamepad support
19:00:30.1 10/20/2010: Using Device Logitech Dual Action
19:00:30.3 10/20/2010: Initializing MCE Remote
19:00:30.3 10/20/2010: Initialization OK! Starting GameEx!
19:00:30.3 10/20/2010: Testing Main Loop Once: Processing Frame
19:00:30.6 10/20/2010: Testing Main Loop Once: Main Loop ran successfully
19:19:46.4 10/20/2010: Validating: Emulator_1: Custom Background: C:\Emulators\MameUI32\snap
19:19:46.4 10/20/2010: Validating: Emulator_1: Snap Path: C:\Emulators\MameUI32\snap
19:19:46.4 10/20/2010: Validating: Emulator_1: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_1: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_1: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_1: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: Control Panel Path: C:\Emulators\MameUI32\cpanel
19:19:46.4 10/20/2010: Validating: Emulator_1: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_1: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: Database: [Arcade] MAME
19:19:46.4 10/20/2010: Validating: Emulator_1: Title Snap Path: C:\Emulators\MameUI32\titles
19:19:46.4 10/20/2010: Validating: Emulator_1: Box Art Path: C:\Emulators\MameUI32\Boxes
19:19:46.4 10/20/2010: Validating: Emulator_1: Cart Art Path: C:\Emulators\MameUI32\Cartridges
19:19:46.4 10/20/2010: Validating: Emulator_1: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_1: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_1: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_1: Manual Path: C:\Emulators\MameUI32\Manual
19:19:46.4 10/20/2010: Warning: Emulator_1: MAPFile Does Not Exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Custom Background: C:\Emulators\WinKawaks\capture
19:19:46.4 10/20/2010: Validating: Emulator_2: Snap Path: C:\Emulators\WinKawaks\capture
19:19:46.4 10/20/2010: Validating: Emulator_2: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_2: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_2: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_2: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Control Panel Path: C:\Emulators\WinKawaks\Controls
19:19:46.4 10/20/2010: Validating: Emulator_2: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_2: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Database:
19:19:46.4 10/20/2010: Warning: Emulator_2: Database Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Title Snap Path: C:\Emulators\WinKawaks\sshots
19:19:46.4 10/20/2010: Validating: Emulator_2: Box Art Path: C:\Emulators\WinKawaks\Boxes
19:19:46.4 10/20/2010: Validating: Emulator_2: Cart Art Path: C:\Emulators\WinKawaks\Cartridges
19:19:46.4 10/20/2010: Validating: Emulator_2: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_2: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_2: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_2: Manual Path: C:\Emulators\WinKawaks\Manuals
19:19:46.4 10/20/2010: Validating: Emulator_3: Custom Background: C:\Assets\Future Pinball\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_3: Snap Path: C:\Assets\Future Pinball\Snaps
19:19:46.4 10/20/2010: Warning: Emulator_3: Snap Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_3: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_3: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_3: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Control Panel Path: C:\Assets\Future Pinball\Controls
19:19:46.4 10/20/2010: Warning: Emulator_3: Control Panel Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_3: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Database: [Pinball] Future Pinball
19:19:46.4 10/20/2010: Validating: Emulator_3: Title Snap Path: C:\Assets\Future Pinball\Titles
19:19:46.4 10/20/2010: Warning: Emulator_3: Title Snap Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Box Art Path: C:\Assets\Future Pinball\Boxes
19:19:46.4 10/20/2010: Warning: Emulator_3: Box Art Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Cart Art Path: C:\Assets\Future Pinball\Cartridges
19:19:46.4 10/20/2010: Warning: Emulator_3: Cart Art Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_3: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_3: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_3: Manual Path: C:\Assets\Future Pinball\Manuals
19:19:46.4 10/20/2010: Warning: Emulator_3: Manual Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Custom Background: C:\Assets\Atari 2600\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_6: Snap Path: C:\Assets\Atari 2600\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_6: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_6: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_6: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_6: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Control Panel Path: C:\Assets\Atari 2600\Controls
19:19:46.4 10/20/2010: Validating: Emulator_6: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_6: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Database: [Console] Atari 2600
19:19:46.4 10/20/2010: Validating: Emulator_6: Title Snap Path: C:\Assets\Atari 2600\Titles
19:19:46.4 10/20/2010: Validating: Emulator_6: Box Art Path: C:\Assets\Atari 2600\Boxes
19:19:46.4 10/20/2010: Validating: Emulator_6: Cart Art Path: C:\Assets\Atari 2600\Cartridges
19:19:46.4 10/20/2010: Validating: Emulator_6: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_6: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_6: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_6: Manual Path: C:\Assets\Atari 2600\Manuals
19:19:46.4 10/20/2010: Validating: Emulator_7: Custom Background: C:\Assets\Atari 5200\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_7: Snap Path: C:\Assets\Atari 5200\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_7: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_7: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_7: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_7: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: Control Panel Path: C:\Assets\Atari 5200\Controls
19:19:46.4 10/20/2010: Validating: Emulator_7: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_7: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: Database: [Console] Atari 5200
19:19:46.4 10/20/2010: Validating: Emulator_7: Title Snap Path: C:\Assets\Atari 5200\Titles
19:19:46.4 10/20/2010: Validating: Emulator_7: Box Art Path: C:\Assets\Atari 5200\Boxes
19:19:46.4 10/20/2010: Validating: Emulator_7: Cart Art Path: C:\Assets\Atari 5200\Cartridges
19:19:46.4 10/20/2010: Validating: Emulator_7: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_7: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_7: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_7: Manual Path: C:\Assets\Atari 5200\Manuals
19:19:46.4 10/20/2010: Validating: Emulator_8: Custom Background: C:\Assets\Atari 7800\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_8: Snap Path: C:\Assets\Atari 7800\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_8: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_8: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_8: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_8: Custom Art Path 3 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: Control Panel Path: C:\Assets\Atari 7800\Controls
19:19:46.4 10/20/2010: Validating: Emulator_8: Instructions Path:
19:19:46.4 10/20/2010: Warning: Emulator_8: Instructions Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: Database: [Console] Atari 7800
19:19:46.4 10/20/2010: Validating: Emulator_8: Title Snap Path: C:\Assets\Atari 7800\Titles
19:19:46.4 10/20/2010: Validating: Emulator_8: Box Art Path: C:\Assets\Atari 7800\Boxes
19:19:46.4 10/20/2010: Validating: Emulator_8: Cart Art Path: C:\Assets\Atari 7800\Cartridges
19:19:46.4 10/20/2010: Validating: Emulator_8: Music Path:
19:19:46.4 10/20/2010: Warning: Emulator_8: Music Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: TV Ad Path:
19:19:46.4 10/20/2010: Warning: Emulator_8: TV Ad Path Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_8: Manual Path: C:\Assets\Atari 7800\Manuals
19:19:46.4 10/20/2010: Validating: Emulator_9: Custom Background: C:\Assets\Nintendo NES\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_9: Snap Path: C:\Assets\Nintendo NES\Snaps
19:19:46.4 10/20/2010: Validating: Emulator_9: Custom Art Path 1:
19:19:46.4 10/20/2010: Warning: Emulator_9: Custom Art Path 1 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_9: Custom Art Path 2:
19:19:46.4 10/20/2010: Warning: Emulator_9: Custom Art Path 2 Does not exist
19:19:46.4 10/20/2010: Validating: Emulator_9: Custom Art Path 3:
19:19:46.4 10/20/2010: Warning: Emulator_9: Custom Art Path 3 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_9: Control Panel Path: C:\Assets\Nintendo NES\Controls
19:19:46.5 10/20/2010: Validating: Emulator_9: Instructions Path:
19:19:46.5 10/20/2010: Warning: Emulator_9: Instructions Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_9: Database: [Console] Nintendo NES
19:19:46.5 10/20/2010: Validating: Emulator_9: Title Snap Path: C:\Assets\Nintendo NES\Titles
19:19:46.5 10/20/2010: Validating: Emulator_9: Box Art Path: C:\Assets\Nintendo NES\Boxes
19:19:46.5 10/20/2010: Validating: Emulator_9: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
19:19:46.5 10/20/2010: Validating: Emulator_9: Music Path:
19:19:46.5 10/20/2010: Warning: Emulator_9: Music Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_9: TV Ad Path:
19:19:46.5 10/20/2010: Warning: Emulator_9: TV Ad Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_9: Manual Path: C:\Assets\Nintendo NES\Manuals
19:19:46.5 10/20/2010: Validating: Emulator_10: Custom Background: C:\Assets\Nintendo SNES\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_10: Snap Path: C:\Assets\Nintendo SNES\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_10: Custom Art Path 1:
19:19:46.5 10/20/2010: Warning: Emulator_10: Custom Art Path 1 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: Custom Art Path 2:
19:19:46.5 10/20/2010: Warning: Emulator_10: Custom Art Path 2 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: Custom Art Path 3:
19:19:46.5 10/20/2010: Warning: Emulator_10: Custom Art Path 3 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: Control Panel Path: C:\Assets\Nintendo SNES\Controls
19:19:46.5 10/20/2010: Validating: Emulator_10: Instructions Path:
19:19:46.5 10/20/2010: Warning: Emulator_10: Instructions Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: Database: [Console] Nintendo SNES
19:19:46.5 10/20/2010: Validating: Emulator_10: Title Snap Path: C:\Assets\Nintendo SNES\Titles
19:19:46.5 10/20/2010: Validating: Emulator_10: Box Art Path: C:\Assets\Nintendo SNES\Boxes
19:19:46.5 10/20/2010: Validating: Emulator_10: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
19:19:46.5 10/20/2010: Validating: Emulator_10: Music Path:
19:19:46.5 10/20/2010: Warning: Emulator_10: Music Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: TV Ad Path:
19:19:46.5 10/20/2010: Warning: Emulator_10: TV Ad Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_10: Manual Path: C:\Assets\Nintendo SNES\Manuals
19:19:46.5 10/20/2010: Validating: Emulator_11: Custom Background: C:\Assets\Nintendo N64\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_11: Snap Path: C:\Assets\Nintendo N64\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_11: Custom Art Path 1:
19:19:46.5 10/20/2010: Warning: Emulator_11: Custom Art Path 1 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: Custom Art Path 2:
19:19:46.5 10/20/2010: Warning: Emulator_11: Custom Art Path 2 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: Custom Art Path 3:
19:19:46.5 10/20/2010: Warning: Emulator_11: Custom Art Path 3 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: Control Panel Path: C:\Assets\Nintendo N64\Controls
19:19:46.5 10/20/2010: Validating: Emulator_11: Instructions Path:
19:19:46.5 10/20/2010: Warning: Emulator_11: Instructions Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: Database: [Console] Nintendo N64
19:19:46.5 10/20/2010: Validating: Emulator_11: Title Snap Path: C:\Assets\Nintendo N64\Titles
19:19:46.5 10/20/2010: Validating: Emulator_11: Box Art Path: C:\Assets\Nintendo N64\Boxes
19:19:46.5 10/20/2010: Validating: Emulator_11: Cart Art Path: C:\Assets\Nintendo N64\Cartridges
19:19:46.5 10/20/2010: Validating: Emulator_11: Music Path:
19:19:46.5 10/20/2010: Warning: Emulator_11: Music Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: TV Ad Path:
19:19:46.5 10/20/2010: Warning: Emulator_11: TV Ad Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_11: Manual Path: C:\Assets\Nintendo N64\Manuals
19:19:46.5 10/20/2010: Validating: Emulator_12: Custom Background: C:\Assets\Nintendo GameCube\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_12: Snap Path: C:\Assets\Nintendo GameCube\Snaps
19:19:46.5 10/20/2010: Validating: Emulator_12: Custom Art Path 1:
19:19:46.5 10/20/2010: Warning: Emulator_12: Custom Art Path 1 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: Custom Art Path 2:
19:19:46.5 10/20/2010: Warning: Emulator_12: Custom Art Path 2 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: Custom Art Path 3:
19:19:46.5 10/20/2010: Warning: Emulator_12: Custom Art Path 3 Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: Control Panel Path: C:\Assets\Nintendo GameCube\Controls
19:19:46.5 10/20/2010: Validating: Emulator_12: Instructions Path:
19:19:46.5 10/20/2010: Warning: Emulator_12: Instructions Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: Database: [Console] Nintendo GameCube
19:19:46.5 10/20/2010: Validating: Emulator_12: Title Snap Path: C:\Assets\Nintendo GameCube\Titles
19:19:46.5 10/20/2010: Validating: Emulator_12: Box Art Path: C:\Assets\Nintendo GameCube\Boxes
19:19:46.5 10/20/2010: Validating: Emulator_12: Cart Art Path: C:\Assets\Nintendo GameCube\Cartridges
19:19:46.5 10/20/2010: Validating: Emulator_12: Music Path:
19:19:46.5 10/20/2010: Warning: Emulator_12: Music Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: TV Ad Path:
19:19:46.5 10/20/2010: Warning: Emulator_12: TV Ad Path Does not exist
19:19:46.5 10/20/2010: Validating: Emulator_12: Manual Path: C:\Assets\Nintendo GameCube\Manuals
19:19:46.6 10/20/2010: Restoring Emulator from Cache
19:19:46.8 10/20/2010: Restoring Emulator Database From Cache
