Hi everyone,
Total newbie here. I'm sure I'm making an obvious mistake - but I'd be very grateful if anyone could help me out.
Gamex has been successfully installed. I intend to use it for Mame only. Running basic Windows XP setup. When I launch Gamex, it gives me the startup screen - then goes totally black. I need to close the window to exit. Happens if I run in full-screen or window mode. Tried different resolutions - but that doesn't seem to be the problem - especially since I get the start-up screen. Log is posted below. Thanks!
20:28:58.4 2/18/2010: GameEx: Version 10.39: Starting Log
20:28:58.4 2/18/2010: Operating System Platform: Win32NT
20:28:58.4 2/18/2010: Operating System Name: Windows XP
20:28:58.4 2/18/2010: Operating System Version: 5.1.2600
20:28:58.4 2/18/2010: Checking for versions of .net Framework installed
20:28:58.4 2/18/2010: .net Framework 2.0 Installed
20:28:58.4 2/18/2010: .net Framework 3.0 Installed
20:28:58.4 2/18/2010: .net Framework 3.5 Installed
20:28:58.4 2/18/2010: Intel® Atom CPU 230 @ 1.60GHz, 895MB
20:28:58.4 2/18/2010: 1.6Ghz - 2 Cores or CPU's
20:28:58.4 2/18/2010: Running Randomize()
20:28:58.4 2/18/2010: Loading PlugIns
20:28:58.5 2/18/2010: Checking for applications to Launch On Startup
20:28:58.5 2/18/2010: Running Misc startup tasks
20:28:58.5 2/18/2010: Setting Menu types
20:28:58.5 2/18/2010: Opening Configuration File
20:28:58.5 2/18/2010: Getting Configuration Values
20:28:58.5 2/18/2010: Using Theme: Default - BlueEx - MCE1024x768
20:28:58.5 2/18/2010: Checking for alternate Image Directory for Theme: Default - BlueEx - MCE1024x768
20:28:58.5 2/18/2010: Initialising Video/MNG DLL's
20:28:58.5 2/18/2010: GameEx will check for media insertion (may affect performance)
20:28:58.5 2/18/2010: Is Media Center running?
20:28:58.5 2/18/2010: Checking/Creating LCD Registry values
20:28:58.5 2/18/2010: Check Media Center Exit/Start Mode
20:28:58.5 2/18/2010: Media Center Mode 2
20:28:58.6 2/18/2010: Video previews on. Warning: Only recommended on modern systems
20:28:58.6 2/18/2010: Snap Delay set to: 2
20:28:58.6 2/18/2010: Get other settings
20:28:58.6 2/18/2010: Set: Find emulator artwork on best match basis
20:28:58.6 2/18/2010: Start work for Form
20:28:58.6 2/18/2010: Getting Original Screen Size
20:28:58.6 2/18/2010: Opening Database Connection
20:28:58.7 2/18/2010: Initializing Component
20:28:58.8 2/18/2010: Retrieving resolution setting
20:28:58.8 2/18/2010: MAME Path is: C:\Emulators\Mame
20:28:58.8 2/18/2010: MAME EXE file is: mame.exe
20:28:58.8 2/18/2010: ROM Path is: C:\Emulators\Mame\roms
20:28:58.8 2/18/2010: Catver.ini is located at: C:\Documents and Settings\Vincent Bray\Desktop\Arcade\GameEx\DATA\catver.ini
20:28:58.8 2/18/2010: controls.ini is located at: C:\Documents and Settings\Vincent Bray\Desktop\Arcade\GameEx\data\controls.ini
20:28:58.8 2/18/2010: History.dat is located at: C:\Documents and Settings\Vincent Bray\Desktop\Arcade\GameEx\DATA\history.dat
20:28:58.8 2/18/2010: nplayers.ini is located at: C:\Documents and Settings\Vincent Bray\Desktop\Arcade\GameEx\DATA\nplayers.ini
20:28:58.8 2/18/2010: MAMEinfo.dat is located at: C:\Documents and Settings\Vincent Bray\Desktop\Arcade\GameEx\DATA\mameinfo.dat
20:28:58.9 2/18/2010: Loading Controls.ini map file
20:28:58.9 2/18/2010: Snap Path: Not Found
20:28:58.9 2/18/2010: AVI Snap Path: Not Found
20:28:58.9 2/18/2010: Flyer Path: Not Found
20:28:58.9 2/18/2010: Cabinet Path: Not Found
20:28:58.9 2/18/2010: Title Path: Not Found
20:28:58.9 2/18/2010: PCB Path: Not Found
20:28:58.9 2/18/2010: Artwork Preview Path: Not Found
20:28:58.9 2/18/2010: Panel Path: Not Found
20:28:58.9 2/18/2010: Manual Path: Not Found
20:28:58.9 2/18/2010: Icon Path: Not Found
20:28:58.9 2/18/2010: Marquee Path: Not Found
20:28:59.0 2/18/2010: Loading Custom Emulators
20:28:59.0 2/18/2010: Loading Emulator 1: [Arcade] Arcade (MAME)
20:28:59.3 2/18/2010: Using 2D Animations
20:28:59.3 2/18/2010: Using General Font: Trebuchet MS
20:28:59.3 2/18/2010: Using Title Font: Joystix
20:28:59.3 2/18/2010: Game Launcher Mode Enabled
20:28:59.3 2/18/2010: Initialising DirectDraw
20:28:59.4 2/18/2010: Applying GameEx is Loading Image
20:28:59.4 2/18/2010: Creating DirectDraw Device
20:28:59.4 2/18/2010: Using Device: Primary Display Driver
20:29:00.0 2/18/2010: 443mb video memory available
20:29:00.0 2/18/2010: Creating DirectDraw Surfaces
20:29:00.0 2/18/2010: Creating Primary Surface - Windowed Mode
20:29:00.1 2/18/2010: Creating Back Buffer
20:29:00.2 2/18/2010: Loading graphic Surfaces
20:29:00.2 2/18/2010: Display is running at: 1024x768 32bit color, 60hz
20:29:00.3 2/18/2010: Creating Surfaces Flags
20:29:00.3 2/18/2010: Creating Surfaces Misc and Dialogs
20:29:00.5 2/18/2010: Creating Surfaces Volume
20:29:00.5 2/18/2010: Creating Surfaces Arrows
20:29:00.6 2/18/2010: Creating Surfaces GameEXlogo Text
20:29:00.6 2/18/2010: Creating Surfaces Toolbar
20:29:00.6 2/18/2010: Creating Surfaces Backgrounds
20:29:00.6 2/18/2010: Creating Surfaces Toolbar Controls
20:29:00.6 2/18/2010: Creating Surfaces GameEx Logo
20:29:00.6 2/18/2010: Creating Surface Unselected
20:29:00.6 2/18/2010: Creating Surfaces Home & Exit
20:29:00.6 2/18/2010: Creating Surfaces Snaps
20:29:00.6 2/18/2010: Creating Surfaces Menu and List Bars
20:29:00.7 2/18/2010: Creating Fonts
20:29:00.7 2/18/2010: Creating Game Font
20:29:02.1 2/18/2010: Creating Game Font Faded
20:29:04.6 2/18/2010: Creating Title Font
20:29:04.7 2/18/2010: Restoring Title Font From Cache
20:29:04.8 2/18/2010: Creating Menu Font
20:29:04.8 2/18/2010: Creating Font Black
20:29:05.1 2/18/2010: Creating Font Black Small
20:29:05.3 2/18/2010: Fonts Created Succesfully
20:29:05.3 2/18/2010: 416mb video memory left available
20:29:05.3 2/18/2010: Creating instance of global keyboard hook
20:29:05.3 2/18/2010: Initialising Bass Audio Library
20:29:05.3 2/18/2010: Attempting to load game list
20:29:05.4 2/18/2010: Applying Language/Text
20:29:05.4 2/18/2010: Text/Language: English
20:29:06.0 2/18/2010: MAME CMD options: -nowindow -joy -skip_gameinfo
20:29:06.0 2/18/2010: Loading last used Game List
20:29:06.1 2/18/2010: Cannot Load Play List. Check Path and filename
20:29:06.1 2/18/2010: Creating DirectSound Device
20:29:06.1 2/18/2010: Trying: Primary Sound Driver
20:29:06.1 2/18/2010: Loading Sound Files
20:29:06.2 2/18/2010: DirectSound Device Created Successfully
20:29:06.2 2/18/2010: Initialising DirectInput for Gamepad support
20:29:06.5 2/18/2010: Unable to create a joystick device
20:29:06.7 2/18/2010: Validating: Emulator_1: Custom Background: C:\Assets\MAME\Snaps
20:29:06.7 2/18/2010: Warning: Emulator_1: Custom Background Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Snap Path: C:\Assets\MAME\Snaps
20:29:06.7 2/18/2010: Validating: Emulator_1: Custom Art Path 1:
20:29:06.7 2/18/2010: Warning: Emulator_1: Custom Art Path 1 Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Custom Art Path 2:
20:29:06.7 2/18/2010: Warning: Emulator_1: Custom Art Path 2 Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Custom Art Path 3:
20:29:06.7 2/18/2010: Warning: Emulator_1: Custom Art Path 3 Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Control Panel Path: C:\Assets\MAME\Controls
20:29:06.7 2/18/2010: Validating: Emulator_1: Instructions Path:
20:29:06.7 2/18/2010: Warning: Emulator_1: Instructions Path Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Database:
20:29:06.7 2/18/2010: Warning: Emulator_1: Database Does not exist
20:29:06.7 2/18/2010: Validating: Emulator_1: Title Snap Path: C:\Assets\MAME\Titles
20:29:06.7 2/18/2010: Validating: Emulator_1: Box Art Path: C:\Assets\MAME\Boxes
20:29:06.7 2/18/2010: Validating: Emulator_1: Cart Art Path: C:\Assets\MAME\Cartridges
20:29:06.7 2/18/2010: Validating: Emulator_1: Manual Path: C:\Assets\MAME\Manuals
20:29:06.7 2/18/2010: Warning: Emulator_1: MAPFile Does Not Exist
20:29:07.0 2/18/2010: Initializing MCE Remote
20:29:07.1 2/18/2010: Playing intro sound file
20:29:07.1 2/18/2010: Initialization OK! Starting GameEx!
20:29:07.1 2/18/2010: Testing Main Loop Once: Processing Frame
20:29:12.6 2/18/2010: Exiting GameEx!
20:29:12.7 2/18/2010: Saving Settings
20:29:12.8 2/18/2010: Disposing Plugins
20:29:12.8 2/18/2010: Closing database connection
20:29:12.9 2/18/2010: Checking for applications to Launch On Exit
Sounds like a video issue to me. What video card do you have and do you have the latest manufacturer supplied drivers? I notice your running an on Atom so I am guessing its a netbook? It could be your video card is not up to it. Although Ive known Gameex to run pretty well on netbooks. It does not require a special video card normally. I suspect updating xp to the latest patches and updating your video card drivers should sort it out for you.
Just to add I have a Atom motherboard, pico psu etc... Gameex works fine. Have you tried choosing a diffrent theme?
Thanks -while not a netbook, it is a pretty basic computer. New, using an NVIDIA graphics card. And, I switched the card settings from "quality" to "performance". Runs great now. Thanks for the support and for a great product!
