Hey guys-
Just got this working- MUCH easier to setup than MameWah! GREAT!!! Questions tho-
1) How do I show screen shots of each game in the main screen?
2) is it possible to show video clips instead of static images? I know I need to download them, I just don't know where that setting is in GameEx.
3) How do I delete games out of the game list? Or, maybe 'HIDING' them is a better way?
4) There seems to be some lag times between selecting a game and starting to run it, as well as when I finish a game and escape back to the main GameEx screen- seems to be quite a bit of lag in between. Is there a fix for this?
Thanks!
1) you have to have a screen shots for the game and the screenshots have to be the same name as the game
2)yes u can put video clips instead of screenshots and thats the same place u put ur screenshots
3)just find the game u dont want on the list and then press DEL
4) i dont think u can fix this because gameex has to open the emultor load the game then when done it has to close it and then switch back to gameex
this also depends on the emulator and it should be real fast like 2-4 seconds
