Hi
New user to GameEX, so far quite impressed and seriously considering registering. One problem however, I want to use the program as a front end for C64 stuff through Vice and CCS 64. I set up VICE tonight and all went well at first. However, I needed to make some changes to the emulator configuration as it was running, so I pressed alt + enter to leave full screen mode and a number of weird things happened.
1) I could not press alt+enter again to go back to full screen mode
2) Most (but not all) of the menu items were messed up, best if I post a screenshot to show you what I mean:-
Is there anything I can do to cure this behaviour? I really need the option of tinkering with the emulator while it is running, I'm running Windows XP SP3 Pro on a Q6600 PC with Asus P5K motherboard, 2GB RAM, Nvidia Gforce 9600GT graphics card, Auzentech X-Fi Prelude sound card. Thanks in advance for any advice.
Post your emulator config please so we can see how you have things setup. Maybe and advanced config is conflicting or something. Also always test outside of GameEx and see if you get the same results.
Ah seems you're right, sorry, launching Vice from the icon everything is fine, but of course GameEX is launching it from the command line. If I launch it from the command line outside of GameEX I get the same problem! Weird, I'll keep investigating.
Well at least that's narrowing it down to it being an emulator issue when run from command-line. I haven't toyed with Vice in awhile so I'll do some testing myself as well when I get a chance to see if I get the same results.
Reported the problem to the VICE team, they confirmed it as a bug with the -fullscreen command line argument in VICE, sorry for the bother.
No problem! Saw your report on their site. Always test outside of GameEx first and verify the emulator. This eliminates the possibility of it being a GameEx issue. Glad you got it all sorted out. Have fun!
