When I try to start GameEx in full screen mode, it comes up with an error. It is fine when it is set to start in a window. I have tried it with GameEx not changing the resolution and with manually specifying the resolution in GameEx. It doesn't work either way. My display drivers are up-to-date.
Thanks,
Dan
18:33:34.2 7/8/2010: GameEx: Version 11.08: Starting Log
18:33:34.2 7/8/2010: Operating System Platform: Win32NT
18:33:34.2 7/8/2010: Operating System Name: Windows 7
18:33:34.2 7/8/2010: Operating System Version: 6.1.7600
18:33:34.2 7/8/2010: Aero running
18:33:34.2 7/8/2010: Initializing Vista/Windows 7 volume control
18:33:34.2 7/8/2010: Checking for versions of .net Framework installed
18:33:34.2 7/8/2010: .net Framework 2.0 Installed
18:33:34.2 7/8/2010: .net Framework 3.0 Installed
18:33:34.2 7/8/2010: .net Framework 3.5 Installed
18:33:34.2 7/8/2010: AMD Phenom 8650 Triple-Core Processor, 3967MB
18:33:34.2 7/8/2010: 2.3Ghz - 3 Cores or CPU's
18:33:34.2 7/8/2010: Running Randomize()
18:33:34.3 7/8/2010: Loading PlugIns
18:33:34.3 7/8/2010: Checking for applications to Launch On Startup
18:33:34.3 7/8/2010: Running Misc startup tasks
18:33:34.3 7/8/2010: Setting Menu types
18:33:34.3 7/8/2010: Opening Configuration File
18:33:34.3 7/8/2010: Getting Configuration Values
18:33:34.3 7/8/2010: Using Theme: Default - RedEx - MCE1024x768
18:33:34.3 7/8/2010: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
18:33:34.3 7/8/2010: Launching HideOS.exe
18:33:34.3 7/8/2010: Initialising Video/MNG DLL's
18:33:34.3 7/8/2010: GameEx will check for media insertion (may affect performance)
18:33:34.3 7/8/2010: Hiding Taskbar
18:33:34.3 7/8/2010: Is Media Center running?
18:33:34.3 7/8/2010: Checking/Creating LCD Registry values
18:33:34.3 7/8/2010: Check Media Center Exit/Start Mode
18:33:34.3 7/8/2010: Media Center Mode 2
18:33:34.3 7/8/2010: Video previews on. Warning: Only recommended on modern systems
18:33:34.3 7/8/2010: Snap Delay set to: 2
18:33:34.3 7/8/2010: Get other settings
18:33:34.3 7/8/2010: Set: Find emulator artwork on best match basis
18:33:34.3 7/8/2010: Using DirectInput for keyboard input
18:33:34.3 7/8/2010: Start work for Form
18:33:34.3 7/8/2010: Getting Original Screen Size
18:33:34.3 7/8/2010: Compacting Database
18:33:34.5 7/8/2010: Opening Database Connection
18:33:34.5 7/8/2010: Initializing Component
18:33:34.5 7/8/2010: Retrieving resolution setting
18:33:34.5 7/8/2010: MAME Path is: C:\Emulators\Mame32
18:33:34.5 7/8/2010: MAME EXE file is: Mame32.exe
18:33:34.5 7/8/2010: ROM Path is: C:\Emulators\roms\MAME
18:33:34.5 7/8/2010: Catver.ini is located at: C:\Program Files (x86)\GameEx\DATA\catver.ini
18:33:34.5 7/8/2010: controls.ini is located at: C:\Program Files (x86)\GameEx\data\controls.ini
18:33:34.5 7/8/2010: History.dat is located at: C:\Program Files (x86)\GameEx\DATA\history.dat
18:33:34.5 7/8/2010: nplayers.ini is located at: C:\Program Files (x86)\GameEx\DATA\nplayers.ini
18:33:34.5 7/8/2010: command.dat is located at: C:\Program Files (x86)\GameEx\DATA\command.dat
18:33:34.5 7/8/2010: MAMEinfo.dat is located at: C:\Program Files (x86)\GameEx\DATA\mameinfo.dat
18:33:34.5 7/8/2010: Loading Controls.ini map file
18:33:34.5 7/8/2010: Snap Path is: C:\Emulators\snaps\MAME
18:33:34.5 7/8/2010: AVI Snap Path is: C:\Emulators\vsnaps\MAME
18:33:34.5 7/8/2010: Flyer Path is: C:\Emulators\flyers\MAME
18:33:34.5 7/8/2010: Cabinet Path is: C:\Emulators\cabinets\MAME
18:33:34.5 7/8/2010: Title Path is: C:\Emulators\titles\MAME
18:33:34.5 7/8/2010: PCB Path is: C:\Emulators\pcbs\MAME
18:33:34.5 7/8/2010: Artwork Preview Path: Not Found
18:33:34.5 7/8/2010: Panel Path is: C:\Emulators\cpanels\MAME
18:33:34.5 7/8/2010: Manual Path: Not Found
18:33:34.5 7/8/2010: Icon Path is: C:\Emulators\icons\MAME
18:33:34.5 7/8/2010: Marquee Path is: C:\Emulators\marquees\MAME
18:33:34.6 7/8/2010: Loading Custom Emulators
18:33:34.6 7/8/2010: Loading Emulator 1: Nintendo NES
18:33:34.6 7/8/2010: Loading Emulator 2: Nintendo SNES
18:33:34.6 7/8/2010: Loading Emulator 3: Nintendo 64
18:33:34.6 7/8/2010: Loading Emulator 4: Nintendo GameBoy
18:33:34.6 7/8/2010: Loading Emulator 5: Nintendo GameBoy Advance
18:33:34.6 7/8/2010: Loading Emulator 6: Nintendo GameBoy Color
18:33:34.6 7/8/2010: Loading Emulator 8: Sega Master System
18:33:34.6 7/8/2010: Loading Emulator 9: Sega Genesis
18:33:34.6 7/8/2010: Loading Emulator 10: Sega GameGear
18:33:34.6 7/8/2010: Loading Emulator 11: Atari 2600
18:33:34.6 7/8/2010: Using 3D Alpha Blended Animations.
18:33:34.6 7/8/2010: Using General Font: Trebuchet MS
18:33:34.6 7/8/2010: Using Title Font: Trebuchet MS
18:33:34.7 7/8/2010: Initialising Direct3D
18:33:34.7 7/8/2010: Applying GameEx is Loading Image
18:33:34.7 7/8/2010: Setting Resolution to 1175x648 32 bit color
18:33:34.7 7/8/2010: Creating Surfaces
18:33:35.9 7/8/2010: --**--
18:33:35.9 7/8/2010: Error: Error in the application.
18:33:35.9 7/8/2010: at Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
18:33:35.9 7/8/2010: at n.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
18:33:35.9 7/8/2010: at n..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
18:33:35.9 7/8/2010: at af.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4, Int32 A_5)
18:33:35.9 7/8/2010: at af.a(Boolean A_0, String A_1, Boolean A_2)
18:33:35.9 7/8/2010: at af..ctor()
18:33:35.9 7/8/2010: Closing database connection
18:33:36.0 7/8/2010: Disposing Plugins
18:33:36.0 7/8/2010: GameEx is exiting with errors
18:33:36.0 7/8/2010: Deleting search cache
18:33:38.1 7/8/2010: ERRORS DETECTED: EXITING
