Hello,
i am using the gameex plugin launcher, namely to start joytokey or xpadder to make my USB connected Ultrastik joysticks usable within other emulators and games which don't directly support joysticks.
However, i can't get Zinc and Model2 to work with pluginlaunch. Both are configured within the advanced mame settings of gameex, so, i can't find which 'title' these two emulators use, for configuring within pluginaunch. Even if it's possible to get them to work with pluginlaunch altogehter. This is annoying, because i don't know how to change the control settings for both emulators, let alone change them to directly use joystcicks by default (and not having to change this for every game).
Is there a way to get this to work?
Regards,
Mart
I have not looked at pluginlaunch in great detail but I would expect zinc and model 2 to come across as "MAME" games but with there own and correct command line. So not sure if there compatible with the plugin.
If you used the MAME Emu mapping instead of the in built ZINC and model 2 support you could potentially set them up as emulators, then they should come over to the plugin as different emulators.
