Hi all,
I Have two systems running GameEX. My cabinet runs my games and emulators and my laptop runs movies thru my television. After the last update, my cabinet is fine. My laptop on the otherhand has no sound I added a emulator to my l;aptop[ and it has sound. The movies, mp3 etc. play fine thru media player,but no sound when ran thru GameEx. I'm running Vista. Here is my log. Its ays at thne end that media center is not open.
11:41:19.2 5/2/2010: GameEx: Version 10.70: Starting Log
11:41:19.2 5/2/2010: Operating System Platform: Win32NT
11:41:19.2 5/2/2010: Operating System Name: Windows Vista
11:41:19.2 5/2/2010: Operating System Version: 6.0.6002
11:41:19.2 5/2/2010: Aero running
11:41:19.2 5/2/2010: Initializing Vista/Windows 7 volume control
11:41:19.2 5/2/2010: Checking for versions of .net Framework installed
11:41:19.2 5/2/2010: .net Framework 2.0 Installed
11:41:19.2 5/2/2010: .net Framework 3.0 Installed
11:41:19.2 5/2/2010: .net Framework 3.5 Installed
11:41:19.2 5/2/2010: AMD Athlon Dual-Core QL-62, 2814MB
11:41:19.2 5/2/2010: 2Ghz - 2 Cores or CPU's
11:41:19.2 5/2/2010: Running Randomize()
11:41:19.2 5/2/2010: Loading PlugIns
11:41:19.2 5/2/2010: Checking for applications to Launch On Startup
11:41:19.2 5/2/2010: Running Misc startup tasks
11:41:19.2 5/2/2010: Setting Menu types
11:41:19.2 5/2/2010: Opening Configuration File
11:41:19.2 5/2/2010: Getting Configuration Values
11:41:19.3 5/2/2010: Using Theme: Default - Media Center
11:41:19.3 5/2/2010: Checking for alternate Image Directory for Theme: Default - Media Center
11:41:19.3 5/2/2010: Using Images from theme: Default - Media Center V1\MEDIA\
11:41:19.3 5/2/2010: Launching HideOS.exe
11:41:19.3 5/2/2010: Initialising Video/MNG DLL's
11:41:19.3 5/2/2010: GameEx will check for media insertion (may affect performance)
11:41:19.3 5/2/2010: Hiding Taskbar
11:41:19.3 5/2/2010: Is Media Center running?
11:41:19.3 5/2/2010: Checking/Creating LCD Registry values
11:41:19.3 5/2/2010: Check Media Center Exit/Start Mode
11:41:19.3 5/2/2010: Media Center Mode 2
11:41:19.4 5/2/2010: Video previews on. Warning: Only recommended on modern systems
11:41:19.4 5/2/2010: Snap Delay set to: 3
11:41:19.4 5/2/2010: Get other settings
11:41:19.4 5/2/2010: Desktop set to Hide ICONS and set Background to Black
11:41:19.4 5/2/2010: Set: Find emulator artwork on best match basis
11:41:19.4 5/2/2010: Start work for Form
11:41:19.4 5/2/2010: Getting Original Screen Size
11:41:19.4 5/2/2010: Opening Database Connection
11:41:19.5 5/2/2010: Initializing Component
11:41:19.7 5/2/2010: Retrieving resolution setting
11:41:19.7 5/2/2010: Initialising Windows Media Player Component
11:41:19.7 5/2/2010: MAME Path is: C:\Emulators\Mame32
11:41:19.7 5/2/2010: Model 2 Path Path is: C:\Emulators\Model2
11:41:19.7 5/2/2010: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
11:41:19.7 5/2/2010: Model 2 EXE file is: emulator_multicpu.exe
11:41:19.7 5/2/2010: Model 2 emulator with command line support detected
11:41:19.7 5/2/2010: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
11:41:19.7 5/2/2010: ZiNc Path is: C:\Emulators\ZiNc
11:41:19.7 5/2/2010: ZiNc EXE file is: zinc.exe
11:41:19.7 5/2/2010: Use ZiNc on. zinc.exe will launch PSX games
11:41:19.7 5/2/2010: MAME EXE file is: Mame32.exe
11:41:19.7 5/2/2010: ROM Path is: C:\Emulators\Mame32\roms
11:41:19.7 5/2/2010: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
11:41:19.7 5/2/2010: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
11:41:19.7 5/2/2010: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
11:41:19.7 5/2/2010: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
11:41:19.7 5/2/2010: command.dat is located at: C:\Program Files\GameEx\DATA\command.dat
11:41:19.7 5/2/2010: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
11:41:19.7 5/2/2010: Loading Controls.ini map file
11:41:19.8 5/2/2010: Snap Path is: C:\Emulators\Mame32\snap
11:41:19.8 5/2/2010: AVI Snap Path is: C:\Emulators\Mame32\avisnap
11:41:19.8 5/2/2010: Flyer Path is: C:\Emulators\Mame32\flyers
11:41:19.8 5/2/2010: Cabinet Path is: C:\Emulators\Mame32\cabinets
11:41:19.8 5/2/2010: Title Path is: C:\Emulators\Mame32\titles
11:41:19.8 5/2/2010: PCB Path: Not Found
11:41:19.8 5/2/2010: Artwork Preview Path: Not Found
11:41:19.8 5/2/2010: Panel Path is: C:\Emulators\Mame32\cpanel
11:41:19.8 5/2/2010: Manual Path: Not Found
11:41:19.8 5/2/2010: Icon Path is: C:\Emulators\Mame32\icons
11:41:19.8 5/2/2010: Marquee Path is: C:\Emulators\Mame32\marquees
11:41:19.8 5/2/2010: Loading Custom Emulators
11:41:19.8 5/2/2010: Loading Emulator 5: Atari 2600 Games
11:41:19.9 5/2/2010: Loading Emulator 6: PC Apps
11:41:20.0 5/2/2010: Using 3D Alpha Blended Animations. This could be slow
11:41:20.0 5/2/2010: Using General Font: Trebuchet MS
11:41:20.0 5/2/2010: Using Title Font: Trebuchet MS
11:41:20.0 5/2/2010: Initialising DirectDraw
11:41:20.0 5/2/2010: Applying GameEx is Loading Image
11:41:20.0 5/2/2010: Creating DirectDraw Device
11:41:20.0 5/2/2010: Using Device: NVIDIA GeForce 8200M G
11:41:21.6 5/2/2010: Setting Resolution to 1366x768 32 bit color
11:41:21.6 5/2/2010: Creating DirectDraw Surfaces
11:41:21.6 5/2/2010: Creating Primary Surface - Full Screen Mode
11:41:21.9 5/2/2010: Creating Back Buffer
11:41:21.9 5/2/2010: Loading graphic Surfaces
11:41:22.3 5/2/2010: Display is running at: 1366x768 32bit color, 60hz
11:41:22.5 5/2/2010: Creating Surfaces Flags
11:41:22.6 5/2/2010: Creating Surfaces Misc and Dialogs
11:41:22.7 5/2/2010: Creating Surfaces Volume
11:41:22.7 5/2/2010: Creating Surfaces Arrows
11:41:22.9 5/2/2010: Creating Surfaces GameEXlogo Text
11:41:22.9 5/2/2010: Creating Surfaces Toolbar
11:41:23.0 5/2/2010: Creating Surfaces Backgrounds
11:41:23.1 5/2/2010: Creating Surfaces Toolbar Controls
11:41:23.1 5/2/2010: Creating Surfaces GameEx Logo
11:41:23.1 5/2/2010: Creating Surface Unselected
11:41:23.2 5/2/2010: Creating Surfaces Snaps
11:41:23.2 5/2/2010: Creating Surfaces Menu and List Bars
11:41:23.6 5/2/2010: Creating Fonts
11:41:23.6 5/2/2010: Creating Game Font
11:41:23.8 5/2/2010: Creating Game Font Faded
11:41:23.8 5/2/2010: Creating Title Font
11:41:23.9 5/2/2010: Restoring Title Font From Cache
11:41:24.0 5/2/2010: Creating Font Black
11:41:24.2 5/2/2010: Creating Font Black Small
11:41:24.4 5/2/2010: Fonts Created Succesfully
11:41:25.1 5/2/2010: 56MB Video Memory Used
11:41:25.1 5/2/2010: Creating instance of global keyboard hook
11:41:25.1 5/2/2010: Initialising Bass Audio Library
11:41:25.1 5/2/2010: Attempting to load game list
11:41:25.3 5/2/2010: Applying Language/Text
11:41:25.3 5/2/2010: Text/Language: English
11:41:25.4 5/2/2010: MAME CMD options: -nowindow -joy -skip_gameinfo
11:41:25.4 5/2/2010: Loading last used Game List
11:41:25.4 5/2/2010: Creating DirectSound Device
11:41:25.4 5/2/2010: Trying: Primary Sound Driver
11:41:25.5 5/2/2010: Loading Sound Files
11:41:25.6 5/2/2010: DirectSound Device Created Successfully
11:41:25.6 5/2/2010: Creating ICONS
11:41:25.6 5/2/2010: Recreating ICONS
11:41:26.0 5/2/2010: Initialising DirectInput for Gamepad support
11:41:26.1 5/2/2010: Unable to create a joystick device
11:41:26.1 5/2/2010: Initializing MCE Remote
11:41:26.1 5/2/2010: Playing intro sound file
11:41:26.3 5/2/2010: Initialization OK! Starting GameEx!
11:41:26.3 5/2/2010: Testing Main Loop Once: Processing Frame
11:41:26.9 5/2/2010: Testing Main Loop Once: Main Loop ran successfully
11:43:44.6 5/2/2010: Failed Opening Video: f:\movies\comedy\death at a funeral (2010).avi
11:45:21.9 5/2/2010: Exiting GameEx!
11:45:22.2 5/2/2010: Saving Settings
11:45:25.9 5/2/2010: Disposing Plugins
11:45:25.9 5/2/2010: Closing database connection
11:45:25.9 5/2/2010: Checking for applications to Launch On Exit
11:45:25.9 5/2/2010: Media Center was not open when starting GameEx, so not launching
