How do i set up the videos on the background i ready did the background theme. but it didnt work like on the video in emumovie site. i was thinking because there for mame 128 and im using mame 133, can that be the problem? or maybe im doing something wrong?
If you are referring to the AVI SNAP as the background in gameex, it does not matter what mame build you have. Why don't you try a different theme, I believe there is one that is specific to video backgrounds, You can always upload a link to it here, perhaps its the file type or encoder used.
Oh yea, go ahead and ask elsewhere, I'm sure others will be much more knowledgeable than here.
There is an option to make the background one of 3 things (default, custom image, video). I don't remember what it's called, but you are looking to change it to the 3rd option obviously.
